Question about HP DeskJet F380 All-In-One Printer
The printer can't be used
The scanner can use, and the copy is not sure can be used, but print can't.
if i press the print symbol. sometimes just come out the white paper. is it because run out of the ink?
  • 1 more comment
  • genemarz Nov 23, 2008
    I connected my Printer to my laptop, but it is not working. It switches on and I can photo copy, but when I give the print command on my laptop it does not respond.
  • creativeinno Nov 24, 2008
    I have the same problem, this I believe caused the problem, as I switched to a cordless LOGITECH mouse about the same time that I switched out the printer ribbon.
  • Anonymous Nov 25, 2008
    I can scan but cannot print
Hhhhhhhhhhhhhhhhhhhhhhhh
Posted on Nov 22, 2008
Copy and Scanner not responding
Copier may require you use the scan feature to make copies either ise the feeder otr flatbed. Press start on machine for manual entry but still use scan to get things working.
Nov 15, 2013 | HP HEWLETT-PACKARD CN583A Officejet 6700...
A week ago my mx300, stop printing and can't recognize scanner. Scenario example: 1. Sending document from word or even try to print the test page, print's 1/3 page then stop saying printer is offline,...
Check to make sure you have the most recent software for your printer. Go to Canon's support website to check for the latest software: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx300#DriversAndSoftware
If that doesn't work, I've sometimes have had to uninstall a printer and it's software, and then completely reinstall it again for it to work. Hope this helps.
Oct 31, 2013 | Canon MX300 Office All-In-One Printer
HOW DO I MAKE A COPY FROM A COPY ON MY HP 2420
You cannot make a copy if you are thinking of it like a photocopier. It doesn't have a scanner built into it .
If this is what you are thinking there are several quite excellent scanners out there fairly cheap. The scanner will come with software that will make it and the printer behave like a photocopier. The scanner we use at home even has a button that we just press to scan and print a copy as well as software that gives more options.
If you want to just print multiple copies of the page then this you can do. You just have to go to print options on a program menu and tell it to print the page how many times you need. You can also change the number on the printer driver but if you don;t set it back after everything after is going to print a few extra copies.
Sep 13, 2011 | HP LaserJet 2420 Printer
I have black lines on my prints. The lines only run across the print itself and not the whole paper.
If problem happen when you're making a copy, make sure the scanner glass for the document feeder or the scanner bed are squeaky clean. Use a soft cloth to wipe the scanner glass.
If problem happens when printing from your computer, try to clean the cartridge nozzles. On printer operator panel, press the Setup button > Maintenance > Clean Cartridges, press OK. Your printer will then print a page forcing ink through the cartridge nozzles and clean them.
Try to print again.
Jun 22, 2011 | Lexmark X5650 All-in-One InkJet Printer
Horizontal lines/missing print occurs on my pages. I have tried to reboot the printer, but the printing issues remain. Do I need to clean the print heads?
Follow these steps to make it work... TIP: Focus on the printer it self. make sure that it can copy (b&w and color) fine.
If your done reseting the printer go to the next step Solution #2 Clean the All-in-One and make a blank copy Before you begin, gather the following materials:
  • Several clean, soft, lint-free cloths
  • Mild glass cleaner
Step one: Clean the scanner glass and lid
  1. Press the power Button to turn off the product, and disconnect the power chord at the back of the printer.
  2. Open the scanner lid, and remove any originals from the scanner glass.
  3. Spray a clean, soft, lint-free cloth with mild glass cleaner.
  4. Wipe the scanner glass and the white underside of the scanner lid with the dampened cloth.
Step two: Clean the automatic document feeder ADF
  1. If the product is not already off, press the Power button to turn off the product, and disconnect the power cord from the product.
  2. Locate the ADF frame to the left of the white underside of the scanner lid.
  3. Press the ADF frame release.
  4. Unhook and remove the ADF frame.
  5. Lightly dampen a clean, soft, lint-free cloth with a mild glass cleaner.
  6. Use the dampened cloth to clean both sides of the transparent film, and the white strip in the center of the ADF frame.
  7. Clean the ADF frame.
  8. Re-Install the ADF Frame
Step three: Make a blank copy
  1. Remove any originals from the scanner glass.
  2. Load plain white paper in the input tray.
  3. Press Start Copy Black to make a blank copy.
  • If the copy is clean, there is no need to continue troubleshooting.
