Sharp R-1850A 850 Watts Convection / Microwave Oven
Problem for Sharp R-1850A 850 Watts Convection / Microwave Oven
Shuts down after 59 sec
By Worm on Dec 20, 2006
Microwave will shut down after 59 sec, time remains. Must press start again and will run 59 sec more. Doesn't require cool down. Every other aspect is working fine. Ordered new control unit and replaced but same problem still there.
Same Problem
Jan 11, 2009
-   Sharp R-1874 With same problem, shuts down after 59 seconds. Ordered damper motor. When it arrives I'll open the case and see if its readily accessible. From the exploded view, it appears to be on the right side of the unit, behind the control panel. Also note that there is a high energy capacitor in the microwave that can store a substantial charge so unplug for at least an hour before disassembling and still be careful what you touch. -   MrRat
Nov 03, 2007
-   Our R-1870 had the same problem. Replacing the $10 damper motor fixed it. The tech said it COULD have been the control circuitry, the damper itself, or the microswitch that the damper hits, but it was in fact the motor.-   Guest
Best Solution
posted on Dec 21, 2006
Very Helpful)
Rotu
Rank: Guru
Rating: 90%, 609 votes
Sounds like someone else got it already, I just got the phone with sharp tech support for the exact same problem, and they said to replace the damper motor and switch if the board didn't do it. Good Luck!
Was this helpful?
Yes
No
Solution #2
posted on Mar 04, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
It was the damper motor. $10 part fixed it. Thanks
Solution #3
posted on Dec 20, 2006
Helpful)
MicrowaveSvc
Rank: Guru  Sharp Kitchen Appliances  Expert
Rating: 89%, 5355 votes
Chances are you have a bad damper switch or wiring.
A sample photo is here: http://207.234.249.73/mwd/damper.jpg
It might also be a problem with the humidity sensor or a problem with the control panel, such as corrupted code or bad connections.
Comments:
Nov 05, 2007
- I just wanted to update this reply since it's so popular:
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door located on the right side of the innards. The damper closes and opens depending on cooking mode.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find an exploded view by entering your model number here: http://www3.sears.com
You can order parts from Tritronincs at http://www.wehaveparts.com
Was this helpful?
Yes
No
Solution #4
posted on Oct 20, 2008
Not Rated)
pak48188
Rank: Apprentice
Rating: 0%, 0 votes
Replaced damper motor twice! First replacement motor did not turn. Second one was OK, these motors are cheap JUNK. Last Sharp I buy!
Was this helpful?
Yes
No
Solution #5
posted on Apr 06, 2008
Not Rated)
ArchH
Rank: Apprentice
Rating: 100%, 1 votes
Exact same problem. Very common problem with the people we know that have motorhomes with Sharpe R-1874
Mine was the damper motor. $14.95 for the motor.
The total bill for removing and reinstalling in my motorhome with parts was $106.45.
Was this helpful?
Yes
No
Popular Solutions for Sharp R-1850A 850 Watts
Questions and Unsolved Problems for Sharp R-1850A 850 Watts
Do you recommend Sharp R-1850A 850 Watts Convection / Microwave Oven?
Answer
Answer
My Sharp 1850 A has stopped heating with the microwave - just makes a loud buzzing noise. All other... (More)
Answer
My Sharp 520KS-T stopped working.Light does not come on when door is opened. Is there a fuse in this... (More)
Answer
I was using the convection feature and half way through, it stopped heating. The light still works,... (More)
Answer
The Sharp Microwave R-1850A oven light is inop. The oven is installed in 2000 Alpine cabinet where... (More)
Describe your Microwave Ovens problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Microwave Oven Experts
Top Small Appliance Repairmen
in Newport, KY
(316) 283-4211
Sharp
(316) 283-8664
Sharp
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
