Question about Alpine MRA-F350 Car Audio Amplifier
Inconsistant Switching of Alpine MRA-F350 Amp
I have just installed an Alpine IVA-D106 to an Alpine MRA-F350 Amp in my Truck. I put an Audiovox XM radio box in line in the AI-Net input. I have switched the two little external switches as I should and the head unit will signal the amp to turn on at times and not at others. It will sometimes lock up the screen on the Alpine for a few minutes so that pushing any button does nothing. Other times the head unit will not turn on. Then when it is on I can wait a minute or two and the Amp will decide to turn on as it should. Other times everything works 100% as it should.
I have good Grounds, 8 Gauge Wire to the battery terminal, etc. I have tried all the settings inside the head unit.
Wondering if you have any ideas and if it sounds like I have a wiring problem, a bad head unit or a bad switch in the amp?
I have also tried powering everything off for 5 minutes and pushing in on the little main reset under the face plate.
Thanks
    Problem Solver:
  • 12 Answers
Try and unplug the audiovox unit and check if problems still exist. and what swithes on what unit are you talking about? this kind of sounds like a wiring problem.
Posted on Dec 10, 2008
IVA-D106 Car DVD Player: no picture on screen while dvd is playing...
Im guessing that if you can hear sound but have no picture and this is newly installed that your unit is wired to your parking brake as a safety feature. You need to disconnect it and connect the wire to the radio ground to bypass it.
May 18, 2010 | Alpine IVA-D106 Car DVD Player
Cannot access bluetooth menu in the Alpine iva-d106
To connect the iva-d106 with the kce-400bt you need another cable
(KWE-460V), and to connect the ipod you'll need the KCE-435IV, first you connect KCE-400bt to the IVA-D106 using the KWE-460V cable, then conect the ipod to the KCE-400bt using the KCE-435IV
May 15, 2010 | Alpine IVA-D106 Car DVD Player
Interface Question (Alpine IVA D106)
the way u have it formated on the ipod might have something to do with that.
Apr 20, 2010 | Alpine IVA-D106 Car DVD Player
Screen is blank on my Alpine IVA-D106 and menus, video etc only appear when I touch the screen. A few seconds after touching the display goes blank again.
check the screen configuration using the visual button on the top right side of the screen, you should disable the "OFF" button
Apr 16, 2010 | Alpine IVA-D106 Car DVD Player
Can you by pass the parking brake on the alpine iva-d106?
Yes you can you have to put power to that wire an you will need a switch a on off switch will work an when you put a dvd in you will have to filp the switch on an then off or of then on an it shold work have fun hope this will help you
May 07, 2009 | Alpine IVA-D310 Car DVD Player
No radio sound from my IVA-D310E
neither of those units use fibre optic cables! but it sounds like you puled out the antenna wire behind the head unit. if you try and search radio stations without the manual tune on and it keeps changing frequency on it and never stops then its the antenna plug.
Nov 13, 2008 | Alpine MRA-F350 Car Audio Amplifier
Hooking the mra-f350 to my highs
You will only need to connect the door speakers to the MRA-F350. In short, the connections will be as follows:
Deck---->MRA-F350 amp---->Door speakers
...................................\---->Sub amp---->Sub(s)
Just make sure you use the optical digital output of the deck to connect to the optical digital input of the MRA-F350 amp, not the RCA preamp connections.
Mar 13, 2008 | Alpine MRA-F350 Car Audio Amplifier
Alpine IVA-W205 XM not displaying in source menu
Alpine IVA W205, Red light on the bottom left of the screen and the radio & cd player does not work?
Jan 06, 2008 | Car Audio & Video
No sound from speakers after mra-f350 connected to alpine w205
Did you set the digital output to the on position on the bottom of the head unit?
You have to switch the head unit off then back on for it to recognize the position of the switch.
Oct 27, 2007 | Alpine MRA-F350 Car Audio Amplifier
Alpine mra-d-550 car audio amplifier
Sorry man here's what i pulled from the internet- Crutchfield sells these:
Note: The MRA-D550 requires a compatible head unit for setup and control, it cannot be used without one. The current list of compatible head units includes (but is not limited to): IVA-D300, IVA-D310, IVA-D900, IVA-D901, DVA-9860, and DVA-9965.
Oct 22, 2007 | Alpine MRA-D550 Car Audio Amplifier
Alpine MRA-F350 Car Audio Amplifier Logo
214 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
