Question about Arris SURFboard SBG900 (49402201900) Modem
Sbg900 setup and login page
I have a sbg900 surfboard router. when i go to the setup page to change my password and to add firewalls the user id "admin" and password "motorola" does not work. even after resetting thr router through the pinghole in the back, help!!!!!!!!!!!!!
  • 3 more comments
  • Anonymous Dec 17, 2008
    I have the same problem
  • Anonymous Dec 23, 2008
    i also have this problem, some1 help plz
  • Anonymous Jan 03, 2009
    I hear you. Same problem, no answer.
  • Anonymous Jan 20, 2009
    Same thing - even tried teh mac address as password but no help.
  • Damia442 Apr 19, 2009
    I forgot my password and login and motorola couldn't tell me how to reset modem. Save this Solution #1 and after a few tries of holding the reset in for 20-30 seconds it worked.
I had this problem just last night. I held down the reset button for 20-30 seconds. It worked when after pressing teh button the LEDs stayed on and then after the 20-30 seconds they started to blink indicating the reset. If they do not start reset while holding down the reset, let go and the modem should reset itself. It took me a few times to get this right since teh reset button is rather sensitive and a momentary depression/release will resutl ina reset of the modem but not to default password. I found out I was inadvertantly doing this momentary reset due to teh sensitivity of the switch.
Anyway, next make sure you type "admin" and "motorola" in all lower case. I was using Admin and Motorola - no good.
Posted on Jan 20, 2009
Changing security key on my modem surfboard wireless sbg6580
Use the default user name and password to login... then you can go to wireless tab and chamge the WPA key to whatever you want.
Sep 22, 2014 | Arris SURFboard SBG900 Wireless Router...
Trying to secure my wep, tried the loggin admin, motorola but will not log me in.
Couple of things you can do....
In the User ID field, type admin (case sensitive) and press TAB. In the Password field, type motorola (case sensitive) and click Log In to display the SBG900 Setup Program main window
If you are still having problems, try the following:
  1. Press the reset button on the rear panel. Resetting may take 5 to 30 minutes
  2. Try the login again, if that fail try from a different browser.
Mar 06, 2011 | Arris SURFboard SBG900 Wireless Router...
Set up wireless security
1 On a computer wired to the SBG900 USB or Ethernet port, open your web
browser (for example, Microsoft Internet Explorer)
2 Type http//:192.168.100.1 and press ENTER to display the login window:
3 In the User ID field, type admin (case sensitive) and press TAB.
4 In the Password field, type motorola (case sensitive) and click Log In to
display the SBG900 Setup Program main window:
As soon as your network is operational, run the SBG900 Setup Program to:
"Wireless Network Setup"
For a LAN with one or more wireless clients, enable wireless security on the SBG900.
After enabling wireless security on the SBG900, as required on each wireless client:
> If you disabled ESSID broadcasting on the SBG900, set the client Network
Name (ESSID) identical to the ESSID on the SBG900.
> If you enabled WEP on the SBG900, set the client WEP key identical to the
WEP key on the SBG900.
> If you enabled Allow Only Listed Stations Access, be sure the MAC
address for each client is correctly listed on the SBG900.
Dec 22, 2010 | Arris SURFboard SBG900 Wireless Router...
Where do i find the wep? i am tryin to connect my ps3 to the wifi.
HI,
Please go to one of the computer which can go online
browser (for example, Microsoft Internet Explorer or Netscape
Navigator®).
now you would be able see your WEP key
Hope it can resolve your issue
Thanks for using Fixya
Apr 19, 2010 | Arris SURFboard SBG900 Wireless Router...
How do you unlock the secured wireless signal when you were not given the code
first you need to connect a cable between a PC and your router. Next she can need to log into the router using a browser. The routers should ask you for a login and password. the default password for your router is motorola. The user ID is admin. I have attached a link to the manual for your router. Page 71 of the manual will explain how to set up your wireless password/passphrase. That is the security code being asked for. Use the same passphrase with your PC when asked.
The link is: http://broadband.motorola.com/consumers/products/SBG900/downloads/SBG900_User_Guide.pdf
If this sounds your problem please leave feedback otherwise send me more information about what you tried in how worked out.
Feb 11, 2010 | Arris SURFboard SBG900 Wireless Router...
I have a motorola SBG900 and i cant seem to fine my user id and pass word to get to my configuration page i keep reading these other options that keep saying type in admin for the user name and motorola...
Is there any computer connected to the router?
If not then you will need to connect the computer to the router and the access the router setup and you will find the password there if you don't know the password to access the router then you will need to reset the router and reconfigure the router.
Click Here for more info
Nov 16, 2009 | Arris SURFboard SBG900 Wireless Router...
I cant reset my Motorola SBG900!
Ok in the back of this unit or bottom there is a reset button or hole that you need a pin needle to access. Press it in for 15sec and let it reboot. Once it reboots, open a web page and type in 192.168.100.1 or 192.168.0.1 This will bring up a log in page. The login is admin and the password is motorola.
May 24, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Wireless router
1. Log into the router with your browser by entering 192,168.0.1 into the URL bar near the top of the screen.
2. Type admin in the user field
3. Type motorola into the password field.
This will get you into the router setup.
Go to the wireless tab and setup WEP encryption. Write down everything you do, because you'll need ti later if you don't remember it.
Once setup, you'll need to setup any wireless computers that you want to hook to the router.
Here's a link to the router manual. If you go through it page by page, starting at page 22, then you should be OK. Key things to setup are WEP encryption. A lot of the other stuff, you don't have to worry with. And, you can change the login user name and password, which is highly recommended.
http://www.fixya.com/PostAnswer.aspx?thid=1586831&prdid=496213
Jan 23, 2009 | Arris SURFboard SBG900 Wireless Router...
Can't open my NAT
Hi there.. i had that problem too and i just solved it...
heres the thing..
first you go into the router setup page.. which is.. 192.168.100.1
go to the gateway tab
go to port forwarding tab
go to config
thenTemplate --> custom
Name--> whatever
Port start--> 88
Port end-->88
LAN IP address--> check on your xbox on network settings and copy the same ip address.
Enable --> checked
Then click add.
After that.. you will do the same thing but on the port option you will put 3074. add it ..
now your nat should be open. ;)
Dec 30, 2007 | Arris SURFboard SBG900 Wireless Router...
Arris SURFboard SBG900 (49402201900) Modem Logo
1,946 people viewed this question
Top Arris Computers & Internet Experts
Suddenlink Help
Level 1 Expert
 John
John
richie46
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
