Question about Panasonic Televison & Video
The cooling fan is not working on my dvd player
  • tadhg0307 Nov 21, 2008
    Can you provide details of repair person in Christchurch, NZ
  • tadhg0307 Nov 22, 2008
    The fan spins ok, no resistance. When I turn unit on it has a process of checking the player/recorder before it switches itself on. Checking system starts when power is switched on, but it just loops to startup so doesn't get to end of process, and power doesn't start the unit. It's not something covered in the troubleshooting section of manual. So I think I need to take to service agent but warrenty is out of date so may be costly. Thanks for suggestion,
  • 98 Answers
Panasonic Fans on Burners are not always on they are temp. set meaning when the temp. reaches a certain heat index fan kicks on now you may open the unit and manually turn the fan if it has resistance or a scratching noise then the bearings might have dried and needs fan replaced
Posted on Nov 22, 2008
DVD just locks up after about an hour of play
The DVD Player is overheating, dont have other hot machines under it, let it cool down naturaly and whatever you do, DON'T try to cool it quickly with a fan or vacuum cleaner becasue the fast temperature change will crack the internal components.
Nov 24, 2011 | Samsung Televison & Video
I have noticed that the cooling fan does not work on my bdp-S350 and am wondering if it only works depending on temperature, would greatly appreciate your help, thanking you in advance. Austin Donnelly,...
The cooling fan on your BDP-S350 should work all the time, because the system gets very hot in just a few minutes. Try playing a Blu Ray disc with the volume down, with in 10 minutes the fan should start running if not you have a defective fan or control electronics. Try spinning the blade of the fan when its on with a non conductive material ( tooth pick ).
But if the fan starts running with in 10 minutes of the movie ( Bluray ) all is OK and your system has a thermal sensor built in. Its done to prevent you hearing the wind noise during a quite passage of a movie ( some find it annoying ).
Mar 28, 2011 | Sony BDP-S350 Blu-Ray Player
Fan is not working, DVD player got so hot it stoped working.
replace the fan and dvd driver if the motherboard is not already fried
Sep 03, 2010 | Compaq Presario Fan
Combo panasonic es40v cooling fan alwais on ?
Most of these units are a always on sitaution. Accept for TV's witch are temp controlled.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 09, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Princess dvd player making grinding noise(Won't play the disk)
It is the problem of the cooling fan in your player .Provide lubrication
Dec 03, 2008 | Disney Princess MCP DVD2050P DVD Player
Heat
PLACE A 12 VOLT CAR FAN OVER IT
Sep 16, 2008 | Farenheit DVD-36 Car DVD Player
Cooling fan in reciever noise.
Its necessary to run cooling fan because Amplifiers in home theater system produce heat during its operation. If you shut down cooling fan, Amplifier ICs may be damaged due to over heat.
Aug 24, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Panasonic DMR-E55EB cooling fan appears not to work
The fan is thermostatically controlled - it only works when the unit gets hot. The hotter it gets, the faster the fan spins.
Apr 30, 2008 | Televison & Video
After Recording
Unit sounds like it has a small cooling fan at the rear. A bad fan bearing will produce a noise when dried-out. Replace the cooling fan.
Jun 23, 2007 | LG DR-4912 DVD Recorder
Open Questions:
Televison & Video Logo
189 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
