Question about Lasko 5610 Baseboard Heater
Lasko 5610 red caution light, no power
My Lasko space heater's red "caution" light is on, and the heater no longer heats. What exactly is the message it's sending me? Element shorted out, switch not functioning, insufficient voltage? ls there anyway to reset it?
  • 1 more comment
  • Anonymous Jan 20, 2008
    I have the same model, and my "Caution" light recently came on, and the heater stopped working. Does this mean it needs to be replaced, or is there something I can do to safely reset it? I am not very familiar with the inner workings of electronic devices, so testing functions on a circuit board is out of the question for me unless made very straight-forward and simple.
  • Anonymous Mar 06, 2008
    I also have the same problem with the red caution light.I too plan on trying the solution listed here! Thanks for the advise.
  • maxine1215 Apr 15, 2008
    i have the same problem c with the red light and its not working can you please tell me what to do
The thermal resister between the two reset breakers on the bottom is what the problem with mine was
Posted on Mar 12, 2008
In the bottom of th e 5610 there are 2 automatic reset breakers. In betwene the two there is wire connecting them together. In the middle of this wire is a thermal resister and thats what repaired mine. Replace it and your heater will heat again.
Posted on Mar 06, 2008
  • 625 Answers
The caution light is telling you something is wrong. most wired baseboard heaters have a hi limit cutout that may be bad.  it is connected into the heater circuit as a safety device.  you could jump out this element to test this theory.  if the element is shorted, certainly it would blow a fuse or circuit breaker.  if the element is open it won't heat at all.  you need to take it apart and use a test meter to troubleshoot it.
Posted on Oct 15, 2007
I have a Tower Lasko heater and the red light came on and no heat??
pick it up and shake it. put it down and try it again.
Jan 02, 2018 | Lasko Heating & Cooling
Lasko heater blinks 88 no heat
What type of Lasko heater do you have?
Nov 12, 2017 | Televison & Video
Can I purchase a new remote for an unidentified heater?
Heaters : Target
www.target.com/c/heaters-home.../-/N-5xtuk
Target Corporationheaters buying guide > ... (125) reviews for Lasko Tower Heater with Electric Control ..... (23) reviews for Lasko Digital Ceramic Tower Heater with Remote.
Lifesmart Meduim Room Infrared Heater w/Remote - Space ...
www.amazon.com > ... > Space Heaters
Amazon.com, Inc.Amazon.com - Lifesmart Meduim Room Infrared Heater w/Remote - Space Heaters. ... This compact heater also includes a new larger remote control to operate the ... the best heater I have ever owned for my purposes and would definitely buy ...
Heaters - Overstock Shopping - The Best Prices Online
www.overstock.com/Home-Garden/Heaters/.../subcat.html
Overstock.comBuying Electric Heaters: Tower heaters: Tower heaters are ideal for many homes .... Lifesmart Slimline Compact Infrared Heater with Remote Today: $102.99 4.4 (10 .... Dyson AM09 White Hot + Cool Fan (New) Today: $449.00 $499.99 Save: ...
Jan 27, 2016 | Heating & Cooling
I bought this heater August of 2014, and the red caution light is on but does not heat. What can i do?
don't send anything to Fixya. Please contact your dealer, or the site where you bought this.
Mar 13, 2015 | Lasko 5622 1500 Watts Low Profile Heater
Schematic plf504d thermalinc
My experience with Lasko heaters is with the small portable ceramic types. On mine there are two knobs. One is the "Power"; the fan symbol is for fan only, then (I) Low Power and (II) High Power 1500 watts. The other know is the thermostat from (-) to (+). Set the thermostat towards (+) until the temp in the room is the way you want it. Then turn the thermostat know towards (-) until the unit shuts off. This is now the temperature setting and the heater will cycle on and off to this setting. Hope this helps.
Dec 13, 2013 | Lasko 5610 Baseboard Heater
Hi, I have the Lasko Ceramic Elements heaters. When I plug it in, the light lights up to show it's plugged in, but when I try to press the POWER button turn it on, it beeps but does not do start heating...
If I am getting this right you just purchased this heater? I would return it and get another one. It sounds like the tip over switch is not made and will only show that power is getting to it but the tip switch is keeping it from heating.
Dec 14, 2010 | Lasko 5540 Ceramic Compact Heater
Lasko 5350 will not power up. Tempermental.
I had the same problem with mine,, I called the 800# and they told me to either vacuum it out weekly or use a hair dryer to blow out the vents, both solutions seemed to have work for me ~ good luck
Nov 14, 2008 | Heating & Cooling
Yellow caution light
I also have the model 5620. with the yellow caution light on. After taking the unit completely apart I found 2 thermal fuses on the bottom of the unit(appox. size of a nickel). They are located under 'U" shaped brackets which are below the medal heating element. The thermal fuses do not reset. you could test them with a drip or two of souder or wire on the top - if you ran the heater this way it would be a safety problem as the fuse would be overridden. I am throwning mine away.
Mar 16, 2008 | Heating & Cooling
Lasko heater model 5620
Underneath the heater element are two thermostats that are run in series with each other. Inside the wire that connects them is a thermal fuse that opened up. Replacing the fuse corrected the problem.
Feb 12, 2008 | Heating & Cooling
Lasko 5610 Baseboard Heater Logo
4,821 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Craig Butler
Craig Butler
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
