Question about Compaq Evo N620c Notebook
Powering I have compaq evo n620C laptop. Everytime I plugged, it automatically turns on, the display appears and then turns black afterward. I have to press the reset button to restart. Is this normal?
  • 91 Answers
This is usually a sign of bad ram. remove the ram cover underneath, pull aside the pop out clips and remove the ram. hold the ram by its side and try not to touch the 'gold fingers'. Clean it / them with a soft clean paint brush along with their holders and re-insert. If this does not work and you have 2 sticks of ram then try each one on its own in one slot,then the other slot, turning on each time to identify the faulty module.
If this is no joy I would suspect the CPU. It could also be the motherboard video chip which is not repairable without a new motherboard but this is doubtful as it is not a common fault on this laptop.
Hope this helps some.
sparkyuiop.
Posted on Nov 22, 2008
  • Phillip Thorne
    Phillip Thorne Nov 23, 2008
    Just a thought, it could also be the internal battery needs replacing if it does boot the second time round. Do you have to redo the time settings when Windows starts?
    You can replace it yourself if you are reasonably competent at repairing things. Here is a link to download the service manual for free.
    http://www.eserviceinfo.com/downloadsm/2...
    sparkyuiop
  • 114 Answers
No nothing like that should happen it maybe because when you plug it in it gets a jolt of power because there maybe a battery short and it all discharges, and it gets a jolt and attempts to boot up but fails, you may want to check the battery otherwise it could just be a simple flaw that could require bringing it into the repair shop
Posted on Nov 30, 2008
  • 3 Answers
Pls., connect a good external monitor first, if the problem persists, then replace the memory chips with good ones.
Mr USA
Posted on Nov 24, 2008
  • 3 Answers
Dear Friend
I think it is RAM problems so remove the ram from its slot then Clean it with a soft clean paint brush and re-insert it in another slot.
Yours
Pralayankar Acharya
    Problem Solver:
  • 7 Answers
This type of problem seems regularly in MBD'S the maxim chip near vga chip become dry so my suggation is pls resold the chip by an expert chip lebel repairing person
Jitendra
Posted on Nov 23, 2008
    Problem Solver:
  • 4 Answers
I have seen this type of problem before. Question have you tryed pluging in an exterinal monitor on that laptop? If you have the same problem with the external monitor then the problem is on the mother board somewere. If the problem goes away with the external monitor then the problem is in the lcd display.
Steve
Ho to add netork card to my Compaq EVO N620c laptop
Number five is the network port, the network card is built in on the motherboard
Jan 10, 2011 | Compaq Evo N620c Notebook
Download a sound driver into my compaq Evo N620c
You can download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Sep 12, 2010 | Compaq Evo N620c Notebook
Drivers problem for compaq NOTBOOK Evo N620c
download from here
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=316684&prodTypeId=321957&prodSeriesId=316682&swLang=8&taskId=135&swEnvOID=1093
Jul 02, 2010 | Compaq Evo N610C Notebook
Troubleshoot compaq evo n620c froze on me. Then turned black screen and will not turn off.
Unplug the power, Take the battery out and leave it for 5-10 mins. Then try and turn it back on
May 20, 2010 | HP Compaq Evo n610c Notebook
No monitor n620c loptop
To switch between monitor modes (internal/external) you have to press the key combination Fn+F4 (or F8) or the F key with a dual monitor icon printed on it. This happens when you use the laptop with an external monitor or projector, and you forget to return to the internal monitor mode.
Apr 22, 2009 | Compaq Evo N620c Notebook
Compaq n620c evo laptop
Check your floppy drive and see if there's a disk in it and remove it. If there is no diskette in the floppy drive and you are still getting the error. You can go into the Bios and turn off the "boot from floppy drive", that way it will not look for the floppy drive when booting up. Hope this helps.
Feb 27, 2009 | Compaq Evo N620c Notebook
Laptop Compaq Evo N620c screen gone tiny!
dear do one thing as you have not mentioned whether you r using a laptop or desktop.........press the ctrl button on your keyboard & use the mouse scroll button up/ down..........hope this will resize the icons..........................Sameeraryan
Jan 02, 2009 | Compaq Evo N620c Notebook
Cannot locate ram on compaq EVO N620c
The RAM is located under a panel on the LHS of the touchpad.
You need a thin blade/knife to slip under this panel to lift it up and out. It is clipped in with plastic catches on the panel.
Dec 17, 2008 | Compaq Evo N620c Notebook
Laptop issues
Have they tried opening the BIOSthe mother board and HDD may have been disabled there
May 29, 2008 | Compaq Evo N620c Notebook
Compaq Evo N620c Notebook Logo
137 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
