Question about Microwave Ovens
It s not working at all.
Key pad not working and light does not on.i buy that 8 months ago.it was working good.but i don,t know what happen.
  • fouzia_rizwa Nov 23, 2008
    hi , i did that what u said but its not working
  • Microwave Ovens Master
  • 9,086 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Please reply back with your brand and model number so we can help you.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Posted on Nov 21, 2008
  • William Miller
    William Miller Nov 23, 2008
    Usually it's best to wait until we're finished with a thread before you give a rating.
    Since
My oven heated fine 2 days ago and the kids tried to heat some sandwichs last night and it didnt heat. The table turns, clock counted down and power setting on level 10. I boiled water this morning to...
after several reviews of this microwave i have found that most people are not satisfied with the model or the company. And that it seems that your problem may consist with the magnetron not being installed correctly sometimes this happens at the factory but can only be replaced by a technician. they are supposed to carry them on their truck at all times. Youll have to call GE and schedule an appt with a tech. and from other testimonies that can prove to be difficult. sorry i couldnt have been of more help and good luck
Jan 25, 2011 | GE JVM1850 1000 Watts Microwave Oven
I plug in my microwave and it works for a few minutes then a error message reads key pad shorted the model number is jvm1740dm1bb
That is the worst microwave that you can buy. GE give you 1 year warranty, after that they send you a maintanence plan $50/month. They change mine 3 TIMES during the warranty period, after that works for 6 months and brake again. Always the problem was the KeyPad. The guy that they sent never told me a real reason for that, so I think is manufacturing defect. I put my GE JVM1740DM1BB to the trash.DO NOT BUY GE AGAIN
Dec 15, 2010 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
I own a GE over the range microwave, model #HVM1540DN1BB The touch panel doesn't work at all. I can't even set the clock. I even umplugged it for a couple of DAYS, and still nothing. I called GE, and they...
This model from GE is a ****..they replaced the keypad once wihtin first 2 months..now just after warranty..same issue again. Never buy GE products. The replacement key bad is $44+shipping in many onlne parts store..I am giving it one more try..next time this happens..GE will be out my door!!
Dec 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The key pad doesnt work, had it less than a year. Unplugged and then plugged it back in and it tells me to set the clock but when i push the buttons nothing happens. The key pad isnt locked already tried...
The panel may have a short or need to be tested for replacement. You should try and leave unplugged for 8 hours so power supply can fully drain power and reset microwave
Aug 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How to fix
replace the touch key pad. it has failed.
If this is an integrated control design, you will need to replace the control board as well. some board designs link the control and key pad as one device.
Jun 19, 2009 | Panasonic NN-P794SF Microwave Oven
Key pad does not work
Take the housing cover off and check the little cylinder glass on-board fuse.
Sep 18, 2017 | Samsung MW7490 Microwave Oven
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
Buttons including light, cook time, etc will work infrequently
Good news, even though the electronic controls (circuit boards) are different, the touch pads for the two units are the same. As far as the nomenclature behind the model numbers/letters, this information is rarely known or needed.
Please take the time to give this solution a fix ya rating.
Below are some applicable links for you for future reference.
clarkco
owners manual/parts list for MH6150XMT
owners manual/parts list for MH6140XK
Feb 09, 2009 | Whirlpool MH7140XF Microwave Oven
Erratic keypad
It must be dissassembed Clean both surfaces (pad bottom surface and board up surface so they would have good contact) with alcohol solution liquid sweep and let them be dry. Next assemble it again and test it. if START KEY persit not working even if it is clean, a small leaf of aluminium must be stuck at the pad bottom of START KEY. Be sure you can carry out this procedure well done otherwise you 'll need to buy another keypad. Good Luck!
Jan 05, 2008 | Kenmore 63672 Convection/Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
