SOURCE: mower starts then stalls, stalls when throttle is raised
Check your oil filter and oil level. Some have an oil pressure switch that saves the engine but killing spark when oil pressure is too low. That is something near the carb, usually has 2 wires coming from it.
SOURCE: JD 2030 power steering failure
either the steering arm in the bell housing on the right side of the tractor is striped or the colume is broken internaly. the is asuming that all tie rod ends and the bell crank are still atatched.
SOURCE: yth1848xp bogs down at full throttle when engaging the mower
Carburetor could possibly need cleaning or rebuild, Governor linkage could be dirty and not operating freely, or it could be out of adjustment
SOURCE: I have a F725 mower.
Could be ignition module overheating, but then the coke influence doesn't make sense. Once it quits try either a shot of starting fluid in the carb, or tiny bit of gas. If it runs then you know you have a fuel problem. Check to be sure the gas cap is venting and check to be sure you're not getting vapor lock after the motor gets so hot. You could also disconnect fuel line to be fuel pump is pumping. Does it have a kawasaki engine? Beware of some plastic cam gears.
SOURCE: JD 68 riding mower
dear sir
tour bottom end is going in your lawn mower or tyoyur block is cracked. sorry but thats the truth.
