Marvell 885E61xx BIOS V.1.1.0.L69 IDE adapter
Hi WV, sorry to bother you again so soon, I have a couple more probs to straighten out before I can call this computer the PC of my dreams! (Hope you can help me).....
The Marvell IDE adapter on my mobo (ASUS p5q se/r, c2d E8500, 2x2g 800 RAM) takes over a minute to detect my IDE drive during boot up, and after looking around the net for some answers all I could come up with is "Ensure if the drive is on its own cable, that it is set to master", I checked that, and I already had master set... so I moved it to the end of the cable (no difference). Ive currently got 2x500g Western Digital SATA's, and my old 250g WD IDE, and ASUS DVD drive.
I was considering getting an IDE to SATA adapter, but I'm not sure if I do will the mobo then consider the drive an IDE or sata? (I know I wont get much if any speed boost, but if it became SATA at least I could turn off the Marvell?)
Or should I just send it to HDD heaven, and cut my losses? (I've got a few from my old PC, not sure if I should incorporate them into this or copy what I need and file them under my bed)
Oh, and I got Far Cry 2 - looks great but I havent really played it yet. I benched it at all optimal settings and got 24FPS - running my system stock. (Is that ok? I dont really know what FPS I should aim for) It looked awesome to me! (Actually made me wonder why I ever bought PS3, except for COD4) Question: Would increasing my RAM from 4g to 8 make any difference to my machine? (4x2g 800s)
Anyway, your suggestions would be a great help to me, hope to hear from you soon.
ADS
  • 2 more comments
  • findads Nov 21, 2008
    Thanks for your response WV, the DVD is SATA(new), and at this point I have 500g system HDD in SATA 1, 500g spare in SATA 3 and DVD multi in SATA 5. I wasn't sure if SATA 1 shared a channel with 2, 3 with 4, 5 with 6.... so I seperated them (This PC is my first experience with Sata), but in regard to the IDE, its pretty much new and transfers data fast enough to be usefull still.... but I cant figure out why the delay in booting... I might pull them all out tomorrow and see if I made a mistake somewhere...will let you know...
    Thanks WV, I'll try removing SMART first and go from there. When you say write zero's to the drive.... do you mean format it? I dont know the speed; never looked and pulled the stickers off yesterday thinking it would look better! (I'm now thinking that may not have been the brightest idea I've had.) And please don't let me keep you up... I'll hear from you when I hear from you! Thanks again. ADS
  • findads Nov 23, 2008
    Hey WV, hope you had a good trip. I don't seem to be able to turn smart on or off on this mobo, which I find strange considering my ancient ecs mobo had that option (if not many others!). I'd better take another look at my BIOS, but I don't recall any drive spin up or accoustics options....
    Cool WD.... I'll give that a try.... thanks! I've got ultimate boot CD and spotmau..... will they do the same job, or do you advise hirens?
    Guru:
  • 859 Answers
You have your Asus DVD on the same cable as your WD IDE Drive? Is the DVD a DVD ROM or DVD ROM and CDRW, or is it a DVD Multidisc? An old DVD ROM could slow down your WD HD by riding on the same cable. I wouldn't pin these other than CS and put the HD in the middle or slave port and your DVD on the end. Turn SMART monitoring off in your system. This slows down spin up and mounting of your HDs. Puting your HD in the middle as Slave gives the data the shortest distance to travel to the MD where the system BIOS is better off deciding what is master and what is slave by position on the cable. And what is master and what is slave is of little significance anymore. Most System BIOS utilities allow you to instruct the BIOS what drive to boot from anymore.
You *could* use the IDE to SATA adapter and port it on a SATA cable. It would still only transfer at around 60MBs and over 100 on burst. But it could still take time to recognize. Some drives have a spinup delay to prevent shock to the motor believe it or not. WD HD utilities do not allow you to change spin up delays. If yours was built with a delay its probably because of a test result at the factory.
You could designate your OLD 250 as a backup drive and put it in an external enclosure that connects via USB. Thereafter just go with SATA drives. Same thing for the DVD writer if you really want to rip DVDs.
