I have a Panasonic SA-PM147 compact stereo system. It is faulting as follows: After turning on the cd player or radio, the unit soon turns itself off. The louder the volume, the sooner it turns off, and just before switching itself off it comes up with a message saying F61, which I assume means fault 61. This unit has had little use since I bought it and has never been played particularly loud. It is not often used because it is in or holiday home which we don't use much. What is the problem? and how difficult and expensive is ot to fix the problem? I actually own two of these stereos. I bought one for home and one for my holiday home as stated. Kind regards Steve steve.hope@innovationz.co.nz
SOURCE: I have a panasonic SA.AK640
El IC amplificador de audio esta dañado .
Posted on Apr 04, 2008
robotek
  • 1512 Answers
SOURCE: Panasonic stereo SA-PM28 displays fault
Hi dearnley1
The error code your unit is presenting relates to either a speaker cabling fault or a fault speaker. Sometimes, it is neither, and may be a fault inside the unit. Needless to say the unit is in protection moe to prevent more damage occurring. Check you speaker wiring for any short circuits or frayed wires. If all appears to be ok, disconnect the wires from the unit and see if it turns on and stays on then. If it still presents f61 with speakers and cable disconnected, then I am afraid that you may need to take the unit to a Kenwood service center near to you for an inspection . Good luck
regards
Graeme
Posted on Apr 06, 2008
SOURCE: f61 code coming up on
You gotta change the audio amplifier IC because maybe are on short circuit
Posted on Oct 02, 2008
  • 4 Answers
SOURCE: much loved old J.V.C. unit
try turning it upside down and pluging in and out while turning it on.
Posted on Dec 19, 2008
dunnbiker
  • 8546 Answers
SOURCE: i have a panasonic dvd
Did the fan replacement follow the onset of an F61, too? Or did the F61 come on after the 'repair'? If theformer, I'd ask the techto take another swing at it; if the latter, I'd ask the tech what he did to wake up the new problem.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Feb 19, 2011
I would like to get a neew remote control for my stereo system model number CD stereo system panasonic SA-PM9
The Panasonic SA-PM9 indicates the main unit of the SC-PM9 CD stereo system. It came with the EUR7711140 remote. Amazon.uk has the original remote for sale here: https://www.amazon.co.uk/Original-remote-for-PANASONIC-SCPM9/dp/B01610BYJ8 . Other sites have replacements for this remote. One vendor with the replacement in stock (today) is http://www.remote-control-world.eu/rc-for-audio-hifi-panasonic-technics-c-12_96/panasonic-eur7711140-replacement-remote-control-p-3903 .
The manual for the SC-PM9 is available from Panasonic's support for the unit. The direct link to the manual is https://panasonic.ca/PCS/OperatingInstructions/SCPM9S-OI-Eng.pdf .
I hope this helps.
Feb 01, 2017 | Panasonic Audio Players & Recorders
Panasonic sa ak220 wont turn on
The problem is in the audio output ic, it is loading the unit into shutdown. The only option is have the ic in the stereo replaced.
Mar 07, 2012 | Panasonic SC-AK220 CD Shelf System
Panasonic SA-AK630 can i plug a ipod into it some how ?
for these stereo you have a AUX IN on the back (L and R RCA sockets)
from your manual follow these steps.
1. Press [AUX].
The unit comes on.
2. For listening: Proceed to step 3.
For recording: Press [a, REC] (recording starts).
3. Start playback from the external source. (For details, refer to the
external unit’s instruction manual.)
External unit connections
An analog player with a built-in phono equalizer can be connected.
For details, refer to the instruction manual of the units which are to
be connected.
When units other than those described above are to be connected,
please consult your audio dealer.
Rear panel of
this unit
(R) (L)
R L
then you need a ipod audio cable, available on mac store, but these cabble has 3,5 mm jack connector, need a adapter 3,5mm stereo jack to rca Connectors, and these is available on electronics stores, or professional audio store
try these and post
Jan 29, 2010 | Panasonic SC-AK630 CD Shelf System
Panasonic cd stereo system sa-ak100
my remote control don't work. I thank it's the remote control signal sensor. what should I do.
Jun 20, 2009 | Panasonic SC-AK100 CD Shelf System
Error f-61 on SA-AK640
F61 Power Amp IC output abnormal
Upon power on,
PCONT=HIGH,
DCDET=L after checking
LSI.
For power.
Press [STOP] on main unit for
next error.
Aug 23, 2008 | Panasonic SC-AK640 Shelf System
181 people viewed this question
 Grubhead
Grubhead
