Question about Dell 1700n Laser Printer
Model # Dell 1700. won't print says usb cable has bad connection
I believe cable is ok. machine is few years old but has had little use and ink is ok
  • markmathews Nov 21, 2008
    Similar happened to mine after a windows update on about the same date. The computer recognises that the printer is attached, but will not recognise the software disc put in. Manual attempts to install and also an update of drivers does not solve the issue. I run windows XP and it is a Dell Inspiron 6000 lap top,
    Out of warranty and so Dell are unable to help
  • Anonymous Feb 08, 2009
    Do not have installation disk for Dell1700. I cannot print anything but a test sheet. Any help appreciated.
    rvanhoy3@carolina.rr.com
2 Suggested Answers
SOURCE: dell 1700 image drum
After you replace the imaging drum, you should reset the imaging drum's counter. To reset the counter, YOU MUST LEAVE THE DOOR OPEN AND THEN press and hold the Cancel button until all lights flash in sequence.
Posted on Oct 02, 2008
Why dell vs525 will not print in color. ink cartridges are full
Hello Judy
when it comes to printers not printing in color its usually a software issue . Now there are times that you buy the cartridges are bad but lets do some troubleshooting.
Go to support.dell.com
Support Dell US
Select your product by service tag or click on printers and look for your model
Select operating system and the software and driver will appear below in blue lettering click on it download and install software and fireware. Install and run.
Make sure you are connected by USB to your computer.
Print out a test page to make sure all is running ok.
Reseat the cartridges and make sure the contacts are clean.
let me know if this helps
May 07, 2014 | Dell 922 All-In-One InkJet Printer
Model 6180 error Ink System Failure Oxc18a0206 - won't shut off either or print
mportant: If your error message includes the words 'ink system failure ,' check your cartridges before reading this document. If you use any of the following cartridges, refer instead to 'Ink System Failure' Message Displays on the Control Panel (c01458034) to solve this error:Solution one: Reset the product
  1. Without turning off the product, disconnect the USB cable from the rear of the product.note.pngNOTE:The USB cable connects to the port on the rear of the product. The port is labeled with the USB icon (c01424575.gif ).Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product.
  10. Try printing again.
Oct 07, 2011 | HP Photosmart C6180 All-In-One InkJet...
My printer is a HP- 6210, Message: "remove and
Hello Cliff, welcome to FixYa.
Hard Reset the printer by doing the following:
  • Remove all the ink cartridges.
  • While the printer in ON, unplugged the power cable from the power source.
  • Disconnect the USB cable at the back of the printer (if your printer is connected through a USB cable)
  • Restart your computer.
  • Connect back the USB cable.
  • Plug the power cable to its power source.
  • Turn ON the printer if it does not turn ON automatically.
  • Install the ink cartridges.
  • If the printer prompts for an print head alignment, please do so.
If the problem persists, replace the ink cartridge. The cartridge might be defective since you already have tried to clean the contacts.
Keep me posted.
Jas
Sep 28, 2011 | HP Photosmart 2610 All-In-One InkJet...
My Brother MFC-5890CN Printer wont print.It does scan.I have tried re-installing the drives but when it gets to the last section the box just asks for the machine to be connected. I have also changed the...
I can't print nothing from my PC or trough network, but still I can Scan, Fax, etc. I'm using Windows 7 Home Basic, I already installed the driver ( "Connection via USB Cable" ) and I have plenty enough ink ... I checked the Settings, Test Page is OK, but nothing else want to be pinted. I had a problem with my MFC 5890 in the very begining ( nearly 2 weeks ago ) so I had to unplug and than plug in the USB Cable and in this situation the printing of my "pending documents" was successful, but from few days ago there is no such a thing that could make it print. Please help
Dec 31, 2010 | Brother MFC-5890CN All-In-One InkJet...
Keep getting "Printer Offline" from Dell 1700 printer
go to the start menu
click on run
type services.msc
on the list go to Print Spooler
double click on print spooler and select automatic on startup type
now press on start.
if that doesn't work go to this microsoft website and click on the Fix It icon with the little man holding a wrench. run this and it will fix it.
Dec 03, 2009 | Dell 1700n Laser Printer
Printer goes through the motions but text does not print
Let's first test the printer independant of your computer:
Try printing a test page using the instructions here: http://www.ehow.com/how_2006016_perform-test-epson.html. I hope your model printer is listed there. If not, try to find instructions specific to your model in your model's user guide or elsewhere on the internet.
If this works and printing from your computer doesn't, then:
(???Bad print drivers???) Reload the print drivers on your computer.
(???Bad cable???) Try replacing the printer/USB cable that connects this printer to your computer.
(???Bad USB port???) Try using a different port to connect the cable to your computer.
If none of this works you either have a faulty ink cartridge or a more serious issue with the printer. Depending upon the model, unfortunately, it might be cheaper to replace than repair.
May 28, 2009 | Epson Office Equipment & Supplies
1700 printer
How did you install the printer?
I have found that if you just let your computer recognise new hardware, it really has a hard time with the USB printing to the 1700's.
Originally there was a disk that came with the 1700 printer. You do want to use that.
During the install, you run the software, and then turn on the printer. (You can have the printer on during the install, but ignore the Windows Wizards that come up).
If you don't have the original 1700 install disk, you can download it from Dell.
The problem is with USB port configuration. These little 1700's are just a pain sometimes if not installed the way they were originally designed.
Jul 31, 2008 | Dell 1700n Laser Printer
Brother MFC-440CN won't print color
Did you use generic carts?
Do use only original brother ink carts!
Only these have special cleaning fluids mingled with the ink.
There are several advantages, too:
You can run a special cleaning mode (DO insert original carts at first!!!)
Press menue then start bk copy then fourtimes arrow-up.
machine should switch to maintenance mode (buttons will flash).
press 7 then 6 then 4 then start bk copy. machine will refresh ink within the tubes and the print head and run a special cleaning routine. when finished press 7 then 6 then 3 then start bk copy to run a power cleaning. leave the maintenance mode by pressing 9 then 9.
The machine should print without proböems. If there is a poor quality left, the printhead is affected by bad ink and cant be fixed anymore.
Jan 24, 2008 | Brother MultiFunction Center MFC-440CN...
Flashing Green Light/ Computer can't communicate with printer......
Hi. The flashing code signifies that there is a fault with the connection between the ink cartridge and the printer - usually because either the tape is still on the cartridge or maybe some glue from the tape still on the contacts. In my case, I think the cartridge was simply knackered, so I threw it away and opened yet another ink cartridge. It now works fine.
If you want to test yours, simply take out both ink cartridges, and re-insert them one at a time. If you've put a working cartridge in the flashing will stop; if you've put the dodgy one in it'll still flash. Just replace the dodgy one.
Hope this helps.
Dec 14, 2006 | Dell A920 InkJet Printer
Lexmark X5150 No printing
uninstall the printe driver,then try reinstalling the printer back.if no luck,change the usb cable or printer cable as the case may be,if doesn't work,try using the printer on a friends machine. did it work?let me know. eyo7 eyoifiok2005@yahoo.com
Sep 01, 2006 | Lexmark X5150 All-In-One InkJet Printer
Dell 1700n Laser Printer Logo
35 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
