Question about HP LaserJet 2200dtn Printer
Cannot print attention light blinks red yet the paper is not jammed, the toner cartridge is inside, all the trays are closed propely and i have fed the printer with papers
  • Uwe Klopfer
    Uwe Klopfer May 11, 2010
    more details please...
    printer model would be nice to know.....
If this is a 2200dtn, have you checked the duplex turn around tray under the printer? You can access this by removing tray 2, inside on the front left you should see a small green tab which will release a drop down tray. Many times a sheet or even just a piece of paper can get lodged in the sensor causing a paper jam condition.
Posted on Nov 22, 2008
I don't have the manual and the red light is on. Is that the toner needing replacing and how do I do it?
Here are the things that a steady red light may indicate (from the Owner's Manual):
led-erroron17.jpg A paper jam has occurred. To solve the problem, see "Clearing Jams in the Paper Tray". The front cover is open. Close the front cover. The top cover is open. Close the top cover. The paper tray is empty. Load paper in the tray. See "Loading Paper". A toner cartridge is not installed. Install a toner cartridge. See "Installing the Starter Toner Cartridge".
• A paper jam has occurred. Check the paper tray area.
• The front cover is open. Close the front cover.
• The top cover is open. Close the top cover.
• The paper tray is empty. Load paper in the tray.
• A toner cartridge is not installed. Install a toner cartridge.
Jul 26, 2011 | Dell 1110 Laser Printer
IT IS JUST RED BLINKING AND DOES NOT PRINT
Red blinking could indicate out of paper or out of toner. Be sure to check which light is blinking; the one for lack of toner or paper.
Check whether the paper tray has any paper and if it has, is it properly closed? Check whether it has a paper jam also.
Check the toner cartridge and ascertain whether it has anything. Lastly open the top cover and close it again for the printer to re-initiate itself.
May 26, 2011 | Kyocera Mita FS 1010 Laser Printer
I own a ML-2525/XAA and have a blinking light on the right hand side of the unit. It looks like: <--->/(a triangle with an explanation mark inside it.
Per your user manual, here is a list of all the LED status':
Jam (b-error.png)
Orange
On
A paper jam has occurred. (See Clearing paper jams.)
Online/Error (b-online.png)
Off
  • The machine is off-line.
Green
On
  • The machine is in power saver mode.
  • The machine is on-line and can receive data from the computer.
Blinking
  • When the LED slowly bilnks, the machine is receiving data from the computer.
  • When the LED rapidly blinks, the machine is printing data.
Red
On
  • The cover is opened. Close the cover.
  • There is no paper in the tray. Load paper in the tray.
  • The machine has stopped due to a major error.
  • Your system has some problems. If this problem occurs, contact your service representative.
  • A toner cartridge has almost reached its estimated cartridge life[a]. It is recommended to replace the toner cartridge. (SeeReplacing the toner cartridge.)
Blinking
  • A minor error has occurred and the machine is waiting for the error to be cleared. When the problem is cleared, the machine resumes.
  • Small amount of toner is left in the cartridge. The estimated cartridge life[a] of toner is close. Prepare a new cartridge for replacement. You may temporarily increase the printing quality by redistributing the toner. (See Redistributing toner.)
Feb 28, 2011 | Samsung ML 2525 BW laser Printer
The traingle is flashing orange the rest not flashing. the printer does not print
In the Attention state, the Attention light is blinking and the Go and Ready lights are off. This state can be reached in the following circumstances:
● Paper tray is empty
● Door open
● Toner Cartridge Missing
● Paper jam/ Tray Misfeed
Pressing Go attempts to reset after a jam is cleared or is ignored in the other error cases. It may be necessary to clear the error manually and press Go or close the top cover. If the error still persists, the device will return to the Attention state.
Note
The LJ1010 product series does not have paper out sensors. When the printer is in an Attention state because the paper tray is empty, the user must reload paper and press Go.
Nov 13, 2009 | HP LaserJet 1010 Printer
Show paper jam what do i do?? But no paper or anything is there.
I'm assuming that the printer will not print and error message displays on the computer. Also, the "Attention light" ( triangle shaped icon by light on right side of printer) at the top of the control panel blinks, and the Ready light ( light just below the Attention) is off.
Solution
If you see any loose paper bits remove them check the paper tray, the priority feed slot, and the output bin.. Even if you do NOT see any paper particles do these steps.
  1. Open the top access door,It flips up and then remove the toner cartridge. Try to do this in a dimly lit room, and cover the cartridge with paper, to try to reduce it's exposure to light.
    2. It is at this point you can remove paper from the inside, if you see any bits. Otherwise place cartridge back in. and close cover.
  2. Replace the cartridge, and then close the top access door.
  3. RESET the printer
By pressing the power switch on the back of the printer, turn it OFF.. Then turn it back ON
Then reload the paper into the tray.
Please let me know if this solution is helpful, and rate the reply.
Thank you !
Jul 06, 2009 | HP LaserJet 1020 Printer
Hiw do I reset the
The following conditions can cause the On Line LED to glow:
* Printer paper is jammed inside your printer.
* A cover is not be closed properly.
* The toner cartridge is not inserted properly and needs to be reinstalled.
* The toner cartridge is running low.
* There is no paper in the paper tray.
* The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks
If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. For replacement cartridges, please click here to visit our official online parts distributor.
On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service
Apr 14, 2009 | Samsung ML-1640 Monochrome Laser Printer
Samsung printer ml 1510 red light flashes after self test
Red Error Light Stays On The following conditions can cause the On Line LED to glow solid red:
  • Printer paper is jammed inside your printer.
  • A cover is not be closed properly.
  • The toner cartridge is not inserted properly and needs to be reinstalled.
  • The toner cartridge is running low.
  • There is no paper in the paper tray.
  • The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Mar 21, 2009 | Samsung ML 1510 Laser Printer
Attention Light Flashing
Unfortunately, HP didn't make this indicator very descriptive. Their product specification page for this printer states that the blinking Attention light, "indicates that the printer media input trays are empty, the print cartridge door is open, the print cartridge is missing, or other errors".
You've already changed the print cartridge and the light is still blinking, so you should take a look at the other conditions described such as an empty paper tray, open door, and so forth. You also will want to look for a paper jam or carriage jam. These are two very common errors that will result in a blinking Attention light.
HP.com does provide a web page that describes a specific problem associated with a blinking Attention light:
Job Stuck in Queue
See if any of these suggestions work out for you. If not, post back your results along with anything else that you've learned about the problem. Good luck.
Oct 08, 2008 | HP LaserJet 1020 Printer
Printer ML2010 not responding
LED pattern Possible Problems and Solutions
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
Paper Jams” on page 5.6.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See “Installing the Toner
Cartridge” on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
Jul 15, 2008 | Samsung ML 2010 Laser Printer
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
May 28, 2008 | HP LaserJet 1012 Printer
HP LaserJet 2200dtn Printer Logo
98 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
