Question about EliteGroup Computers & Internet
What is maximum memory size and speed for a P4M800PRO-M v2 motherboard
It also supports dual core....now i have a doubt..!!!  wat is the maximum hard disk size this motherboard can handle??? 500 GB or 1 TB??
Posted on Dec 23, 2008
    Problem Solver:
  • 4 Answers
Hi!the maximum of memory capacity that support is up to 2G DDR Socket and this motherboard that support LGA775 Intel Core 2Duo Processor.by:danz
Posted on Nov 21, 2008
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
May 17, 2011 | Computers & Internet
I need to know the capacity for MEMORY AND THE TYPE SPECIFIED
According to the manufacturers specs these are the memory specifications you need, and the maximum the motherboard will accept...
3 x 168-Pin DIMM-socket
for up to 768 MB memory SDRAM
with 8, 16, 32, 64, 128 and 256 MB size
Dec 28, 2010 | Shuttle Slot A AI61 (MBAI61) Motherboard
When I upgrade P4M800PRO-M478 motherboard with 2x Kingston ValueRAM - Mémoire RAM - 1 Go - DIMM 240 broches - DDR II it doesn't recognize it as 1Go memory but only as 512Mb!! What is wrong??
hello nepr29
my name is ausi
i had a look at your main board. it is capable of 2gig RAM (maximum). you issue is typically related to the type of
RAM you are using. your posting does not indicate the RAM model.
you have to make sure the
RAM you are using is double sided (has chips on boat sides of it). older mother boards have problem addressing the full capacity of single sided RAM, so it reads only half of it.
good luck.
if this was helpful please vote for me.
Nov 27, 2010 | EliteGroup P4M800PRO-M478 Motherboard
I installed memory 1 gb 533 ddr2 kingston mHz, and the computer only recognizes 512 mb of memory. The memory is installed into the sockets of DDR2 memory and change the socket but the result is the same,...
hello jorge stoke
my name is ausi. i have just joind Fixya.
it is interesting you have had no reply yet.
i had a look at your main board. it is capable of 2gig RAM (maximum). your issue is typically related to the type of
good luck.
Sep 12, 2010 | EliteGroup P4M800PRO-M478 Motherboard
Need max memory and hard drive size for Gigabyte GA-5AA motherbrd
Max Supported of your motherboard memory is 768 MB SDRAM DIMM(100,133,166,200 MHZ). You can find the full specifications here:
http://latam.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=1439
Thanks for using Fixya
Jul 28, 2010 | Gigabyte GA-5AA Motherboard
My motherboard ecs elite p4m800pro m2 cant detect 1 gig memory,, please help
Hi, you need to check you have the corrct memory, you need: Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MH
Jul 12, 2010 | EliteGroup (ECS 915PL-A2) Motherboard
Motherboard Name MSI PM8M-V H (MS-7104 v2) (3
MSI PM8M-V is a VIA UniChrome P4M800-based, PC motherboard. Form Factor: Micro ATX. Compatible with Intel P IV and Celeron. Maximum Bus speed would be 800MHz. Maximum RAM Supported is 2GB.
If the specifications differ please inform me.
Thanks for contacting Fixya! Please rate the answer if it solves your problem.
Jun 05, 2010 | Computers & Internet
Hi I also have a P4m800-M7 rev 3.1 motherboard and a 512mb of ram.. my question is, is it okay to put another ram but in 1gb size its pc3200, will it work? thanks!!
The motherboard supports 2GB maximum memory. 1x1GB in each slot.
Maximum clock speed is 400MHz (PC3200), so the memory module you have should work fine.
Please remember to remove the power cord before installing the new ram.
Regards.
Nov 25, 2009 | EliteGroup P4M800-M7 Motherboard
Will this ram support my motherboard?
your motherboard supports • Supports DDR2 533/400 DDR SDRAM DIMMs
• Accommodates two unbuffered DIMMs
• Up to 1 GB per DIMM with maximum memory size up to 2 GB
that ram may or may not work, most likely not as the motherboard was designed for slower memory.
Apr 10, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Computers & Internet Logo
105 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
