Question about Oster 76076-010 Hair Trimmer
Clippers wont cut
These are small animal clippers i had the blades sharpened i did this thinking they would cut like they did when i first got them they didnt cut any better at all.
  • 193 Answers
If possible try the blades on another clipper just to make sure the clippers are ok, otherwise it sounds like a sharpening problem.
Posted on Aug 04, 2009
Im having trouble with my Andis Master clippers. I tried doing a cut with a 1 1/2 and they wont cut. If I use just a one or any other size they are fine, only when I raise it to a half they don't cut.
get a small shallow dish and put in a small amount of kerosene
turn the clippers on and place the cutter blades( just the cutter blades ) in the kerosene so that any gunk , hair etc is washed out
change the cutter head to a newly sharpened set
Mar 10, 2017 | Andis Health & Beauty
Can I swap sharp cutting blade from one size blade to another?
Well you can either buy a new one from a local shop
http://www.angliaclipperservices.com/dog
Or wait a while and send them off for sharpening
http://www.angliaclipperservices.com/Clipper_Sharpening
May 26, 2016 | Andis Dog Clippers - AGP Super 2-Speed...
Clippers not cutting
It is not unknown for a sharpen to be no good, anyone can turn out a bad sharpen. Look for correct blade assembly, check that there is sufficient pressure holding the blades together, check there is no missing stroke. Check the blade is secure and not wobbling. If the above are OK I would buy a new blade. You could also return the blade with the clipper for the sharpener to test for themselves.
Nov 20, 2013 | Wahl BravMini Rechargeable Trimmer Purple
Andis agc 2 not cutting very well
Yep as simple as that just make sure they are a well recignised sharpener otherwise you will waste your money. You can rule out a clipper problem if other blades cut ok. Clipper Blade Sharpening
Mar 03, 2013 | Andis AGC2 Hair Trimmer
How to position the clipper blade while u sharpening?
Hi!
I'm not sure about the nature of you question. Firstly if you mean, position the comb (with the adjusting lever on your clipper because your blades wont work, then:)
1.
If you move the comb downwards using the lever on the side of your clipper you will get a shorter cut, if you move it forward you will get a slightly longer cut. If your clipper makes a horrible noise, I believe there is a plastic adjuster on the side that you adjust with a flat head screwdriver. This adjusts the springs inside the clipper which effects how central the cutter moves from side to side. Adjust this while the clipper is running. You want your blades to be as central as posssible. If they still do not work, you may need your blades sharpened. This costs £5.90 incl. VAT & Postage www.sheareaseltd.com You could send your clipper to them as well and ask them to re align your blades after sharpening and they'll just charge the extra postage. (extra £5)
Hope this helps!
2.
If you mean how to hold the clipper with the blade relative to what you are clipping. You need to hold the clipper so the teeth are not pointing into your project, but not pointing away from it either. Keep the comb parallel to your project. With human hair, cut against the grain, with an animal cut with the grain!
Hope This Helps!
Jun 18, 2010 | Wahl Magic Clip Clippers Hair Trimmer
Can i sharpen my electic trimmers using sandpaper
Things You'll Need: Three-sided blade sharpener (coarse, medium, fine) Small flat head screwdriver step 1 Using the flat head screwdriver, unscrew the trimmer blades and remove them carefully. Wipe off any oil, grime or dirt that has built up on them as this may make it more difficult to handle and keep them in place during the manual portion of the sharpening process. Step 2 Separate the blades and re-apply only the moving blade to the tension spring. Then apply the moving blade to sharpener surface and turn the clippers or trimmers on. Hold the moving blade on the surface of the sharpener and apply light pressure while moving the blade back and forth for one to two minutes. You can also lay the blade on the sharpener first, then put the trimmer tension spring directly on the blade. Step 3 Turn off the clippers and remove the moving blade. It should look shiny and feel sharper. Step 4 Remove the guide from the guide blade by unscrewing it using the flat head screwdriver. Place the guide blade on the sharpening surface and manually run it back and forth for about one or two minutes or until it's been sharpened to your satisfaction. Screw the guide back onto the guide blade while being careful to readjust it before you tighten the screws. Step 5 Screw all the blades back on the trimmers and power them on to make sure they've been fitted correctly. Test them on your own hair to make sure they've been sharpened correctly and are set to the desired depth. Ads by Google Best Knife Sharpener Sharpen like the pros. Complete kit w/ 1x30 belt sander. Only $189.00 www.theedgemasters.com Braun® BodyGrooming Tools Try the Braun® bodycruZer? with Gillette® Fusion Razor Technology. www.Braun.com/BodyGrooming Oster ® Clipper Blades Oster ® Full Line Clipper Blades, Animal & Human Oster ® Blades. www.HouseholdAppliance.com STIHL Electric Trimmers Buy it. Plug it in. Trim it up. Depend on STIHL Electric Trimmers. www.STIHLdealers.com Tips & Warnings Which surface you choose, whether coarse, medium or fine, depends on how dull your blades are and how sharp you want to make them. If they are very dull, you will want to start with the coarse or medium side of the sharpener. If they just need a small amount of sharpening, use the fine side. If you've never sharpened electric trimmers before, you may want to visually observe and feel the sharpness of the blades with your fingers before you start to sharpen it. It may be hard to tell if the blades are sharp enough if you don't feel them just before you apply them to the sharpening surface.
May 02, 2010 | Andis T-Outliner Hair Trimmer
Hi, used a blade sharpener for my a2 horse clipper blades and they are still blunt. Do i sharpen between the teeth
no . The blades are sharpened by grinding away the base of the wear until the edges between the teeth are sharp. It also necessary for the tension between the cutting blades is correct other wise the cutting teeth ride up over the hair and will not cut. Have a person who does sharpening of knives ,scissors and blades sharpen the clippers for you as the machine will get it right.
Nov 18, 2009 | Makita 9820 - 2 Blade Sharpener
Wahl kennel pro 8800 noy cutting hair
if the blade look black on the cutter blade and also the comb blade where the teeeth are U need to sharpen them Mannys Sharpening clipper doc
Nov 11, 2009 | Health & Beauty
Need advice on how to sharpen Wahl animal clippers
try getting they sharpened but this time when you use them oil between the two blades before during and after use. oil will maintain the useful life of blades.
Jun 19, 2009 | Wahl 8892-002 Kennel Pro Clipper Kit
Blades are not cutting
hi, yes blades can wear out but your sharpener should advise if there is a problem with them. check to make sure the clipper is moving your blades and your blade cannot be removed without depressing the latch. If your are experiencing tram lines with larger blades then it is more likely to be a clipper problem. However if your blades just wont cut i would recommend a new sharpener as it is a specialist area.
Jan 29, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster 76076-010 Hair Trimmer Logo
232 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Chuck
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
