Question about Kenwood Car Audio & Video
I have got a kenwood cd player but can,t install it into my vauhall corsa because i need a seprate battery 15amp yellow cable to run from the battery supply to connect up to a cable attached to the radio cables but i can not find one in the car and do not know how to install one can u help.
    New Friend:
  • 99 Answers
I don't mean ti intrude Linktriscuit, but your solution is OK for low power car stereo's.
I have been in car audio setup for a while and what daren_norman has said was that he needs a 15A seperate cable. So to my knowledge if his CD palyer manual says it needs 15 Amps then I don't think it's a low powered one, 15Amps is quite high for a standard car radio stereo harness, and that is why it needs a seperate high guage wire capable of handling that much current.
This yellow wire replaces ACC cable in the harness, but the normal memory supply (+12V) is taken from the harness and the cd player should have good ground connection to the body of the car in addition with th harness ground.
The yellow cable should be as thick as u can get to make cable loss minimum. At high Audio levels the cable drop will increase if you use low gauge wires ( thin ) and the sound will get distorted due low batttery supply.
And thirdly there will be a remote wire to switch on and off the cd player when u turn on or off the rest of the components
Mostly there couls be two or three different ways to control the set but THE YELLOW WIRE WILL BE THICK ENUF TO HANDLE THE CURRENT AND IT WILL BE TAKEN FROM THE BATTERY + TERMINAL THROUGH AN APPROPIATE FUSE TO THE CD PLAYER OR POWER AMPLIFIER. DIRECTLY, AND IT WILL BE NOT SWICHED OFF.
I said all these because car audio currents a quite high and any silly mistake will lead to cables to over heat and mostly it will catch fire. ( Cause I have seen a maercedes benz caught up in flames due to poor wiring. "what a dread ful sight, and a 2004 model two").
So If u need help just post back and I will tell u how to do it, it is quite simple with the right way.
Cheers
Rifaa
Posted on Nov 22, 2008
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 89 Answers
You can test one of the wires from the harness connector for a contant +12v with a test light. They are sold at your local auto parts store for less than five dollars. The harness connector that i'm talking about is the harness connector that originally connected to the stock radio. All of the connections needed to install a cd player are all on that harness wire. The test light is simple to use, all that's needed is for the alligator clip to be hooked to ground. And from there, you can determine from tapping which wires are for the power supply. The power consists of three or four wires. They are ground, +12v ignition, +12v constant, and if installing w/ an amplifier, the remote. This is the usual place most people connect the wires for a new head unit.
Trying to install kenwood kcd mp238 cd player into a 1996 Ford Expedition. I need to know wiring data to connect the wires of cd player to harness, which colors should I match wires up to, so I can just...
Black Ground, yellow, battery, red switch battery, blue not used, blue white power antennea/amp, brown tel mute, white black front left neg, white front left pos, gray black front right neg, gray front right pos, green black rear left neg, green rear left pos, purple black rear right neg, purple rear right pos
Oct 24, 2012 | Car Audio & Video
Kenwood MP3 CD Player not working in a daewoo matiz
If all disks do not load the player is fubar and needs replacement. No getting around that.
Sep 11, 2017 | Kenwood Car Audio & Video
Kenwood kvt 715dvd wont turn on
check all your fuses. check power for the battery(yellow) wire and red wire(ignition- key must be on), and if all of those are good then check the fuse on the back of the stereo itself, i think it has a 15amp mini fuse in it.
Aug 05, 2010 | Kenwood KVT-715DVD Car DVD Player
Cannot set the clock,get it out of demo
I've just fitted a Kenwood KDC-3047radio to my son's Opel Corsa B
Jul 29, 2010 | Kenwood DPX302 CD Player
Memory erases everytime the ignition is turned
Be sure that the yellow wire from the cd player is connected to a +12 volt source. ONe god source is the orange wire from the cigarette lighter if the cigarette lighter is working fine. If not run a wire from the yellow wire of the cd player to the fuse block in one of the pins marked "bat". Good luck. Please rate.
May 26, 2010 | Kenwood KDC-319 CD Player
Need a wiring schematic KDC C717
Black typically goes to ground.
Red goes to battery (+) (+ all the time)
Yellow typically goes to switched power (+ when ignition in run position)
Mar 06, 2009 | Kenwood KDC-C717 10-Disc CD Changer
Battery keeps going dead
check your yellow wire must be connected to the earth
Jul 12, 2008 | Kenwood KDC-MP4028 CD Player
Kenwood dpx 4020
The iPod will stop itself from charging when the battery is full, and will not overcharge. I'm pretty sure you can't disconnect the power to the iPod (would stop it from charging) and still use the Audio to your stereo.
Aug 19, 2007 | Kenwood DPX-4020 CD / Cassette Player
Car Audio & Video Logo
96 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
