Question about Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451
Makita dpc6410 not starting
My stone cutter is not starting. it has a good spark, compression is good and turns over and fuel seems to be getting through
  • 23 Answers
I know you said the compression is good, but the number one problem with these saws is the cylinder dusting out (scaring).
before you tear off the cylinder, just double check a few things.
your fuel mixture is good
your decompression valve (depending on year bought) is not seized in the open position
you exhaust isnt blocked
check the plug (my 14" makita uses plug BPMR7A, sometimes i find a BPM7A in it)
if everything looks good, i'm sorry to say you're going to have to remove the cylinder.
remove the filter cover and starter coil
remove the shroud holding the paper filter being held on by 4 screws
remove the plug and unscrew the ground wire from the cylinder shroud and push them aside
remove the 3 remaining screws from the cylinder shroud and remove (it wont come off easily)
now you should be looking at the carb assembly hooked into the cylinder by 2 connections. loosen the hose clamp as much as you can, and be EXTRA careful removing the small hose connection. (they love to rip)
you can either remove the carb housing or leave it in. if you leave it in, you're just going to have to move the cylinder around it to get it free. if you take it out, you just have to make sure you plug the fuel supply and prevent debris from getting into the tank from the top.
i usually take the cylinder and exhaust off as one piece because the 2 exhaust screws love to get seized up in the older saws and it's just more of a hassle than it's worth. remove the 4 screws holding the cylinder down and you should be able to pull the cylinder straight up.
look for discoloration around the exhaust port and vertical lines, also check the piston to make sure the ring isnt fused to it, or broken.
i'll keep my eye on this, so if you have more questions i'll try to keep up.
Posted on Nov 23, 2008
Makita petrol stone cutter
Start by removing the wire from the cut out switch to rule out a problem with the switch, if still no spark with a new plug it will be a replacement ignition unit.
Feb 12, 2012 | Saws
Makita dpc6400 won't start but has spark
i had a similar situation with a chainsaw... and a rotortiller.
use ALOT of starter fluid or even pour a little gas through the carb, this will most likely flood it... but enough pulling should eventually start it, although it will not stay running long. if you try this and get these results.. then next take the engine apart and check the the piston walls they may be scratched. this can happen in some small engines from a couple different things. 1.dirt getting in through the air breather (bad filter). and 2. some are real sensitive and even the wrong gas/oil mix can cause this. for your sake i hope this is not the case but this was has been my experience.... hope this helps.
Nov 14, 2011 | Makita DPC6410 64cc 12" Power Cutter
Regarding makita petrol disc cutter dpc6410- how much oil do i need to add to a full tank?
Don't add oil to the fuel tank, it doesn't mix well in there and you'll almost always use too much oil. Mix your two-cycle oil and petrol in a gas can to get a 50:1 mixture. Read the directions on the two-cycle oil bottle for how much to use and put the oil in the can first so the petrol will mix well with it as you add it to the can.
Oct 11, 2010 | Makita DPC6410 64cc 12" Power Cutter
What ratio oil to use dpc7310 73cc 12power
Page 12 - 50:1
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
Your OM
http://www.makita.ca/data/upload/tools/DPC6410,%20DPC6411,%20DPC7310,%20DPC7311,%20DPC7320,%20DPC7321,%20DPC8112%20-%20ENG%20&%20FR_owner_English.pdf
It will operate on 40:1, but starting is more difficult and it carbon fouls much quicker. Failure is usually caused by an undetected air leak the additional oil will not preclude it.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 21, 2010 | Makita DPC7310 73cc 12" Power Cutter
MY MAKITA DPC6410 PETROL SAW IS RUNNING SMOKEY
It uses 2 stroke oil during combustion as it is a 2 stroke powered engine..Sometimes it may be a small deposit of oil and the bottom of the gas container which causes this smoke or else you may have added a bit more oil than needed in the fuel..I assume it is a 2 stroke engine and also note these do give out a little bit of smoke..
Dec 08, 2009 | Makita DPC6410 64cc 12" Power Cutter
No operators manual for makita dpc 6410 petrol disc cutter
Come on, it tooks me 20 seconds to find it...Web search is all about keywords. makita dpc 6410 manual leads to the answer. Adding pdf would have been even better...
Aug 01, 2009 | Makita DPC6410 64cc 12" Power Cutter
I have a makita dpc6410 disc cutter.it has a good spark and i have cleaned the carb and pressure tested the carb and the needle is holding and i have fitted a new fuel filter.it will fire up and run flat...
after servicing the carb,do u retune it?
blacking around the piston is no big deal for a small engine,as long as the piston rings are in order or in other words it still has compression.
check the fuel supply..
the tank should be airtight...
it is a diaphragmed carby...
Aug 17, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451 Logo
195 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
