Question about IBM ThinkPad G40 2388 Notebook
Monitor plug not working?
Well it started about 12 am 11/20/08
i was puting in a new hard drive.. i plugged in everything then turned it back on and the screen wouldnt come on you know when your computer is inactive for a while and the light turns yellow well it does that and when i turn off the monitor and then turn it back on it just shows the oppions like resize ect. so i took my tower (compaq presario) (( old yes i know)) in to a nother room and i plugged in the tower in to the monitor and it worked so i then turned it off again to put the new hard drive in and yet again the monitor would not work.. Im stumped i dont know what to do
So if anyone does know what to do then ill be glad to have the help im just hopeing that its not the pice that you plugg in to the computer.
    Brigadier General:
  • 6,966 Answers
Initially, pls check the Master/Slave jumpers. Additionally, pls check that the IDE flat cable is connected right.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 21, 2008
Hello my names antonio. I have had about 5 people look at my desktop and can not figure out what is wrong with it. Everything starts up fine all my pieces are working efficiently, but it will not come up...
Are you using a offboard video card? If you please make sure you unplug any external video card that is plugged in. If you have a offboard video card please make sure your monitor is plugged into that video card and not the onboard which is normally located near the power, Audio in/out, and Ethernet port on the back. Most external video cards are on the back located lowest to the base. This could be caused by having a bad video card.
Another possibility is your Hard Drive has gone and you will need to purchase a new one.
Recomendations:
Bring your computer to any computer store and ask them to check if they can detect any memory on your hard drive and if there isn't any present, that means your hard drive has fried (Happens a lot). Personally all this informaiton you have provided me leads me to believe it is your hard drive.
Hope you get this problem fixed and if you have any other question's, please do not hesitate to ask. Please don't forget to rate, Thanks! :)
Oct 12, 2010 | Computers & Internet
Hi, my Dell Vostro 200 monitor isn't working; when I boot up the light is blue and everything else seems to work but the monitor says 'Entering power save mode' or something and it shuts off. I can't get...
Your monitor is most likely fine. That message is the monitor telling you it's not getting any video signal from the computer.
If you're hearing all the sounds that go with a normal startup (usually a beep from the motherboard, then hard drive activity, finally the normal Windows startup sound through the speakers), and seeing that message, then you may have a monitor problem. You can try another monitor as a test.
The trouble is probably that the computer is turning on, but not actually starting up. This may be due to power supply, memory, processor or motherboard problems. Or one of the drives or expansion cards connected to the motherboard may be keeping the system from starting.
Make sure the memory modules are firmly seated in their sockets, and disconnect everything else but the power supply. If the motherboard, processor and memory are working, the system will start and you'll see something on the monitor. Then you can start reconnecting parts and see when the problem returns.
Mar 30, 2010 | Dell Vostro 200 Mini Tower With 20" Flat...
Lap top screen
It's possible that it's a hardware problem, Since this is a laptop it may be hard for you to reseat some of the internal devices inside in your laptop so we could start isolating the issue from the hardware and to the software.
First try to power cycle it, turn off your laptop remove the battery, any external connection like external mouse, external hard drive and monitor and press the power button for 15 seconds after that put the battery in and turn it back on without the external devices plugged in. (if it turned on without a problem that's good-possible that one of the external devices are causing it to keep on restarting, to isolate it you can just put the external devices one-by-one and start the computer, if it start occuring you know who is causing the problem)
If you can disassemble your laptop you can try to remove the hard drive, then turn on your computer, if your computer didn't restart that means that the problem is with you hard drive, possible that the software installed in it is faulty or the hard drive itself (try plugging it back in properly let's see if it'll work, if not, you may need to buy a new hard drive or before buying one, you can try to plug your hard drive to a different computer (acting like an external hard drive) and backup all your important files and reformat that hard drive, after reformatting it you can try to plug it to your laptop again. (if that hard drive is not detected to another computer meaning that it's faulty)
If that didn't resolve the problem, you can try to reseat the memory testing each memory chip and slots, processor.
Jan 13, 2010 | Compaq Presario R3000Z Notebook
My computer restarts recognaizing WD external hard drive!
I suggest you check the power management on the device. You can right-click the disk in the Device Manager and see if it is allowed to be powered off, or you can check the power settings in the control panel.
Most likely it is turned off, and when it resumes, the computer somehow thinks it was not plugged before.
Jules
Apr 19, 2009 | Western Digital Passport WDXML800UE...
Eee pc won't turn on (I think have already posted this,not sure)
Sounds like a classic case of hardware failure!!!!!!! possibly your motherboard, start by removing the battery, hard drive and optical drive.
disconnect the laptop monitor and connect the laptop to an external monitor.
remove the memory modules clean the brass contacts with a eraser and place back in the machine 1 at a time to check to see if they work, remember to plug in the AC power suppy, if you see the post screen then its a memory issue and you can then reconnect your laptop monitor to see if it lights up, if everything works but the monitor then its the inverter or backlight that has blown and is easily repairable saving you money on a brand new screen
Nov 13, 2008 | ASUS Eee 4G Notebook
HP dv9000
 Hello jarkk, I believe your problem is with your backlight inverter. the hard drive should be installed for this process of checking it on an external monitor. with the hard drive removed it will not boot to the operating system. with the drive in, use the external monitor. if the monitor works when plugged into the external monitor plug, this will eliminate a bad video card. if the screen is still black on the laptop screen, replace your backlight inverter. the last case cenario is to make sure your backlights are not burnt out.
Sep 11, 2008 | HP Pavilion dv9000z Notebook
Compaq Presario S0000/8000 Series hard drive won't turn on. Green light on back is blinking. Power strip is working, modem, monitor and speakers getting power and working?
is the power supply working have u recently installed a new hard drive or cd rom need to make sure that the wires are securly plugged into the drive and into the board and are plugged in to the drive correctly if this is all ok you may have to get a new drive
Aug 14, 2008 | Computers & Internet
Laptop screen
Did you unplug the 'tower', or did you remove the hard drive from your computer? In either case, the monitor would not be affected. I suggest plugging everything back in where it was, start from scratch, and see if your monitor works then.
Mar 09, 2008 | Computers & Internet
Monitor powers down upin startup
you need a new video card. it is powering down becuase it is not reciving any signal from you computer. if you are useing onboard video (vga) get a pci video card if you are useing a pci card try puting it in a dfrent slot.
Dec 20, 2007 | Gateway 310S (2900621) PC Desktop
IBM ThinkPad G40 2388 Notebook Logo
42 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
