Question about Zenith DBZN-311 Remote Control
Problem programming Zenith Digital TV Converter DTT901 remote.
(The build for this product is September 2008). The Installation Guide (welcome screen, etc.) did not appear when I set up the converter box with an RCA TV. I managed to get the Zenith remote to turn on (and off) the TV, and to shift the converter box from standby (blue) to on (red). But none of the functions work, no menu appears when menu button is pressed, etc. My old remote still works with the TV to increase volume, etc., but none of the converter box commands work with the old TV remote (nor with the new Zenith converter box remote.) The picture seems improved by the converter box. But could you please tell me how I can program the new Zenith remote to control the new Zenith converter box? I would like to be able to access the menu, guide, etc. I tried using remote codes, but nothing accessed the converter box menu, channel scanner, etc. Your guidance would be appreciated. Thank you.
  • 1 more comment
  • shijyosho Nov 21, 2008
    Please note that the Product Number of the Zenith Digital TV Converter to which my inquiry refers is DTT901. The reference to DBZN-311 above was not supplied by me. I do not recognize that Product Number. Thank you. --Shijyosho.
  • roulleau Feb 03, 2009
    I have exactly the same problem. I've tried connecting with both the RF cable and the A/V input cables. (I've tried A/Vs only, RF only, or both at the same time.) Neither the menu nor the Install Guide will show up, whether the TV is set to channel 3, 4, Video 1, Video 2.... etc.
    Could this have something to do with my VCR/DVD setup? I have separate VCR and DVD players, which used to be linked to the TV through A/V inputs and the Antenna In cable.
    I could try re-routing the whole setup so that my A/V cords run from the Zenith converter into the DVD player, and from there into the TV. I have no idea if this will make a difference.
    I did try installing the converter before I had a digital antenna, and the Install Guide came up (but obviously couldn't locate any channels). I don't know why it would not want to appear now that there is an antenna connected.
    Help!
  • Anonymous Feb 28, 2009
    I had this problem initially. After reading the response above, I set the TV to Channel 3 and tried calling up the set-up menu. It took maybe 30 seconds to appear, but it came up and I'm now watching TV with the best resolution I've ever had. Note: the blue light on the converter has to be on.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Posted on Jan 17, 2009
Can I use my zenith TV tuner converter box model number dtt901 to watch my phone on TV
The Zenith DTT901 receives OTA (over-the-air) digital signals from TV stations and converts them to an analog signal to be used with an older analog television.
So the answer is no.
Nov 26, 2017 | Zenith Televison & Video
How do I program a Toshiba remote to a zenith converter box
Signal converter boxes are pretty easy to set up - ABC News
abcnews.go.com/Technology/AheadoftheCurve/story?id=5485537
Digital Switch: How to Set Up Your Converter Box. ... If you subscribe to cable, satellite or some other pay-TV service, you'll continue to receive programming. ... aToshiba TV in my kitchen: Magnavox's TB100MW9 and Zenith's DTT901. The boxes are simple enough to set up, though I prefer the Zenith's remote control and ...
Comcast Remote Codes ' Program Your Remote Control
https://customer.xfinity.com/remotes/
Help and support with your XFINITY® Remote, select your remote control type and get the support you need to enjoy your XFINITY® TV!
Zenith remote control code list - channel recovery morning ...
www.thompsontv.com/zcodes.html
Dec 15, 2015 | Zenith Televison & Video
Have a Zenith DTT901 converter box, need the remote codes for my zenith remote, thanks
Your Zenith remote should be able to control your Zenith DTV box. If not, your remote may not have the latest codes or it could be defective. You may have to try a newer programmable remote.
Dec 10, 2014 | Zenith Dtt901 Digital Tv Tuner Converter...
Where can I download a schematic for a Zenith dtt901 converter
Try the manufacturer's website and/or do a Google search using
" Zenith dtt901 manual pdf
Nov 08, 2014 | Zenith Dtt901 Digital Tv Tuner Converter...
Lost remote - moved to new state - need to have new rescan of local channels
You probably will have to get a replacement Zenith remote but there are some remotes available that can control your converter.
Aug 13, 2014 | Zenith Dtt901 Digital Tv Tuner Converter...
I have a DTT901 converter that I would like to control with my directv remote. What code would I use?
Unfortunately, there are no converter codes in the directv remotes.
Thank you.
PLEASE RATE ANSWER.
Jun 30, 2010 | Zenith Analog to Digital Audio Converter
There's no code for a Zenith DTT 901 to an RCA universal remote?
Hi.
Try this RCA code for Zenith -> 001
Regards...
/Tech5508
Feb 16, 2009 | Zenith DBZN-311 Remote Control
I am trying to find a universal remote code to control the new Zenith digital tv tuner converter box. The model # is DTT900. It is for a person with low vision who cannot see the buttons on the remote...
Pls post back with the brand and model of the universal (replacement) Remote Control or what remote control you would want to use with the Zenith DTT900 Digital-to-Analog Converter Box.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 23, 2008 | Televison & Video
Zenith DBZN-311 Remote Control Logo
3,836 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
