Question about Samsung TXN3245FP 32" TV
No picture or sound
Went to move TV and snapped off the Video prong in the rear AV1 input. Couldn't get prong out, ended up pushing it all the way through (by accident). When I went to power it on, it popped (from input/output area), and now TV does not come on. When I apply power to it, standby power light comes on, but when I hit power button, standby power light goes out, but no picture or sound. Any suggestions. I'm not a tech. thanks
    Genius:
  • 1,074 Answers
Take you tv to tech you have damaged your microchip and component in the power supply
Posted on Mar 19, 2007
Scren went blank. We have sound but no picture .what do we neen to do to get pictute?
How is your TV receiving video? Are all cables connected? With RCA (the red, yellow, white ended cables) the yellow is the video, the white and red are left and right stereo sound. Ensure that all cables are connected into the correct spot on the back of the TV and that you are on the right input (Video 1, AV1, etc).
Mar 15, 2015 | Sanyo DP55441 55" LCD TV 1920x1080, 120...
My tv sanyo cm21kf81A, chassis number FC3-G221 has snow noise on all tv channels, but AV1 and AV2 play good sound
First check cable wire or whatever is connected to set for channels--the leads are connected and wiggle them with set on to see if it clears up--could be a connection where cable wire is connected at end--loose connection there etc.
If tuner is bad causing this and you use a box for signal--most have rear audio/video outputs you can connect to a unused video/audio input on rear of set---bypass the tuner in the set and operate set that way changing channels on box instead of set.
let me know if you have questions or have more information.
Mar 21, 2012 | Televison & Video
I have connected the audio optical cable from my TV, but I couldn't get the koss system to work. Are there any other settings need to be set? Which channel should i use to get the sound AV1 or AV2?
AV1 & AV2 are the Video Inputs from your external devices such as DVD Player, Freeview etc.
I presume you have something connected to your TV and want to get this sound from your TV to output through your Koss.
Their should be a menu to activate the Optical Input but I can't find the manual to advise the correct menu.
I'll keep looking for a manual so if you can't find the menu let me know and I'll see what I can do to guide you in the right direction.
Jul 25, 2011 | Koss KS5190 System
I was switching my ps3 from hdmi output to the red,yellow and white cords and after i accepted i switched my tv to av1 and there was picture and sound but it then asked me what format and i selected 1080p...
Easy to fix so don't worry ;)
While the PS3 is off (solid red led)
Hold down the power button until you hear the SECOND BEEP, quickly release.
This will reset the video settings back to default.
Feb 01, 2011 | Sony Playstation 3 (PS3) Console
I have picture but no sound LG flatron TV and Pioneer DVD player.
connect audio output (RCA Jack white n red color) from the video, to the audio input of your TV. Make sure you use same AV channel for the video and audio.
i.e AV1 or AV2 or AV3
Apr 10, 2010 | LG Flatron MW-30LZ10 30" LCD Monitor
I have my dvd player attached but don't know what channel to put the tv on so the picture from the dvd comes on and not just the sound
You should be using the Video input, you should have three cables hook up to one of the Video input,
Yellow for composite video, red for right channel sound input, white for left channel sound input, then select AV1 or AV2 depend on which one you choose.
Oct 30, 2009 | Philips 19PFL3504D 19 in. LCD TV
Im trying to hook up my new lcd tv using a cable box and a dvd player but cant find any diagrams. As of now I can get a picture but the sound is low and can only be turned up by the cable remote. Any help...
it should not be a big deal red and white is sound yellow is video, if you have a converter box and are not getting a signal I would suggest you try moving your antene to get picture. Try hooking the DVD plaer into the TV to AUX 1 or AV1 or AV 2 Or AV3 and make sure the TV is on the right channel on to see Picture and correct level of sound, are you running anything threw a coverter box? Need to know the TV brand to do a diagram. The output from the DVD player shoud go into AV1 and the wire colors should be the same DVD output to AV1 input or AV2 in?
Jul 06, 2009 | Televison & Video
Sound but no picture on PS3 using AV3/4
the best configuration is using component AudioVideo cable.component video out from ps3 use 3 wires going to component video input to your tv (Y-Pb-Pr) and two wires for audio left.right. use av1 input on your tv to hook the audio and video. let me know if you still have issue.
Apr 05, 2009 | Philips Televison & Video
Hi i cant get no sound other than frying inmt rear left and right spearkerall the other is working
YES check your connections and make sure you have selected the right INPUT signal source on your surround sound just remember RCA cables (yellow red white) goes from digital box,CABLE or SATELLITE OUTput to surround INput from there connect another RCA cable from the OUTPUT of the surround sound to the AV1 Input on the TV make sure AV1 is selected on the TV,if you dont know how just put the TV on channel 3 then press the channels down button and when the TV gets to channel 1 the next channel down from that should be AV1.Also make sure you have selected the right INPUT for the surround sound.
If you are not using RCA jack and just coax follow or you dont have a digital box.Connect the cable from the wall to the INput
on the surround sound the the cable OUT to the tv make sure the surround sound is Looking for a signal from the coax.
Nov 03, 2007 | Audio Players & Recorders
My Screen Said "Are You Sure" and "Please Wait" and now, instead of "AV", i have "AV1" and "AV2" and my tv wont show picture from the dvd player OR vcr
You will need to go back into the menu and see what ia available in the video input mode. You may have switched the type of input you can use such as default or componts ect. If you have an isntruction manual, look in there or call the manufacturer, should also be in the instruction or user manual. Good Luck
Mar 28, 2007 | Spectra KT2114 Television
Samsung TXN3245FP 32" TV Logo
47 people viewed this question
Demonic-2011
Demonic-2011
Steve Allison
Steve Allison
