Question about Teac SRL50 Clock Radio
Intermittant failure LED display of my TEAC SR-L50 Clock Radio
Each digit on display is made up of 7 lights.
One of the digits has an intermittant problem with the top and bottom horizontal light.
It appears to be associated with humidity. All through winter it behaves fine, but as soon as the humidity increases in summer I lose those two lights.
It is the secong digit that is faulty and being a clock radio it means you cant tell what hour it is.
I would like to know whether it is a faulty part, bad connection or just a ideosyncracy of larger LED displays.
    Brigadier General:
  • 6,966 Answers
Offhand, the failure of the 2 segments would seem to be intermittent (granted affected by humidity). Technically, I would suspect a case of cold solder. They could be replaced or if you know somebody who could solder, then it is a matter of re-heating the joints and adding a dab of soldering lead.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 21, 2008
Teac model LT-1 how to set clock
To set time on TEAC CD Receiver LT1
Press Memory/Clock Adjust button until numbers flash.
First display is 24/12 for choice. Change with >>> button.
Press Memory/Clock Adjust button again and Hours digit
flashes. Set with >>> or <<<.
Press Memory/Clock Adjust button again and Minute digit
In 12 hour mode "PM" will be displayed
Sep 23, 2012 | Teac LT-1 Clock Radio
How to set clock on the teac sr-l100 just bought at yard sale, no info book. thanks d
The "set time" button on my SR-L100 is located inside the CD compartment. To set the time the unit needs to be in the standby mode. Press and hold the set time button until the time blinks, then use the tuning/clock adj. dial to set it. Hope this helps!
To set the alarm on the TEAC SLR 100:
Be sure the radio is set to off or standby.
Hold down the BUTTON for the alarm you wish to set (#1 or #2) until the TIME ON THE DISPLAY begins flashing. Use the TUNER/CLOCKSET DIAL to change the display to the time you wish the alarm to go off. pRESS THE ALARM BUTTON BRIEFLY TO RETURN TO NORMAL OPERATION.
May 28, 2011 | Teac SRL50 Clock Radio
I cannot set the clock on my Teac MC-DX50i
put the system in standby then use your forward and revese buttons to set the time.
May 31, 2009 | Teac Hi-Fi Radio w/ iPod Dock BLACK...
Blue LED display too bright
TRY........with radio on and set on "AM", hold "Clock" button about 7 seconds and let up - bringing a setup menu. Using tuning knob,scroll to "Hardware". Press tuning knob in, bringing up contrast menu. Press tuning knob in, bringing up "contrast level". Turn tuning knob counter-clockwise to "00". Brightness, dimming level should be "170". Turn radio off to exit, then adjust "Dim" button to your liking.
Nov 02, 2008 | Boston Acoustics Recepter Clock Radio
Teac SR-L100 Clock Radio
There is button inside the CD chamber. Press it for a few seconds.
Aug 12, 2008 | Teac SRL200i/B Clock Radio
TEAC SRL100 Set clock
The "set time" button on my SR-L100 is located inside the CD compartment. To set the time the unit needs to be in the standby mode. Press and hold the set time button until the time blinks, then use the tuning/clock adj. dial to set it. Hope this helps! Ted
May 26, 2008 | Teac SRL50 Clock Radio
Alarm clock won't change time with daylight savings
unless it is an automatic , atomic clock none I have ever owned do the change automatically
Feb 27, 2017 | RCA Audio Players & Recorders
CD Music System Clock Radio SR-L100
Open CD Cover. In the left rear is the time set button. Depress it for at least 3 seconds and you will be in the time set mode. Use the "Skip" rotary knob to adjust the time.
Dec 25, 2007 | Audio Players & Recorders
Right clock time
Hold the memory button on the remote control, wait for the written "SYNC ON" on display and then press the track forward (one on the right with the double arrow).
Now normally set the clock.
Dec 02, 2007 | Teac SRL200i/B Clock Radio
Teac SRL50 Clock Radio Logo
219 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
