Question about Radio Shack Pro-2055 Base Scanner
PRO-2055 not picking up programed EDACS frequencies
All programing is correct (or atleast it was), it worked a month ago when I used it last. But now all it does is scan. Everything appears to be programed properly. What might be my issue. If more info is needed I'll be happy to pass it on. I am at an absolute loss as to what might be wrong.
Additional info: I am monitoring EDACS, I have programed it in logical order (as previously mentioned, the scanner worked a month ago).
Any help would be greatly appreciated.
4 Suggested Answers
  • 1114 Answers
SOURCE: pro-95 dual trunk-tracking handheld scanner from Radio Shack
Firstly make sure the "squelch" is set as per the manual (link below) page 26. If that fails I suggest initializing the scanner to factory defaults as below:
Posted on Aug 01, 2007
sir fixalot
  • 146 Answers
SOURCE: Pro-95 dual-trunk scanner
Here is the online programming tutorial:
Here is the full manual Should include Quick guide:
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
Posted on Jan 04, 2008
SOURCE: Pro 96 Rebanding Issue
You need to program custom tables into the Pro-96. Visit the link above.
ChLO ChHI Step Offset Base
440 559 25.000 440 851.025000
000 719 25.000 0 851.012500
720 759 25.000 0 848.000000
815 831 25.000 0 846.625000
958 958 25.000 958 868.975000
961 1022 25.000 0 843.400000
Posted on Mar 28, 2008
Why wont my scanner model 60 channel pro-2029 scan
Hi Chad,
Do you have any frequencies programmed into your radio scanner?
If not, then that is why you're not receiving anything.
If on the other hand you do have frequencies programmed, are they the correct frequencies for your location?
Are the frequencies the Tx or Rx frequencies that you programmed, The Tx frequencies are the correct frequencies to program, as Rx is the mobile(usually) Tx frequencies, and unless you're within 5 miles of that mobile, you won't hear it, and you certainly won't hear the base transmissions, unless it's a high powered Simplex Frequency.
I hope this has been useful to you.
Mar 15, 2013 | Radio Communications
How do i work a pro-94 radioshack police scanner?
Specs are not needed. I suspect you need the local frequencies and how to program them. The scanner CAN be set to scan for the local frequencies. Have a pad and paper ready and write down the ones you want to keep.
You must obtain the local frequencies, try Google. They are public knowledge, but hard to find. Local Hams or a Radio Shack will likely have the frequencies. Be nice, be polite, no one has to give you this information.
Jan 29, 2018 | Radio Communications
Having problem programming Pro-94, is there a simpler book or read than the manual. It says you must load in logical channel order. how do I determine this??? Also am I correct in that you can only load...
put your scanner in manual mode.and then go to program mode and program your frequencies into your scanner.try that and see if that works.....if not it could be a problem in your Radio....
Feb 22, 2011 | Radio Shack Pro-94 Scanner
You can download and print an easy to read aftermarket manual for your scanner here:
For a comprehensive database of active frequencies and systems in your area, visit:
Bill B
Sep 11, 2010 | Radio Shack Pro-2055 Base Scanner
Is there software for the pro 96 to monitar edacs
This scanner only monitors 2 of the 3 types of trunking systems. There is no digital voice inversion. There is an AGC control for the digital voice to try either way DG (on) or Dg (off) There is software you can buy to program the PRO96 from Don Starr. There are two Yahoo GrOUPS you can join to discuss this radio, in addition to forums on RadioReference DOT com.
Jun 19, 2010 | Radio Shack Pro-96 Scanner
I need to know how to program this scanner. Radio shack pro-2055
The programming instructions are too detailed and lengthy to post here, so here's a link to the manual for your scanner. It will walk you through the programming process.
For an extensive database of active frequencies and systems in your area visit
If this response helps, please take a moment to post a rating. "Very Helpful" would be appreciated.
Dec 04, 2009 | Radio Shack Pro-2055 Base Scanner
Not receiving the tunked freq.
you may be trying to pick up a frequency that is to far away for that scanner. not all scanners pick up as far as others.
Feb 17, 2009 | Uniden TRUNKTRACKER III
Edacs frequencies
Are you getting talkgroup ID's? If not, you're probably monitoring the EDACS system in conventional mode rather than trunking. When the scanner hears those beeps, it's supposed to go back to monitoring the control channel if you're in either trunking mode (search or scan). This also happens if the CC isn't coming in very well. If you're not in trunking mode, read the manual to find out more about programming and monitoring trunked systems. If you are in trunking mode and receiving ID's, the unit is probably malfunctioning.
Sep 23, 2007 | Radio Shack Pro-94 Scanner
RadioShack PRO-94 Scanner
is there a vista program avalib.for pro-94 pc-interface cable
Sep 19, 2007 | Radio Shack Pro-94 Scanner
Radio Shack Pro-2055 Base Scanner Logo
61 people viewed this question
Top Radio Shack Radio Communications Experts
Greg Cann
Greg Cann
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
