Question about Sharp R-1480 Microwave Oven
Oven makes operating noise when doo is closed without starting
When closing oven door the microwave appears to turn on automatically. The light stays on however the turntable does not rotate and the oven fails to heat. Other touch pad features to include stop/start button are inoperable. Have to unplug oven to cease malfunctioning operation. This is sharp Microwave # r-1460.
  • Anonymous Mar 18, 2014
    Door ceased to lock shut, functions still light up but without door closed, microwave will not operate....
  • Sharp Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
The best place to order Sharp parts is Tritronics. You can call them at 866-779-5835.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Nov 21, 2008
My LG microwave will not shut off. When not in cooking mode and I close the door, the light stays on, it makes a light humming noise and the center plate continues turning
All microwave ovens have microswitches to confirm door open/closed. Many have several, and a bad switch can cause all sorts of strange issues. My ovens have 4 such switches, and I've had several go bad. You have to open the oven up to see which you need, measure them, and replace the bad ones. The good news is that the switches aren't expensive.
May 26, 2015 | LG Over-the-Range Microwave
My microwave would not turn off. Door closed and light/turntable off, the microwave continues to work when not selected on.
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Microwave.
Mar 09, 2017 | Whirlpool GT4185SK Microwave Oven
Panasonic microwave door is misaligned? does not close without slaming it, then sometimes the light still stays on and msg displays that the door needs to be closed. other times, the light goes out but...
could be a bent or broken pin in the door - its a safty issue since microwaves are harmful when the door are not shut - return the microwave to the store you purchased it from or get a new one
Jan 05, 2014 | Sharp R-1480 Microwave Oven
Fan stays on without cooking or starting
Sounds like a door switch problem. Relays can stick too so tap them to release, they may need to be replaced
Nov 24, 2013 | Sharp R-1610 Microwave Oven
Microwave door wont stay closed
replace the door hooks and door release button.
if this is broken the switch will not close very well, and NOT start the microwave.
God bless you
Jul 19, 2012 | Samsung SMH9187 Microwave Oven
Samsung model smh7178std, shut the door and the fan and lights come on automatically, if i lift up on the door the fan shuts off but light stays on.
some switches are normally closed "short position" press switch "open" it will be labeled NC on the one side, "stands for normally closed" and others will be NO "stands for normally open" press switch "short" if there is no change in readings when you press switch it is defective.
Mar 28, 2012 | Samsung SMH7178STD Microwave Oven
The microwave makes a low rumbling noise once the door is closed. The noise is similar to when the microwave is in use, just a little quieter. The noise occurs as soon as the door closes without pressing...
There is a circuitry problem. Nothing should be on when the door closes and could be dangerous to diagnose for the untrained and inexperienced.
Eric
Nov 21, 2009 | Kenmore Microwave Ovens
Door latch not functioning well
the door switch needs adjusting recommend a service tech to do this
Dec 22, 2007 | Whirlpool GH8155XJ Microwave Oven
Sharp R-1480 Microwave Oven Logo
140 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
