Question about Panasonic KX-T7630 Corded Phone
Speed dial access
I cant work out how to use speed dial on my system
  • Anonymous Apr 02, 2009
    how do you DELETE numbers from the system speed dial??
  • Panasonic Master
  • 2,460 Answers
It's easier if you have access to the database to put in names with the numbers, but in the simplest sense, you can take a piece of paper, write down locations, and start entering numbers.
PROG
They are added in sytsem speed dial from the first extension or one designated as the manager's phone. PROG **1234 gets you into programming and 001 is the system speed dial area. With a combination of NEXT's and ENTER, you can be looking at SD 000 (ie PROG **1234 NEXT NEXT ENTER NEXT) and you're ready to enter a speed dial in bin 000. The complete number starts with an access code (9) plus the number as you would dial it. For example 918005551212 ENTER puts that number in bin 000. NEXT will step to 001.
USE
Press INTERCOM or select a line and press AUTODIAL and dial the 3 digit code. If your installer was lazy, you will have a problem as "9" selects the highest line in a trunk group, one that you might not have. In that case, he'll either have to program the system properly, or you will always have to pre-select a line to use speed dial.
Notice that this is just hte instructions for SYSTEM speed dial. I guessed that it was what you're looking for. Personal speed dial is a different set of instructions and it could be either under a button or in your 10 or 100 number personal directory (so that's where the 2 digit SD's went :-))
Anyway, if you need those instructions and can't find them in the user manual, please post back.
Carl
Posted on Nov 21, 2008
  • 560 Answers
To store names and numbers to Personal Speed Dial:
-While on hook, press *30 then the 2 digit personal speed dial location, enter phone number to store, press #
Done.
To call using speed dial stored on the phone:
-Lift handset or press speaker button, press AUTO DIAL button, press * then the 2 digit location of your contact.
Posted on Apr 09, 2009
2 Suggested Answers
SOURCE: uniden power max 5.8 speed dial
Press and hold a number key (0-9) associated with the speed dial until the phone number appears, and then press talk/flash or speaker on the handset or speaker on the base. The number stored in the speed dial is dialed.
Posted on Jan 22, 2009
KX-Ta824 Speed dialing problem
Panisonictel.com has a FAQ for this model here
In that FAQ, there is this explanation of your problem:
When I tried to access speed dial, it does not call out.
When storing speed dial number of external parties, the stored speed dial number must include CO (outside line) access code (9 or 81…etc) even with direct line access. If the external number is 1234567, you must store the speed dial number as 91234567.
This rule applies to all system speed dial, station speed dial and speed dial key.
It looks like you're just going to have to add a leading 9 to all the speed dial numbers for that function to work.
Nov 04, 2007 | Panasonic KX-TA824PK Phone
How do I set up speed dialing on my phone DECT1560 ?
ou can save up to 8 phone numbers in your speed dial book. The speed dial keys go from 2 to 9. When you place a call, our system prompts you to "enter the phone number you wish to dial". You just press the appropriate speed dial key followed by the pound sign (#) and your call goes through. No long numbers to enter any more!
If you set a speed dial for our access number on your phone machine, you have to press three keys only to complete a dial - as easy as "1-2#"! That's it!
For example, you can set your parents' phone number as speed dial key 2 and your friend's number as key 3. After dialing the access number from your phone, you will press 2 then # to reach your parents, or press 3# to reach your friend. Nothing could be easier!
Speed Dial set up Instructions:
Dial the access number, wait for prompt.
Enter PIN number, wait for prompt.
Dial: "#" "2" "#" [a speed dial number: 1-9] "#" [destination number] "#". The system will confirm the number.
Example: [#] [2] [#] [5] [#] [011-888-88-88-88-88] [#]
Use Speed Dial:
Dial: [speed dial key (1-9)] "#"
Hope this will help to solve the problem....
Aug 18, 2011 | Uniden Cell Phones
Panasonic KX-T7730 Corded Phone programmed speed dial numbers not working. will not dial numbers programmed
When the system is installed, you need to make sure that only the lines equipped are in the access plan (program 400 in a TA series box). When you go to the intercom on a phone and dial "9" you should get an outside line every time. If that works, system and personal speed dials include that access code as part of the number. eg my test number is 914197845522 9+1+10 digits.
Carl
Apr 01, 2011 | Panasonic KX-T7730 Corded Phone
Hoi have got speed dial on the main switchboard, so how do i do speed dial from other extensions
There is system and personal speed dials. System is programmed from the main phone and is dialed by using the AUTODIAL button and dialing a 2 or 3 digit code, depending on which system the 7730 is connected to. The other is PERSONAL speed dial, programmed on the 12 buttons on the right side of the phone. Those are programmed at each phone by using PROGRAM pressing the button and dialing an access code (usually 9) and the number then STORE.
Carl
Oct 23, 2010 | Panasonic KX-T7730 Corded Phone
I NEED TO STORE NUMBER ON MY PANASONIC KX T7730
The mechanics of storing a speed dial number on Panasonic phones is the same, even if the phone can be connected to one of 18 different model Key Service Units. It involves pressing PROGRAM a button, an access code, the number, and STORE. In the U.S. our access code to get an outside line is "9". You may be using something different, like '0'.
The differences are if you can dial "9" on the intercom and get a dial tone, which collumn of buttons you press, and/or whether you want this to be PERSONAL numbers or SYSTEM numbers.
In a TA-824, lines are accessed high to low. If you have 2 lines on a basic system and dial "9" to get an outside line, you will land on line 3 if you have not told the system that line 3 is disabled (system program 400). So, the fast answer is press PROGRAM, a button on the right side, dial 9+your desired number and STORE. If it's a left side button, dial 29 instead of 9.
System speed dials requrie access to system program 001.
If this does not work on your system, please comment back with your actual system model number.
Carl
Nov 09, 2009 | Panasonic KX-T7730 Corded Phone
Having problem programming personal speed dial on norstar 7208
Sounds to me your trying to access your speed dial bins feature 0 then your speed dial will get you to the speed dial bins 71-92 this is your personel spedd dials your phone only 0-70 are system wide speed dials . Feature * 4 is not a feature in norstar systems.
Sep 26, 2008 | NorStar T7208 Corded Phone
Uniden power max 5.8 speed dial
Sep 22, 2008 | Uniden 5.8GHz Dual Cordless Phone
Speed dial
For System Speed dial, you can only do it from a port with Attendant Features. Typically they are ports 1 and 2.
Assuming they are still the default settings, the available System Speed Dial bins are 00 thru 79.
from one of the Attendant Ports:
Press Feature
Press Redial
Dial in the memory location bin number (00-79)
Press "9" for the Trunk Access Code (or whatever it is)
Dial in the Phone Number (24 digits max)
Press Feature
To use, get DialTone, press Redial, enter bin number (00-79)
Oct 10, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Clear speed dial/one touch settings
There is no way to clear the settings you would have to re-program the correct setting. Did you program one touch speed dial on the line buttons? I do not see how programming a speed dial could effect accessing the CO lines unless you re-programmed the CO line buttons by mistake. If so, you would need to re-program those soft keys to line buttons. The manual you have may not cover this? The phone you have can work on a few different Panasonic phone systems. If you need a more detailed manual you will first need to know which Panasonic phone system you have. The phone part number WILL NOT help you determine which phone system you have. There is a main control unit somewhere (basement, utility closet, etc..)
Aug 13, 2007 | Panasonic KX-T7431 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
564 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
