Question about Panasonic Workio DP-2330 Printer
Panasonic DP 2500 paper tray error
We have a DP 2500 we refilled the paper and now it says that paper tray 1 isn't installed. Paper tray 2 works fine what have we done and how can we fix it. Thanks
  • Panasonic Master
  • 4,338 Answers
Make sure that you don't have too much paper in the tray. There is an overfill idicator on the back of the tray. Push the tray in firmly. Then try to print. If not, reset the printer by pushing "reset" button.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 22, 2008
Panasonic dp-1820e paper not detected
Listen to see if the lift motor is working properly...if it doesn't lift the paper then the machine will think there is no paper installed in the paper tray. The lift motor will need to be replaced if this is the issue.
Aug 13, 2014 | Panasonic Workio DP-1820E Copier
Add paper/add paper try 1/try 2
Is the error stating to add paper? If so, go ahead and add paper to the trays necessary.
Jul 23, 2014 | Panasonic DP-8020E Multifunction...
Panasonic dp 6030 copier error code e02-10
E2-01 sounds like a tray 1 lift malfunction. These machines use a lift motor encased in a plastic drive gear casing. Usually something inside the casing breaks, This usually happens in trays that have Ledger or Legal paper installed. The weight of the paper can cause these gear packs to break. Also if the customer loads letter paper in a tray set up for larger paper sizes, the paper can fall back causing the gears to break. We normally replace the whole lift motor assembly.
If there is more then one paper tray, you can pull tray 1 out, (the code should not appear with tray 1 open. You can at least use the manual feed to keep them going until you can get the part.
May 05, 2011 | Panasonic Office Equipment & Supplies
In printer it showing Tray 1 ADD PAPER but [paper is added to the tray still it is showing that error so what to do ? give me the solution.
1.May be because of paper sensor.try to change it
2.may be you have given wrong paper size.u might have give wrong paper size.for ex for A4 paper u might have given some other size like a3. check this it will work for u
Jan 31, 2011 | Panasonic WORKiO DP-1520P All-In-One Laser...
E02-02 - what does this error mean for a DP-C213?
E2-02 means there is an error with the lifting motor assembly for tray #2. You will not be able to use your tray #2 until it's fixed. You can check it, sometimes there's just paper clogged at the rear of the paper tray. Remove your 2nd tray to see if there is a paper clogged inside.
Otherwise the cover/case of the lifting motor is damaged and you will need a service technician to fix and replace it.
May 07, 2010 | Panasonic DP-C213 Color Copier
Panasonic DP1820E check printer E02-02 red spanner
yep!
e2-02 means there is a machine error of lifting motor assembly for tray #2.
For sure this time you can't use your tray #2.
you may check it sometimes there's just a paper clogged at the rear of the paper tray. just remove your 2nd tray to see if there is a paper clogged inside. Otherwise the cover/case of the lifting motor is damaged and you will need a service technician to fix and replace it.
Mar 14, 2010 | Panasonic Workio DP-1820E Copier
My pansonic 1820p digital copier dislays error code E02-01. The main motor & Tray 1 lifting motor do not run, from kingsley I. O.
The following might work:
Switch off at mains, remove paper from tray 1, close tray 1, switch on, replace paper when prompted.
Hope this helps.
Jan 13, 2010 | Panasonic Workio DP-1820P Laser Printer
DP-1820E - Contact Your Dealer - Printer Error E02-01
E02-01 refers to the tray 1 lift motor either you have a bad motor or there's a problem with your main board. good luck
Apr 23, 2008 | Panasonic Workio DP-1820E Copier
Panasonic workio dp-1810p
pls check out the sensor lever below the drum if it is freely moving.
because that is the sensor concerned for j33
Sep 01, 2007 | Panasonic DP-1810P Laser Printer
Panasonic Workio DP-2330 Printer Logo
260 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
