Question about Kodak EASYSHARE 5100 All-In-One Printer
Printer cartridge for Kodak 5100 in India
Can anyone help me. I have a Kodak 5100 AIO printer bought from UK. Now the Ink cartridge has run out and I wish to buy new cartridges, but they are not available from Kodak in India (Checked their site for cartridges - none available). Can someone tell me from where I can buy the catriages for this printer (in Delhi or surrounding area) or tell me any other compatible cartridges for this printer from other vendor (HP etc.)
Regards,
AK
  • 40 Answers
Hello akpunj,
So far, there are no other ink cartridges that might be compatible with the Kodak printers, and even if you refilled the ink cartridge, it wouldn't help because of the smart chip they have.
Honestly, I think your best shot is to find somewhere else where kodak is selling this printers and where it will be cheaper for you to have them sent in.
Posted on Nov 25, 2008
Same on kodak...
Just try cleaning the printhead using the AIO home center program and i'm sure you would be able to restore good print quality again
Sep 27, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
When printing out photos they come with excess ink on them
update the kodak aio home center software on ur computer. open printer accesss door and take out both ink cartridges and then remove printhead. go to www.kodak.com/go/printheadsupport on how to take out and install printhead again. install both ink cartridges . open home center,click on ? @ top right hans side .after clicking on question mark choose maintenance and then choose clean printhead. issue will be resolved. contact kodak@ 1800 421 6699 if u have same problem
Jul 25, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 aio; banding/streaking problem
You will need a new printhead. If its not under waranty good luck trying to find one.
Jul 11, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Ink level will not reset when cartridge is replaced
If you take the cartridge to walgreens, etc... they can clear the chip. There is none for home use
give them a call !
May 10, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Prints only pictures and not text
Run the printer maintenance program and clean the printhead. If that doesn't fix the problem, contact Kodak support. If needed, they will exchange the printhead for a new one.
Feb 03, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Our Kodak 5100 printer will not stop a red light flashing on ink
How often do you use the printer? I have the same problems with a Kodak AIO 5500. Go to the "Help Center" section of the Kodak.com website. This will lead you through troubleshooting and if the printhead is bad they should send you a new one under warranty. This is what I did.
Feb 02, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 AIO won't print after cartridge change
the red blinking light indicates that your printer wont recognize your ink carthridge. you can try to reseat the carthridge and the printhead. to remove the printhead just press on the release tab which is located on the upper left corner of the printhead wall. If this will not correct the issue, you need to call their technical support hotline. maybe the carthridge is faulty or there is a problem on the printhead. their hotline no is 1 800 421 6699
Jan 08, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Help
Sorry to hear about your problems. Here are the steps Kodak AiO Support will ask you to perform.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Jul 23, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
New ink cartridge for Kodak Easy Share 5300 will not work
The version of firmware you originally had on the printer when you changed the ink cartridge was bad. There is a known issue that when you put in a new ink cartridge when the printer is in the error state "COLOR INK EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the new ink cartridge so you will continue to have that error.
So to fix your problem Open the access door and Remove the ink cartridges. Then download and install the new Firmware. Heres the link.
Kodak AiO 5300 Firmware
Then sadly you have to go get another new ink tank and install it.
If you can get through to kodak you should request reimbursement of some sort like a free set of ink tanks.
I hope this helps
Mar 09, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
