Please help me to solve my problem, whenever i need to install window,Mother board (P5RD1-VM) require sata drivers from floppy drive and you know floppy is hard to find, or where from i get the sata driver in internet please solve this problem i am in big trouble. or where from i get the floppy in internet
Http://support.asus.com/faq/faq.aspx
Plenty of downloads available for your motherboard at ASUS.
You likely received a driver disk with the board however if you navigate through the downloads menu and enter your model and also read some of the faq pages you may find there is several others with same problem.
You must enter general search terms in the download area and specify product, series, and model info. I looked for the fun of it though I don't personally have that board specifically and found others with same problem! Try searching keyword in left menu area; search .... "sata driver".
You should then find the answer you wanted!
Hi.......
u can download them from http://driverscollection.com/?C=71 and u can find ways to install the sata drivers without a floppy at http://www.tacktech.com/display.cfm?ttid=414
SOURCE: how to install window XP without floppy disk on asus P5RD1-VM
dear mike,
I too face the same problem, here the window xp cdrom did not detect sata drive. but the bios detect sata and list the drive during bootup. since P5RD1 uses ali-chip set, I think only option is through floppy. we will not be able load the driver and update the system later because no drive exist if only sata drive is present. I do not know whether to say Asus motherboard is faulty. I have seen similar procedure for Ndiva boards also.
bye
Hemachandran.
[email protected]
SOURCE: please give me link for windows floppy
You can purchase an external floppy drive at www.tigerdirect.com
SOURCE: please help me
http://support.asus.com/download/download.aspx?SLanguage=en-us
Therre u find all nessesary drivers for your motherboad. You dont need to buy a floopy, use a usb-memmory-stick, it works to.
Never trust that XP for sure instaling all drivers needed for sata on any else divice on a pc, sometimes you have to instal drivers by you self to make sure that the divice working correct.
In the motherboard CD, there's an option to create a raid diskette on the tabs above.
