Question about Brother P-Touch PT-1830 Label Printer
My P-touch won't work
A screen message appears " No cassette!" however there is a new cartridge installed,
  • Anonymous Apr 29, 2009
    No cassette messge showing
jaylex
  • 417 Answers
SOURCE: colour printing
Hi there you could remove the print cartridge and clean the contacts on the cartridge and on the carriage with a soft cloth as they may have dried ink on them. Is the ink cartridge an original if not replace also replace if you have refilled the cartridge. Most problems are down to fault cartridges so suggest you replace the ink cartridge anyway and return hopefully the faulty one back to the store.
Hope this helps you
Thanks J
P.S I take it you have removed the blue tape that comes on the cartridge!!!
Posted on Jan 13, 2008
Mix-it-up
  • 832 Answers
SOURCE: Ink problems....
Take all carts out of the machine. Have a look into the cart holder. Is there ink swapping beneath the white plastic? (You might shake the machine ;-)
If yes, the cart holder leaks and needs replacement.
If not (your lucky!) it could be that the automatic cleaning procedure which starts when a cart is changed has soaked the carts empty.
Do set machine with date and time and NEVER unplug NOR use a power switch which breaks the power supply.
Do use constant power and switch off machine by pressing stand-by-fax-button!
Everytime when machine comes to (new) power contact it runs an extensive ink cleaning procedure. thats why your carts are always near empty....
The stand-by will prevent this and machine does some cleaning procedures which consumes only a few drops(!) of ink!
The display asks you if you have changed the carts. Do answer this question by pressing 1 for YES or 2 for NO.
This will reset the built-in inkcountermanagement to the correct settings
Posted on Jan 22, 2008
  • 8 Answers
SOURCE: Epson Aculaser C1100 erro message install C tnrcart
You need to remove the cyan cartridge, and thoroughly clean the inside of the printer (please use proper printer cleaning kit, not a damp cloth!). The sensors can get crudded up with loose toner inside the machine.
Posted on Oct 29, 2008
  • 667 Answers
SOURCE: C4280 photosmart printer - printer screen says
Uninstall the program from your computer. Plug in your printer first replace with new cartridge making sure to remover the film on the cartridge Then plug in patch cord to computer, program should reinstall if need be you may have to have your disk that comes with the printer. Hope this works, Printers are going for very cheap I would suggest buying a new one if this does not work.
Posted on Apr 01, 2010
YODELION
  • 11 Answers
SOURCE: hp officejet 7310 black cartridge error message
If the contacts were pierced by the spring clip, you may be able to do one of three things:
!) if you are under warranty (and maybe even if not since there were extensions due to this issue - see fixyourownprinter.com and "x-bias spring"), get a new printer from HP
2)get a new carriage assembly from a used printer with the same carriage - several models including the photosmart amd desk jets use this same carriage and can be purchased second-hand for 25 bucks or less (better than getting one new which may cost as much as $150 for no good reason
3)attempt to repair the torn traces with tape and a "circuit writer" pen (Radio Shack @ 7-13 bucks). Soldering will only melt the mylar, so I recommend sanding off the plastic from the copper trace a bit and then using the pen connect the break in the circuitry and cover with a piece of scotch tape to isolate the circuit paths if more than one is torn through. Don't forget to epoxy the spring back in place - and do the other side too so that you don't have the same problem with the other cartridge later.
Posted on May 24, 2010
Install Cartridge Message
Make sure your CARTRIDGE ISN'T EXPIRED, if the DATE ON THE BOX IS EXPIRED IT WON'T WORK.
Jan 04, 2013 | HEWLETT-PACKARD HP 2140 Fax
You could have a bad cartridge and the printer is not reading the chip, causing this error. Best way to check is try a new cartridge.
Jun 19, 2017 | HEWLETT-PACKARD HP 2140 Fax
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
I have a two year old printer not recognizing the cartridge. The print keeps saying "INSTALL BLACK CARTRIDGE". I bought a brand new cartridge and it is not recognizing it. What should I do
You arn't clear whether this message appeared with the old toner cartridge or just with the new cartridge.
If this message just appeared with the new cartridge and not the old one, take it back and get a replacement cartridge.
If the message also appeared with the old cartridge, the printer has a problem with the drum ground connector on the high voltage power supply.
Mar 02, 2011 | HP LaserJet P3005 Printer
I replaced already new toner cartridge for my brother fax machine mfc-7220 but still the on screen message is appearing on the display "TONER LIFE END". Pls help me to solve this problem. Tnx and God bless...
I replaced already new toner cartridge for my brother fax machine mfc-2820 but still the on screen message is appearing on the display "TONER LIFE END".
Apr 12, 2010 | Panasonic KX-FL541 Plain Paper Laser Fax
C4280 photosmart printer - printer screen says "Printer cartridge missing or not detected" - I replaced the old HP cartridge that was in when the message appeared with a new HP printer cartridge in but it...
Apr 01, 2010 | HP Photosmart C4280 All-in-One InkJet...
Sending Message Problem!!
touch the START menu on the top left of your screen, touch on MESSAGING, select SMS/MMS account by touching, that will take you to your inbox. then just touch the MENU on bottom right of screen and select NEW... then touch SMS. It will ask you to add contact 1st. then touch screen where text goes till curser appears then type either by keyboard buttons or middle bottom of screen if you touch a electronic version of keyboard will appear you can use stylis to type on screen keyboard. Then bottom left of screen hit SEND. message sent message will come on screen when msg sent.... Goodluck
Apr 10, 2009 | Sony Ericsson XPERIA X1 Smartphone
"Remove and check color cartidge."
ok the problem is very common.initially remove both the cartridges.then unplug the printer from main outlet and plug back in.this will reset the printer circuit.then after u on the printer bring back the cartridge carriage to cartridge installation position.then first clean the circuit in the carriage that touches and sense your cartridge circuit with a damp cloth.both colour and black carriage circuit.then clean the cartridge circuit too even if its new.then install both the cartridges and close the door and off the printer again and on it after 30 seconds atleast.then check it should work normally.
Mar 25, 2009 | HP PSC 1610 All-In-One InkJet Printer
New cartridge won' t print.
Was the cartridges lexmark factory replacements or was they generic replacement cartridges.
If they are generic cartridges you might want to buy lexmark cartridges because some generic cartridges will not work in some printers
Mar 03, 2008 | Lexmark JetPrinter Z22 Color InkJet
Brother P-Touch PT-1830 Label Printer Logo
120 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
