Question about ASUS P5RD1-VM Motherboard
Please help me to solve my problem, whenever i need to install window xp_sp 2,Mother board (P5RD1-VM) require sata drivers from floppy drive, so where from i got the sata driver on internet please solve this problem i am in big trouble.
  • 50 Answers
In the motherboard CD, there's an option to create a raid diskette on the tabs above.please help me - 29eb585.jpg
Posted on Dec 01, 2008
  • Ismail Shifau Dec 01, 2008
    and u can use nLite to insert Sata controller or any driver you want and create XP CD with the drivers. so u dont need the diskette anymore.
    also u can download the drivers from this link
I have an asus p5rd1-vm motherboard. I found problems on installing windows xp using sata hdd. Please help me to install windows xp2 as i am not using floppy drive.
The Windows installation CD does not have a SATA driver. You need a SATA driver of a floppy disk or turn off SATA native driver in the BIOS.
Please click on this link and follow my instructions on how to Install Windows on a SATA hard drive :-
http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
I suggest you install SP3 (service pack 3) rather than SP2, it contains the latest bug fixes. The SP3 cannot be installed from a floppy, it can be downloaded from Microsoft, it is a large file approx 300Mb, I suggest you install it from a CD if you can borrow one.
Aug 09, 2010 | ASUS P5RD1-VM Motherboard
Sata HDD NOT DETECTING IN XP SETUP
If you're using a scsi card and connecting the hard drive to the card you need to have the scsi set-up floppy disk. When the blue screen starts during windows installation watch the bottom of the screen. It will tell you to press F6 key then to insert the floppy disk.
If you're using a sata drive connected directly to the motherboard (not in a raid configuration) you shouldn't need anything but the windows disk. The motherboard drivers and utilities disk should have the files to create the scsi install disk.
Sep 11, 2009 | ASUS P5RD1-VM Motherboard
Hard disk is not detecting when I try to install windows 7
Hi
You should find the drivers you are looking for on the Asus website.
Here's the link to their download page,
http://support.asus.com/download/download.aspx?SLanguage=en-us
Hope that help,
MK Support
Mar 15, 2009 | ASUS P5RD1-VM Motherboard
Problem installing Windows XP with Asus P5RD1-VM series mothboard
Hi!
You need to copy the SATA drivers from the motherboard CD into a floppy diskette.
When you are booting with the windows xp installation CD you can see a message that says:
Press F6 for raid drivers
Press that key so windows installation CD look for the SATA drivers.
Jan 20, 2009 | Microsoft Windows XP Professional With...
Please help urgent
hi.......
u can download them from http://driverscollection.com/?C=71 and u can find ways to install the sata drivers without a floppy at http://www.tacktech.com/display.cfm?ttid=414
Nov 21, 2008 | ASUS P5RD1-VM Motherboard
Please help me to solve my problem, whenever i need to install window,Mother board (P5RD1-VM) require sata drivers from floppy drive and you know floppy is hard to find, or where from i get the floppy in...
use Nlight research this software in the net and you will find the answer works on laptops too the process is called slipstreaming. the process of witch you integrate the sata driver to the xp intallation disk to provide the necessary driver you required first download the driver you need then use Nlight to integrate the driver to the xp installation disk of course you will need another writable disk to accomplish this. thank you
How to install window XP without floppy disk on asus P5RD1-VM
Hi sheikhun, just ignore windows F6 to add special SATA drivers. Install windows, when finished use your Asus CD and install missing drivers from CD. Than run windows updates.
You should not have a problem, if while in your bios your SATA drive is shown in the main menu. Than check the Boot section of bios. The boot order should be.
CDROM drive 1st. SATA drive 2nd.
Disconnect any other hard drives data cable while installing windows. When you finish installing windows & installing the drivers from the CD & windows updates you can shut down the PC & reconnect the data cables you may have disconnected.
If your bios does not see your serial ATA SATA drive than your SATA onboard controller is defective. Return to Asus for replacement/repair.
Mike
Mar 30, 2008 | ASUS P5RD1-VM Motherboard
I can't use HDD sata on mainboard ASUS P5RD1-VM
Things need to be turned on in your bios patrohi. This is why windows didn't boot to the SATA. You need to use your manual & make sure the, Serial ATA Controller is [Enabled]
Within the Advanved menue under SouthBridge Configuration.
At the Main menue the SATA drive should be listed.
Boot settings need to change as well. At Boot Settings Configurations. Make sure your SATA drive is listed.
Boot order should list like, Floppy 1st, CDROM 2nd, SATA 3rd. The SATA will not list as a SATA but the model number of the SATA drive. Once all these settings are set save & exit. Your drive should show up for work & the windows CD should load.
Feb 20, 2008 | ASUS P5RD1-VM Motherboard
ASUS P5RD1-VM raid controller
1. put Motherboard Cd (come with p5rd1vm) in cd/dvd rom.
2. BIOS configur as boot from cdrom.
3. restart machin Motherboard CD boot with press enter
4. command line shows 4 option
5. Select 1st option for exact and proper copy ULi sata driver for winxp.
6. Insert floppy press enter
7.you see d copy procedure.
8.then this floopy insert when winxp setup asking F6 for additional driver.
Thank you.
YOGESH JADHAV
Sep 29, 2007 | ASUS P5RD1-VM Motherboard
ASUS P5RD1-VM Motherboard Logo
313 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