Another viable option, but slows down your bootup speeds is an add in IDE adapter card. These are notoriously slow, but I use them for extra DVD writers in one of my PCs where I have four of these. I have kids and grand children so we share amongst ourselves alot and I do pro bono work for families with Autistic children. When they get a DVD I'll make several backups for them so the children can abuse the Movie DVDs I make and not the original copy.
BTW, USB 3.0 is due out next Spring. At that time you'll want to put one of these new USB 3.0 cards in a PCIe 2.0 slot. USB 3.0 will transfer at 1.5GBs. So, if you're holding off on an external backup drive, these should be forward compatible with USB 3.0 or take a firmware upgrade instead.
And don't forget your 250 may be about to croke and this may be why the BIOS is having trouble reading the phyical characteristics of your drive and energizing it so its ready for use.
As to sending it off to Hospice, yeah sure Avoid all this hassle and get another SATA such as a 1.5T.
Hopet that helps you out but let me know if I've only managed to confuse you; its late. And I'll be on the road all day tomorrow (oh boy).
Worldvet
Posted on Nov 21, 2008
  • 3 more comments
  • Glenn Rogers
    Glenn Rogers Nov 21, 2008
    I wouldn't pull them all out myself. I would turn of SMART monitoring for the IDE drive if its on already, otherwise, you are right there is something wrong there.
    I'll be out of town tomorrow but keep me up to speed on what you do do. I've been through this myself, but its been awhile and I'm pretty sure I either turned off SMART or had WD write zeros to the drive and start over.
    Is the HD 7200 with 8 or 16 MB of cache.
    WV
  • Glenn Rogers
    Glenn Rogers Nov 23, 2008
    What were the results once you disabled SMART monitoring, any?
    On your SATA drives, it makes no difference on what number port you plug into. You don't have to worry about shared channels with these things. The motherboards today that support SATA have a smart enough southbridge to handle the traffic. A PCI slot is a bit different, where as PCIe is on a different bus and is handled entirely different.
    I'd just check the WD tools that you can boot from and turn off acoustics management and any spin up delay, if any.
    WV
  • Glenn Rogers
    If for some reason you don't see the option in your Bios, I guess its possible. Go find and download a copy of Hirens BootCD iso from one of the usual GET IT file sites, I hope you understand that clue.
    Bootup from Hirens, and choose Hard Drives and there are several tools in there including one to turn off SMART and disable acoustic management. I know WD rarely used and may not have implemented that still, but the Hiren's CD may have some other clues and tests you can run on this HD that can help you out.
  • Glenn Rogers
    Because I've worked with Hiren's for so long, I've never given Ultimate Boot CD a try, but it should have the same tool set.
    I mostly work with Seagate drives because of the OEM warranty but I do have a WD Raptop and I'm looking at their new 500GB for my laptop as its only two platters thick, so it creates less heat and draws less power.
    You can fill me in on anything it has to offer out of the ordinary stuff WD will let you download. Its the hack programs that you can get to do the job. I don't know of any one program that will adjust accoustic management in a WD as I don't think they ever went for that sillines.
    WV
    Keep me posted.
  • Glenn Rogers
    Glenn Rogers Dec 10, 2008
    How did you make out with your HD and its slow to recognize and spin up time?
    Looking over SATA drives lately myself, I think I'd dump the IDE drive and get another SATA drive if you want. The over the 1TB drive prices are falling like rocks.
I have an old 40gig ibm apple hd
You wouldn't be able to use it as a primary drive in a laptop, you could in a desktop, but you would require and IDE to SATA adapter. But even then, I still wouldn't bother because the drive would be too slow.
You would be able to use it as external storage via the means of an IDE to USB cable. It still wouldn't be as quick at accessing data as today's modern external storage devices, so again that's why I wouldn't bother. But you could if you really wanted to.
Dec 24, 2012 | Dell Computers & Internet
Some keys didnot work. num and litters
First, try to find out if the issue is related with the hardware or software..
