Back to:
Tags:
Samsung HCL4715W 47 in. Rear Projection Television
Samsung TV Repair (by 3 users)
By Odud - usenet poster
Have a Samsung 47"TV about 1 1/2  years old. Picture is bent like
"Cinemacope" TV and colors are all askew. Able to make Red move for
convergence, but Blue will not move to correct the problem. TheModel No.
is HCL4715W and have been told that the set needs a Convergence
IT-1CSTK392040. Cost to repair $350. As a 77 yr. old retiree, that is a
major investment that I can ill afford.
Any advice?
Carl
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Dec 15, 2007
feK.....the T.V. is displaying different colors that are bent like the Cinema pIcture......
Comment by Guest, posted on Dec 13, 2007
i have the same problem with blue lines
Best Solution
posted on Sep 24, 2007
Helpful (85)
Terryfic
Rank:Guru Guru
Rating: 87%, 1397 votes
Both IC's should be replaced by a professional,
also check the pico fuses hiding under heatsink.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Samsung TV Repair:
I don't want to Accept this solution
Solution #2
posted on Aug 07, 2005
Not Rated (0)
Mini Me
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
"Dr.Z" <CARLU @webtv.net> wrote
I think maybe he thought you went inside the cabinet and started twisting
and turning stuff. I assume you just did the "remote thing" with checking
the stuff out.
You may have to have it checked out, but check with several different places
(if you can find one!) and see if anyone makes "house calls". Sometimes it's
cheaper (believe it or not) to have them come out PLUS it's a lot less
hassle than you hauling it into a shop, wait a while, then hauling it back
home again.
Good luck....
Thank You!
Solution #3
Not Rated (0)
Cornish
Rating: 0%, 0 votes
Jim Yanik's response is not at all helpful and is somewhat abrasive.
I did exactly what the owner's instructions recommended, and nothing
more. Nothing was "screwed up" and the problem appears to be a defective
part.
However, I am grateful for the other responses, which are very helpful.
Thank You!
Solution #4
Not Rated (0)
Brad
Rating: 0%, 0 votes
On Sun, 3 Oct 2004 00:30:57 +0000 (UTC), Jim Yanik <jya @abuse.gov>
wrote:
I wouldn't be too hard on a enthusiastic handyman.  That's how I
learn't a lot about repairing many things including TVs.  The trick is
to be able to return to the setting with the original problem if the
tweak doesn't work.  Then try some other tweak.
The OP's problem is probably the degausser circuit not working.  There
is a thermister and a relay involved.  Beyond that try the
< sci.electronics.repair  >  newsgroup.
Thank You!
Solution #5
Not Rated (0)
Green1
Rating: 0%, 0 votes
Someone named CARLU @webtv.net (Dr.Z)  Proclaimed on Sat, 2 Oct 2004
16:25:03 -0600,
Try:
http://www.samsungparts.com/cu stomerservices/info_request.as p
or:
1-800-627-4368
To ask about that part.
-Graham
Remove the 'snails' from my email
Thank You!
Solution #6
Not Rated (0)
Bouncy
Rating: 0%, 0 votes
I don't have a clue.  There is a TV repair newsgroup if you don't get an
answer here.
Thank You!
Solution #7
Not Rated (0)
Charlie
Rating: 0%, 0 votes
Try to find the source of part needed and see if you can replace it
yourself(delicate soldering)
Tony, VE6CGX
(retired EE)
Thank You!
Solution #8
Not Rated (0)
Ranny
Rating: 0%, 0 votes
Try posting to sci.electronics.repair
Thank You!
Solution #9
Not Rated (0)
Pasty
Rating: 0%, 0 votes
CARLU @webtv.net (Dr.Z) wrote in
3217.bay.webtv.net:
Well,you should have posted to sci.electronics.repair BEFORE you screwed
with the purity and convergence.
Now,your best bet is to take it to a shop and pay the price or buy a new
TV.
Jim Yanik
jyanik-at-kua.net
Thank You!
Can you Help with these Projection Televisions problems?
Samsung HCL4715W 47 in. Rear Projection...
The tv was on and working fine. It just shut down, but not...
hey slinte, on both sides of the screen the picture has a...
my friend is selling the above listed tv the problem is...
My TV keeps shuting off and I was told that is it the DMD...
My television is connected as follows: Cable from wall...
Loading problems.
Repair Service
Find Projection TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
