My jvc AL-A151 spins records too slow but gets better
My JVC AL-A151 spins records too slow or varies speed. I put a new belt on it and thought this woud fix the problem. No luck. after a while it will finally catch up and play at the correct speed. ??? Thanks for any help with this. -Chuck
I had this problem. In my case it manifested itself mostly in start-up, and I found that I had to move the tonearm past the 1st track to get the TT to spin. I cleaned the contacts on the micro-switch (on the mechanism, from below) with extra-fine sandpaper. It worked.
Posted on Feb 09, 2011
I'm going through the same thing with my old JVC too, and I've concluded that the problem must b e in the drive motor. I too replaced the belt and it still plays slow in both the 33 and 45 RPM settings.I hate trying to fix a problem just by changing parts and I also hate paying for repairs when buying a new one is such a better solution. Good luck
Posted on Dec 18, 2008
AL-A1 turntable won t turn
take the platter & belt back off, then check to see if the motor spins, if it does the belts the wrong size or put on wrong, if it doesn't spin then you better get your butter & jam out, to put on your toast.
Jan 19, 2014 | JVC Audio Players & Recorders
JVC turntable AL-E300 turntable slowing down when tone arm moves iacross
Even if the belt looks fine it's almost certainly the problem. You mentioned "cleaning" - if you got any kind of fluid on the belt it might act as a lubricant and reduce the friction between the belt and the drive wheel, causing the turntable to slow when the tone arm puts a drag on it. The problem may go away when the belt dries out.
Nov 23, 2013 | Audio Players & Recorders
Jvc al a155 spins to fast. can i adjust that?
make sure first of all that your belt is riding on the drive pulley like it is supposed to do if this is good under your plate that u take off too replace the belt r two screws they will fine tune adjust your record speed on is for 33 other is for 45 should b marked which is which
Sep 19, 2013 | Audio Players & Recorders
What replacement stylus do I need for a JVC AL-A151 turntable?
Since it's possible to fit any cartridge in most turntables the answer is to look at the make and number of the cartridge installed into the arm of your turntable. Put that into Google and the stylus should come up.
Feb 22, 2013 | Audio Players & Recorders
JVC TD-W718 double tape deck capstan belt
Probably the wrong belt. It is also possible that your old belt had stretched and the machine was playing slow. Check with a recording of instrumental (not vocal) music.
If you have a little screwdriver you can adjust the motor's speed via the little hole on the back of the motor.
I suggest a plastic screwdriver so you don't short something out.
Using a tuning fork or electronic tuner or musical instrument will help you get the speed right.
Jun 07, 2012 | JVC Audio Players & Recorders
JVC L T11 turntable spins to fast jerry, rigged adapter
where can I get an 11V -13V DC adaptor to power JVC turntable AL-E300?
Feb 02, 2009 | JVC Audio Players & Recorders
JVC Turntable model AL A1 BKX , need to know how to adjust speed
I have just fixed this problem on my Aiwa PX3800 with improvisation.
The platter was rotating too slowly, I didn't know how much too slow only that the records sounded wrong.
I imagined the belt, motor and platter as a bicycle gear and so simply increased the gear... I achieved this by winding a thin strip of a electrical insulation tape around the motor head to increase it's radius (like changing up to a larger front cog on a bicycle gear).
I could then time the rotations and remove a layer or two of the tape accordingly until I have achieved a perfect 45rpm. 33 is still way out but I only listen to 45s!
Be sure to trim excess tape from the motor head with a craft knife/scalpel or it'll stick to the platter.
Poor man fix up.
Dec 17, 2008 | JVC AL A158BK Turntable
JVC AL-E300 Turntable
More than likely your motor might be bad. There is nothing else that controls the speed. Are you sure you purchased the correct size belt? Turn on the unit, without connecting the belt, and touch the motor shaft, and see if it fluctuates. You can also just get a marker, and marker a point on the motor shaft. When you turn it on, it will act as a visual indication as to it's speed.
- Davis
DJ Pro Audio
www.DJPROLAB.com
www.DJPROAUDIO.com
Aug 07, 2008 | Audio Players & Recorders
1,045 people viewed this question
 Grubhead
Grubhead
