What kind a outputs transistor use
this power amp uses 2SA1962 and 2SC5242 output transistors. You can download the schematic diagram from this website.
Thanks.
gylacz
SOURCE: My QSC GX3 has a red light that turned on (on the
You should check the speaker set, maybe it's short circuit.
Try remove the speaker set from the unit, than switch on the amplifier again, if the red light still on, surely the final drive is damages( Transistors or IC's).
Replace it with new ones.
Normal indication: illuminates whenever the amplifier is driven beyond full power. The LED's brightness indicates the amount of distortion. Distortion that causes only brief flashing may not be audible.
During muting, the indicator fully illuminates. This occurs during normal "On-Off
