Question about Cycling
Recumbent bike seat won't lock in place
My schwinn active 20 recumbent bike seat will not lock, it just keeps sliding down and I'm afraid I'm going to break the adjustment handle.
  • 50 Answers
SOURCE: My Schwinn 230 Recumbent bike makes a clanking
try the bearings.
Posted on Mar 03, 2009
SOURCE: Schwinn recumbent bike 203 Ac adapter or batteries?
It uses an AC adapter. You can visit:
fitnessrepairparts.com
This is where I am getting the AC parts for my 201.
Posted on Mar 22, 2009
SOURCE: the resistance belt on my Schwinn 205p recumbent
http://www.fitnessrepairparts.com/equipment/SelectEquipment/100 lists all the parts for this model
Posted on Jan 03, 2010
wfservices
  • 262 Answers
SOURCE: schwinn 201 recumbent bike makes clicking noise
Check the tightness of the crank bearings, also the crank fastening nuts (on axle) If its the gears you may have to turn the screws on the rear derailleur to adjust the tracking. The same as the front. Your question is kind of vague so its hard to pinpoint the clicking noise. Could even be a stone in the tire??lol
Posted on Feb 21, 2010
jyackle5
  • 8197 Answers
SOURCE: I need the directions for a Schwinn 203 recumbant
You can get the manual on the link below.
http://download.dfxi.com/supportdocs/OM/Schwinn/SCH_101-103_OM_web.pdf
Good Luck
Posted on Dec 04, 2010
I need an owners manual for a Schwinn Recumbent Model 230 exercise bike. On line manual isn't for the 230 that i have. Will you send me one please?
We don't send anything. We are FIXYA, we are not Schwinn.
There are 5 different 230 models depending on the year. The manuals are in this link.
Product Manuals - Schwinn Fitness
www.schwinnfitness.com/manuals.html
  1. Cached
  2. Similar
Schwinn® 230 Recumbent Bike (2013 model), Assembly & Owner's Manual. Schwinn® 230 Recumbent Bike (2016 model), Assembly & Owner's Manual. Schwinn® 230i Recumbent Bike (2013 model), Assembly & Owner's Manual. Schwinn® 230i Recumbent Bike (2016 model), Assembly & Owner's Manual. Schwinn® ...
Schwinn Fitness Manuals
Dec 26, 2017 | Schwinn Exercise & Fitness
I've had a Schwinn 270 recumbent bike for 4 years. The resistance is completely gone. Suggestions?
I suggest you check the troubleshooting guide in the manual, as there are several causes for the resistance not changing. http://download.nautilus.com/supportdocs/AM_OM/Schwinn/SCH.270-MY17.AM-OM-W.EN.pdf I would suspect that no resistance at all might have to do with a failure of the servo motor, which appears to control resistance through interaction with magnets on the wheel.
Secondly, you can try contacting Schwinn Fitness: Customer Service
If you still can't figure out the problem you may need in-person help. Find a place that sells Schwinn exercise bikes or see if someone at a local gym that has recumbents can help you. The bike is apparently made by Nautilus.
Dec 06, 2017 | Schwinn Cycling
How do I tighten a loose seat on my schwinn 230 recumbent?
WHAT YOU NEED IS A PLASTIC RING THAT FITS THE HOLE ON THE BASE OF BIKE ,SO WHEN YOU SLIDE THE
SEAT DOWN YOU GET MORE SUPPORT WHEN IS TIGHTEN.
D,R,CLAUDIO
Oct 09, 2017 | Schwinn Cycling
Stopped sensing speed or give resistance
proceed according and fix it. God bless you
  • 1 Press the reset button to reset the system, then unplug the bike from the power outlet. Wait about five minutes, then plug in the bike and reset the system again. This usually solves most computericon1.png glitches or error readings.
  • 2 Check all basic connections first if the system won't turn on, or the display is partially functioning or not functioning at all. Ensure that the plug is securely plugged into a proper working outlet. Check to ensure that the cable is securely plugged into the front of the system, and that the cable doesn't appear damaged. If the cable is damaged, replace it immediately.
  • Sponsored Links
  • 3 Inspect the system display visually, looking closely for cracks. Also check to see if humidity has caused moisture to enter the screen. If so, you may need to replace the display.
  • 4 Check all connection points and latches. Latches should be lined up with all connectors and be securely in position. Push on the connection and listen for the snap when the latch locks into place. The computer or circuit board may need replacement if all connections are fine and the display isn't operating properly.
  • 5 Check all connections for the HR (Heart Rate) sensors. Check to ensure that both HR connections from the handlebars and the cable box are secure. Apply a conductive electrode creme to the handlebar sensor to see it produces a better connection. You may have to replace the handlebars or cable if no connection is being produced.
  • 6 Check to ensure the RPM sensor is properly aligned with the magnet on the flywheel and that the connection is secure on the RPM data cable. Reposition the sensor if it's not aligned properly; replace the cable if the connections are broken or the cable is visibly damaged.
  • 7 Move the bikeicon1.png away from large metallic objects, microwaves or other electronic equipment that may interfere with the bike's computer. Ensure that the bike is positioned on a flat, level area--otherwise, the bike will rock and feel unstable. Ensure that all knobs, pins and levers are installed appropriately, including pedals, crank and seat. Cranks should be connected at 180-degrees from one another. Seat pins should be seated completely and securely in the your designated pin hole for seat position.
  • Read more: How to Troubleshoot a Schwinn 230 ' eHow.com http://www.ehow.com/how_6829448_troubleshoot-schwinn-230.html#ixzz2CgvzNzjT
    Nov 18, 2012 | Schwinn 250 Recumbent Bike
    What's the best exercise bike there is?
    According to me, one of the best Exercise Bike is Fitness form S20 Indoor Cycle Bike. It has adjustable resistance level and adjustable horizontal or vertical seats also. It provides the pulse, distance and speed or has roller wheels to move around easily. In this bike, you can also get a warranty of 12 months.
    Aug 09, 2012 | Exercise & Fitness
    Shwinn 220 won't prdal
    you can call Treadmill Doctor and they will help at 800-750-4766 I am also attaching the manual.
    http://download.nautilus.com/supportdocs/OM/Schwinn/SCH.120.220.OM.EN.FR.pdf
    Jul 04, 2012 | Schwinn 220 Recumbent Bike
    The tension does not increase on my schwinn 220
    adjust the magnet very well, tigh the bolts if there loose the tension will be not o.k
    Apr 24, 2012 | Schwinn 220 Recumbent Exercise Bike - 2012...
    I'm looking for a manual for a recumbent bike,
    Hi lcbir5319...
    Go to the following websites for your user manual and parts list for your Schwinn 203.
    Please take time to rate me thumbs up
    User Manual:
    http://download.dfxi.com/supportdocs/OM/Schwinn/SCH_103-203_OM_web.pdf
    Parts list: http://download.dfxi.com/supportdocs/AM/Schwinn/SCH_201-203_AM_web.pdf
    Schwinn website/customer support:
    http://www.schwinnfitness.com/schwinn_fitness_us/customersupport/manualsen.jsp
    Sep 12, 2011 | Cycling
    Cycling Logo
    176 people viewed this question
    Top Cycling Experts
    Michial Gueffroy
    John Egan
    John Egan
    Are you a Cycling Expert? Answer questions, earn points and help others
