Question about Mad Catz PS3 Bluetooth® Headset Wireless Headset
Where is the power button on the bleutooth headset
Help
Press on call button and hold it till the bluelight comes up
Posted on Nov 30, 2008
How to answer phone using wired headset
it s necessary to have bleutooth phone and u should read the menu that came with the wired head if u have it if no u can go and look for the way on google because every company has it way of setting thier product
Feb 24, 2014 | Jabra BIZ 1900 Headset
How do you connect it to a nokia 6300
To connect a jabra 250 to the Nokia 6300: On the Nokia go to menu > settings > connectivity > bleutooth = select and the next line = visible
On the headset when it is off > push the upper button for ± 8 seconds until the lamp is burning constant and release this button.
Choose on your Nokia on the same bleutooth menu > search audio.... It will be pairing in a few seconds . It will ask if it is ok to make the connection. The password is "0000" and push on "yes"
I hope you cann understand my english, I'am dutch.
Nov 17, 2010 | Jabra BT250 Consumer Headset
I recently changed my cell phone to a Nokia model 6350 and would like to connect my Plantronics 330 Bleutooth to it. What steps should I take?
Maybe you should delete the pairing from your other phone, after that you just follow the directions on your phone. Make sure that the headset is fully charged. If you are looking for a Bluetooth to stream music, your headset must have A2DP programed in. Please see the link below for some examples of headsets with A2DP.
Headsets with A2DP programming
Good luck from Headsets Direct!
Oct 21, 2010 | Plantronics Explorer 330 Headset
I am tryiung to pair my plantronics 220 bleutooth up with my blackberry cure I need A passkey in order to con
Well the default pass key for most of the headset's is 0000 so you can try this .........
Good Luck!!
Thanks for using FixYa!!
Jun 09, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Whats procedure to connect HTC touch to a bluetooth headset-
Tab start then communication manager and tab bluetooth.Then tab x.go again start-settings.Tab connections-bleutooth and and make sure tha the bleutooth is turned on tick the device visible to other devices.tab x.Then start and tab internet explorer . Your mobile start searching for a device.thats
Before making the device to search for Bluetooth, you should make headset discoverable mode, by continously holding the POWER button, till you get stable LED
RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 15, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
NEED PASSWORD
0000 should have worked, try the last four of your phone number.
Aug 13, 2008 | Motorola Mobility H700 Wireless Headset
Unable to use Bluetooth on HTC Touch
Tab start then communication manager and tab bluetooth.Then tab x.go again start-settings.tab connections-bleutooth and and make sure tha the bleutooth is turned on tick the device visible to other devices.tab x.Then start and tab internet explorer . Your mobile start searching for a device.thats it.
Jul 28, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
Using h700 as a PC headset
Rjcroller wrote and is working fine. please follow....
Steps to pair a H700 headset with any bleutooth pone:
  1. Make sure the H700 fully chared (very important)!!
  2. Make sure the microphone boom is folded closed, i.e. power is off!
  3. Hold the call button for 1-5 seconds until the light is steady lit purple
  4. Flip out the microphone boom, the light should stay lit purple!
Now you are ready to pair the headset with your phone, so follow the pairing instructions of your phone.
Note: When prompted for the Passkey; it is most likely 0000 but the correct Passkey should be on the headset accessory instructions.
I must add that indeed my headset on occation (once or twice every three months) also loses its connection with the blackberry (a 8703e) . At which time I have to remove the headset from my phone bluetooth device list, and start the above described steps to pair my headset with the phone again.
Jul 16, 2008 | Motorola Mobility H700 Wireless Headset
Mad Catz PS3 Bluetooth® Headset Wireless Headset Logo
57 people viewed this question
Top Mad Catz Radio Communications Experts
TO Lady
Michael Vincent Cruz
Tom Chichester
Are you a Mad Catz Radio Communication Expert? Answer questions, earn points and help others
