Question about Samsung CLX-2160N All-In-One Printer
Samsung 2160n printer not connected through lan
How to configure samsung 2160n printer through network
  • Samsung Master
  • 4,338 Answers
On the printer, press menu until copy menu appears on the bottom line of the display and press ok.
Press scroll button until Network appears and press ok.
Press ok when TCP/IP appears
Press the scroll button until Static appears and press ok.
Press ok when IP address appears, type in the address by typing the first byte of the address and and press ok to go to the next byte field. Press ok after you enter the 4th field.
Repeat these steps to input the Mask and the Gateway. If you need to put a DNS , follow the same steps. Then when you finish, press Stop to return to standby mode.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 22, 2008
How do I connect Samsung LAN adapter WIS09ABGN to the network?
Plug it into one of the TV's USB ports, then configure your network's credentials (SSID, encryption type and passphrase) from the network setup menu in your TV.
Aug 02, 2013 | Samsung WIS09ABGN WIRELESS LINKSTICK...
I have a D-link DGS-1005G. I have two computers connected and a printer. The D-Link is also connected via LAN. I can obtain internet connection to each computer with wireless and the printer will not...
Hi, you have to set up your printer as a device that can be communicated in your LAN by the two PCs.
To set up your printer properly in the LAN, you need to assign a fixed IP to this printer such that whenever it is switch on again, both PC still communicate to this printer without changing the new IP assigned to this printer.
You need to set up this fixed IP properly in your DLink router. For guidance please check this in your user manual of the Dlink. Please let me know any problem you may have again in future.
Aug 10, 2011 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
Non-working printer; no paper pickup
The solution shown for the Samsung CLX-3160FN All-In-One works also for the Samsung CLX-2160N.
The associated picture and methodology of "pre-stretching" the solenoid spring is virtually identical for both printers.
Worked for me on the CLX-2160N
See here
http://www.fixya.com/support/t4742967-deve_home_sensor_error
Jul 07, 2010 | Samsung CLX-2160N All-In-One Printer
We are getting problem to scan to PC
What is Error Message is it showing? or Its Connected thru USB Port or Network Port?
Please mention.
Also try to Uninstall Printer Driver / Program using REVO Unintaller and Re- Install Driver using CD came with Printer.
If it is a Network printer then Configure IP Address and Ping from Computer in LAN.
Mar 09, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Epson sx510w prints using a cable but can't get it to print wireless
The specs for your model Epson allows you to connect the you network by wireless and by LAN cable.
The specs are as follows :-
Wi-Fi Wireless LAN IEEE 802.11b/g – compatible with 802.11n*
*Transmission rate will be limited to 802.11g and will operate in the 2.4 GHz frequency band
Ethernet Wired LAN IEEE 802.3 (100BASE-TX, 10BASE-T)
Other PictBridge
Wireless security
WEP – 64bit
WEP – 128bit
WPA – PSK (TKIP) – compliant with WPA2
WPA – PSK (AES) – compliant with WPA2
To connect the printer by a LAN cable you need to configure the Epson for an IP address that suits your network configuration and connect the LAN cable to your wireless router/hub.
The reason why you cannot print using wireless is because the wireless configuration in the Epson is not setup with the router's wireless configuration ie. SSID WPA encryption etc.
For instructions of setting up a LAN network printer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
For instructions on setting up a wireless printer, the Epson wireless settings need to be configured with the router's wireless settings. Go into your router's wireless and note the SSID, and encryption settings etc and configure the Epson's wireless settings with the router's wireless settings. This will allow the Epson to connect to the wireless router. Please click on this link for instructions to secure your wireless network, configure the wireless router (if you have not already do so) and configure the wireless card in the computers and wireless printer (the instructions for configuring the wireless card in the printer is the same as for the wireless card in the computers via the printer's menu screen).
http://www.fixya.com/support/r3559128-wireless_router_security
Feb 07, 2010 | Epson Office Equipment & Supplies
Can you connect it to your computer by wireless
Sure can. Just buy a wireless print server with USB output. They are made by most big names like: Trendnet, D-Link, Linksys, Netgear, etc. I see them on Ebay for low prices 5-20 dollars.
Just make sure you get a match to the router you have for frequencies. For example: G or N
Good Luck
Jan 03, 2010 | Samsung CLP 300 Laser Printer
Netgear FWG114P Print Sever not functioning on upper level of LAN
if you set your dynalink's dhcp list up to a certain number (example: .1-.99). connect cat5 cable from dynalink lan port, into print server lan port. make sure print server can be setup as access point. if so, turn access point setting to on. make print server static ip address the next number outside of dhcp range (example: .100).
.100 ip address is the port number you should then be printing to, using a tcp/ip port.
if print server can be set up this way, then it now becomes wireless access point for all wireless devices. i am assuming, since you didn't mention it, that the dynalink is NOT wireless. if it is, the the print server just becomes another device on your existig network, taking the place of the network adapter the printer doesn't have. just set it up the same way you would set up another workstation on the network. except, make it static.
Apr 02, 2009 | NetGear FWG114P Router (FWG114PAU)
Clx-2160n and mac
please can u breef your problem a little bit
Jan 24, 2009 | Samsung CLX-2160N All-In-One Printer
Samsung CLX-2160N All-In-One Printer Logo
119 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
