Question about RCA RS2005 CD Shelf System
How do i reset my rca stereo?
I tried to use my stereo, i was going to listen to a cd but it said it was reading it then it said reset. i lost my manual so i need help on trying to reset it. its a rs 2005 model. a 3-cd disk changer, cassette player, with a control panel.
SOURCE: stereo won't read cds
You might try running a cleaning CD in it (which cleans the lazer lens). These are available from Wal Mart and many other sources. If a cleaning doesn't get it going, then you may have a lazer that is weakening and might need to be replaced (sorry!). Hope just a good lens cleaning will do the trick.
Posted on Jan 10, 2007
SOURCE: buzzing noise
There was a possible solution to a buzzing problem posted on here earlier. Mine buzzes, whirs and whines because of a defective cooling fan. No solution other than to spend $150 to fix or buy a new system for the same price (NOT RCA).
Posted on Oct 25, 2007
  • 3 Answers
I had the same problem with mine and the fix for it was to replace the Q401 transistor on the main board. I used a NTE382
replacement and has worked fine ever since.
Hope this helps
Posted on Nov 17, 2007
SOURCE: 5 CD Changer won't work
my rca 5 cd changer skips on all cd's?
Posted on Oct 07, 2008
rscheutz
  • 54 Answers
SOURCE: RCA RP-9515 stereo, CD player won't play
RD probably stands for "Reading Disc" and ND probably stands for "No Disc". If the CD player doesn't recognize any discs, then either the laser is dead or the motor has died. MOst likely you will have to replace the unit.
Posted on Mar 22, 2009
How to connect speakers to RCA model #RP-8070D
This unit is just a 5 disc CD player and cannot drive large speakers all by itself. Normally it is hooked up to a stereo receiver / amplifier which is what provides the power to drive the speakers which are wired to the back of the stereo amplifier.
If you have a home stereo, then just run the cables from the 2 AUDIO OUT connectors on the back of your CD player to the CD IN connectors on the back of your stereo.
Then turn your stereo on and select CD on your stereo input mode selector and you should be able to play the cds on your RCA and hear them through the stereo speakers.
If you do not have a stereo amplifier with speakers to connect it to, then you can always listen to it through headphones connected to the headphone jack.
Or if you have a set of self powered amplified speakers, like the kind you hook up to a computer, then you can run the AUDIO OUT cable from your cd player into those as well.
Good luck.
Apr 14, 2011 | RCA Audio Players & Recorders
I have a cd stuck in my car stereo and i tried pulling the fuse, that did not work, it does not even read that there is a disc in the stereo, i cannot find the pin hole to use the paperclip with? do i have...
Had a CD stuck in my Lexus for a year. Got my battery replaced and voila - the next time I turned on the CD player, the long lost stuck CD popped right out!! Must have been one of those reset features where you ahve to totally disconnect power from a component to alloww it to reset. Worth a try anyway.
Apr 12, 2010 | 2006 Hyundai Elantra
CDX-GT710 CD/Front panel will not move
I called the manufacturer who privides FREE instant support 24 hours a day and doesn't try to sign me up for memberships.
Jul 10, 2009 | Sony CDX-GT710 CD Player
My RCA stereo(RS 2620) will not read discs...
it might be the steiro cant read the disk because the cd is scratched or maby it cant read the cd cuz if you put the songs on a cd it might not read hope this helps!!!!
Jun 03, 2009 | RCA RS2620 Single Cassette Deck
Mar 22, 2009 | RCA 100-Watt Stereo System With 5-CD...
Not reading CD
The optical CD reading mechanism needs to be changed, take it to a repair center. These parts are not user-replaceable.
May 05, 2008 | RCA RS2056 Shelf System
HOOK UP
Hi there!
If using an RF Converter you will have to tune whatever you connect to it onto UHF Bandwidth until it locks. You would tune it like you would tune any other station. So as an example tune a tv station onto CH1 and the DVD onto CH2 etc. Regards and good luck. JUS004
Apr 01, 2008 | Televison & Video
No Disc error, won't read any CD
rca does not sell just the laser it sells the base assy. it consistos of the laser & the spindle motor on the metal base. no circuit boards, thoes you will need to remove off of the old one. the list price from rca is $136.10 CDN. replacing the part is not too hard, but take a little time. good luck.
Feb 13, 2007 | RCA RS2501 Shelf System
Stereo won't read cds
Jan 09, 2007 | RCA RS2652 Shelf System
RCA RS2005 CD Shelf System Logo
141 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