  • If the copy has vertical bands, lines, or streaks, there might be dust inside the product, poor internal connections, or the product might be damaged. Contact HP's Printers support department @ 1-800-474-6836
To view this steps w/ images click on this link Good luck! :)
Feb 01, 2011 | HP Officejet Pro L7680 All-In-One Printer
I bought a new cartridge for my printer and it still won't print...I just had my computer fixed for virvses..could that be the problem
No, that should not affect the printer, but I would suggest reinstalling your drivers for the printer. And make sure your cables are nice and snug and plugged in properly. Sometimes it doesn't work if a cable is loose. Also, try to print something without using the computer. Does your printer have a scanner? If it does, you can copy something and print it out, that will let you know the printer is ok and it could be a driver problem on the computer. And when you go to print make sure that printer is the one selected to print, because sometimes there is more than one printer option. Hope this helps. Cheers.
Oct 02, 2009 | Lexmark C533DN InkJet Printer
Everything prints blank, but the ink is fairly new and there are no errors showing up on the screen of my HP 5610 all-in-one printer/ copier/ fax
Hi !
As you are using HP officejet 5610 printer, so perform the following steps on the printer to print a self test report to check the functionality of the printer.
Press Setup on the All-in-One then Press 2 then press 6.
If you are unable to perform the above steps, then try to make a copy using the scanner glass ( By placing a text document face down on the scanner glass and then press color copy button.).
If the printer make a copy or prints the self test page, then it confirms that the printer is working fine.
The issue could be with the software side. However, if the printer again prints the blank page, when you try to make a copy or printing a self test, then the issue is with the print cartridges.
Be sure that you are using the Hp genuine ink cartridges not refiled nor re-manufacture. Check the expiry date printed on both the print cartridges.
If all are correct, then perform the below steps to clean the print cartridges.
1. Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridges , from the top to the bottom.
2. The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts.
3. The contacts inside the printer may also require cleaning. Using a clean, dry, lint-free cloth, gently wipe the contacts, from the top to the bottom.
Then perform the below steps to power cycle the All-in-One unit.
1. Verify that the unit is switched on. Disconnect power cable from All-in-One and also from wall outlet.
2. Wait 30 seconds.
3. Plug in the power cable to All-in-One and also to wall outlet.
Then insert the print cartridges and try to make a copy and check for the result.
Please revert back to me if the issue occurs again.
With regards.
Mike
Jun 29, 2009 | HP Officejet 5610 All-In-One InkJet...
My epson cx6400 printer won't print it not been use for several
I'm not sure what you mean by not printing, is it trying to print but only blank pages?
Make sure its on and the "!" is off.
Try copying first using the unit itself since this is an all in one printer. If it prints then we know its working.
If scanner is not working you can try printing without using the scanner featured on the unit. press on the setup button use the left or right arrow repeatedly and select on nozzle check then press on the color button.
If it prints but the pattern is incomplete (gaps or breaks on the lines) you can try head cleaning.
Press setup use the arrow left or right repeatedly and select on head cleaning then press on the color button then it will clean it.
Make sure that everytime you clean it you have to print on a nozzle check so that you will know that it prints properly.
If there are no gaps or breaks on the lines print on a document or picture it will give you good printouts
Feb 12, 2009 | Epson Stylus C86 InkJet Printer
Lexmark x3550
Changing print cartridges Changing print cartridges Removing a used print cartridge
  1. Make sure the printer is on.
  2. Lift the scanner unit.
    The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the cartridge carrier lever to raise the cartridge carrier lid.
  4. Remove the used print cartridge.
Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge. Installing print cartridges
  1. If you are installing new print cartridges, remove the sticker and tape from the back and bottom of the cartridges.
    cartridge_tape_remove_one_2.jpg Warning: Do not touch the gold contact area on the back or the metal nozzles on the bottom of the cartridges.
  2. Press down on the cartridge carrier levers to raise the cartridge carrier lids.
  3. Insert the black cartridge or the photo cartridge in the left carrier. Insert the color cartridge in the right carrier.
  4. Close the lids.
  5. Close the scanner unit, making sure to keep your hands out from underneath the scanner unit.
    scanner_unit_close_2.jpg The control panel display will prompt you to load paper and press button_select_0.jpg to print an alignment page.
    Note: The scanner unit must be closed to start a new scan, print, copy, or fax job.
Jul 22, 2008 | Lexmark X3550 All-In-One Printer
HP DeskJet F380 All-In-One Printer Logo
21 people viewed this question
Ben Johnson
