Question about Nokia N95 Cellular Phone
My phone works but without lights
My phone suddenly went into the dark. itw working perfectly fine except for the fact tht it does not have a light. the display is black. need to place it under a light to see whts happening. kindly help
    Sniper:
  • 66 Answers
Common problem on the N95, if changing the lcd does not work, its the coil / capicitor / LED ic, all 3 situated on the pcb next to the "watch battery" 100% solve ur problem. BR
Posted on Jun 08, 2009
  • 101 Answers
Hi. The backlight is part of the LCD screen, so if you replace the LCD screen you'll fix the problem. Have a look here for a guide to replacing the screen and to buy the parts http://www.formymobile.co.uk/n95disassembly.php
Posted on Nov 21, 2008
I have a LG 50LA6200 LED TV, about 3yrs old. While watching it, the screen suddenly went black, the audio is fine.
In the dark with the set on do you see light if you look through the vent holes in the back?
Oct 19, 2017 | LG Televison & Video
All of a sudden the screen went light blue. The
Hmmmm! I would have to say you have a problem with the signal board. I have not repaired this brand or model. This would be the first thing to investigate. It is the board that contains all your antenna and rca jacks. Good Luck and visit your TV tech with this info!
Jun 30, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Brake lights went out, changed bulbs, checked fuse, still wont work
You have to check the brake light switch which should be around the brake pedal on the upperside.
Ones located rremove the wires tht go to the switch and jump them by using a piece of wire, thn check if the brake lights come 'on'. If they do , thn its the switch tht may need replacing or even sometimes adjusting inorder to operate.
Hope this helps.
May 10, 2009 | 2002 Nissan Xterra
2003 Sonoma does not turn-over
U have lost the battery, check the cables, if they are clean (no corrsion) replace the battery, modern sealed batteries fail like this, crank fine and then puff nothing, happened to at least 5 times over the years and saw it all the time at work.
Jan 07, 2009 | 1999 GMC Sonoma
White lines when you take photos in light, but perfect in the dark
The problem lies in you camera's CCD unit which is located on the back of the lens held on be 3 small screws it could also be a setting in the camera's menu try going into the menu and reseting the camera to default it works some times if that does not work than you need the ccd replaced pretty easy fix I fixed 1 with the same problem about two weeks ago for someone it happens I hope this helps you out.
Jan 30, 2008 | Casio EXILIM EX-Z1000 Digital Camera
Dull negatives
are you using the a transparency adapter on the negatives?
Oct 16, 2007 | Epson Perfection 3200 Photo Flatbed...
Dell Latitude LCD screen is dark, but computer is still working.
It sounds like the backlight has burned out. The faint light you are seeing is ambient light in your room being reflected through the LCD. Try it in a perfectly dark room and see if you can see anything on the screen. The following page should give you a sense of what is involved in replacing a backlight: http://home.comcast.net/~stonent/screenfix.htm If you aren't comfortable taking things like this apart, I would recommend finding a local repair shop to replace the backlight.
Feb 15, 2007 | Dell E173FP 17" LCD Monitor
Nokia N95 Cellular Phone Logo
497 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