1. go to BIOS
2. press the alphabets which are not working (if you get beep the prob is related with software if not the prob is with hardware)
----------if its hardware related------
1. power drain by removing ac adapter, battery n other accesories connectd
2. go to BIOS n set it to BIOS default
3. check if its working in BIOS page which are not working in the desktop screen(if its not working, the prob is related with the hardware issue. it has to be given for service
--if the prob is related with the software--
2. do system restore (all programs -> accessories -> system tools -> system restore)
3. try BIOS default
4. Update BIOS
5. Uninstall the drivers
6. restart
7.try system recovery
(if it doesn't work, its to be given for service)
let me know if it works
Jun 16, 2011 | Toshiba Satellite A40 Keyboard
Hi i my computer suddenly started to shutdown and turn on again after a fev seconds.some times it goes in to windows but soon after crashes.it has wrked for over a year and this was a home built...
Try these....
Overheating problem in your PROCESSOR!
Check the temp in your BiOS and the setting of your processor!
Check also the power supply and upgrade it to hifgher wattage!
Clean your processor HEAT SiNK, dust and dirt might have acumulated!
Check the HEAT sink position, if its flatly fitted on top of procie, and scrape the old silicon paste between ur proci and heat sink and put a NEW ONE!
Encountered this kind of prob.. the prob is in the PSU unit(Power Supply Unit)!
These might help you!
Nov 07, 2010 | ASUS P5QL PRO Motherboard
8 days ago I purchased Intel dg45id mobo/core2duo proc/2-ddr2 4gb mem & 600w pwr. I then had to get an adapter for monitor(vga to DV1-1) & a IDE controller PCI card to use my CD & DVD burners....
I'm sorry but I would give up. You could buy a SATA to IDE converter, SATA disks, or use USB to IDE. You could buy PCI express cards for the display or IDE or buy a monitor with HDMI input. All these options are going to cost more than the motherboard. If you want to keep it bite the bullet and buy a monitor with HDMI (hp do some reasonable ones) and at some point then replace your discs with SATA
Aug 21, 2009 | Intel D102GGC2 Motherboard
Asus P5Q Upgrade disk error
take the cabel from the dvd out...and try to start igen.
Or try to fixboot with your windows cd...
Apr 11, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
Zebra 2824 red light
Hold the feed button while turning on the printer. After a config label prints, turn the printer off and then on again, and try printing again.
Also, make sure the lid is closed far enough to engage the lid sensor. If the red light comes on again, press down a bit on the lid, hit the feed button and try to print again.
Sep 03, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Packard bell easynote laptop model no mv35-202just keeps coming up with auto detecting ide please wait but just hangs there for hours & does nothing even with anew hard drive
Probably the controller card (built into the mother board) so you might be out of luck..
couple of possibilities, sometimes you can add the hard drive details into bios manually, the other is, do you have the motherboard software? Loading the correct drivers might help.
Apr 27, 2008 | Computers & Internet
Apparent conflict between my wireless adapter and RAM
have you tried looking for an updated bios version for your motherboard?
Jan 05, 2008 | Computers & Internet
ECS N2400-A (V1.0), Power LED = Not Lit (!Lit) , IDE LED = Lit
the most common way of programming bios that i know of now is through a fire wire or USB port you can buy the program that sets you up to do this at any major computer store. i use a server with the program and set all the machines i build with all the bios info from start up - to user executes application. and i establish a custom POST set up . you are right its nothing to be afriad of you just need the tools.
Dec 16, 2007 | EliteGroup N2U400-A Motherboard
ECS GeForce6100SM-M Onboard Network Adapter does not show up in windows???
I had the same problem. Tyr this.. Install windows x64 1st install the ide driver (it's a setup program) reboot 2nd go to device manager, you will see a PCI bridge device, update that driver to the lan driver on the cd. reboot Then install the rest of the drivers. If you don't do it in that order you will NEVER be able to install the Lan driver without reinstalling windows.
Aug 11, 2007 | EliteGroup GeForce 6100SM-M Motherboard
Computers & Internet Logo
2,204 people viewed this question
David Payne
David Payne
