-   I have an 57H81 Toshiba Rear Projection TV & recently developed an issue with a double image showing up & a color bleed/stream coming off images & need a solution to this issue.
-   Bob Toddler
Apr 07, 2009
-   Just noticed this the other day on my picture. Seems like a double image & a stream coming off of some images. Really annoying. Tried auto-focus & playing with the convergence but didnt seem to help.
-   Bob Toddler
Dec 22, 2008
-   green convergence is arched at bottom/double image -   Guest
Dec 22, 2008
-   picture distorted and double picture-help-   earljill
TV takes several attempts to turn on. Light will flash a couple of times and then turn off. After...
(More)
TV takes several attempts to turn on. Light will flash a couple of times and then turn off. After 6 or 7 times, the set will turn on and work fine until shut off again.
The TV won't turn on. It clicks on and then clicks off within a second or so. One time it wouldn't...
(More)
The TV won't turn on. It clicks on and then clicks off within a second or so. One time it wouldn't turn off and wouldn't respond to any input such as volume or channel control
Images show up sometimes with new bulb, usually i heard motor working somes clicks but not anymore,...
(More)
Images show up sometimes with new bulb, usually i heard motor working somes clicks but not anymore, i dont know what to do ??? Right now i have just disconnect power cable back of TV and plug back, i turn on the TV i heard motor working so what??? the images show up, so must be motor and then??? how do i do to change if it is the problem average cost on that motors??? Thanks to help me...... Model m50wh74s
I have the same TV. One minute is was working fine and I turned it off for less that 2 minutes, turned it on and the colors are out of wack and the image looks sort of concave. Is this the "convergence" problem I have been reading about and are the parts still available to fix it?
