Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Problem with small hoop
Hallo, I've a problem with small hoop, my machine's software don't recognize it!!! Can I help me? thanks Anna.
    Problem Solver:
  • 7 Answers
Uninstall your Futura software and reinstall.
Posted on Jun 23, 2007
Need help, I keep getting error c 12 hoop size is smaller than embroidery data, I have the right size hoop on for the embroidery design I' using.
Perhaps the machine is not recognizing the hoop you have installed. Could be a computer component or software glitch or something wrong with the hoop itself.
You might try contacting a local machine dealer for support or contact the online manufacturer support.
Dec 19, 2015 | Sewing Machines
Embroidery
When you are editing the design make sure you are actually doing it in the hoop size that you want. It may be that the design has been done in a larger hoop although it does not really require it. I can change the hoop size on my machine. Good Luck!
Oct 15, 2017 | Bernina Sewing Machines
Brother PE770 Hoop size programming stuck on small hoop option
Your machine would be able to perform 5 X 8 embroideries. The hoop size on this machine is recognized by the machine itself, depending of the embroidery file size. So it the embroidery is small, it will indicate that the small hoop is needed.
But U can use the large hoop, position the embroidery where U want then perform another embroidery on the sams hoop.
TRICK : the embroidery size exceeds the hoop? reduce it in X and or Y using this function on the machine
Jun 10, 2012 | Brother PE770 Computerized Sewing Machine
My embroidery unit does not recognize my hoop size. I am using the 240 x 150 and I have the size selector set to the size. When I try to start my project the screen says to attach correct hoop size. I...
The first thing to check is the software version on your machine. Later versions are far better at recognizing the proper hoop than the earlier versions. The current version is 2.24 . Check this by looking at the bottom, right corner of the welcome screen when the machine is first turned on. The numbers in that corner are your software version.
If you are in the 2's, then adding the latest probably won't change this problem. Make sure that when the hoop is slid into position you do not go beyond the proper position. The release button on the hoop holder should drop down fully. If it is slightly raised, pull the hoop back toward you, without holding down on the button and see if it clicks down farther. If so, I recommend that you press the button just when you start the hoop onto the machine, then release it and as the hoop slides back it will click into the hole. Wiggle the hoop a little and the button should seat fully and then the machine should recognize it. If it still does not recognize the hoop, you may need professional attention.
Apr 08, 2009 | Husqvarna Designer I
Update for 150x150 hoop
If you have a light gray button then you need to have the embroidery unit upgraded. The hoop will fit on the machine, but the machine can not recognize the hoop. The new hoop holder that needs to be installed will have a second sensor trigger allowing the machine to recognize more hoops. The original holder only has one trigger and can only recognize earlier hoops.
Contact an authorized Husqvarna repair center to have your embroidery unit upgraded.
Nov 26, 2008 | Husqvarna Designer I
Singer Futura CE 150 not recognizing small hoop
Except advices from the previous posts I suggest to check out whether you install small hoop precisely, there should not be any deflections, you need to insert it on the full length and fix it very well.
Sep 06, 2008 | Singer CE-100 Futura Computerized Sewing...
I have a futura 150 and I can't get it to change hoop settings. I will put the small hoop on it but it doesn't recognize it. What do I do to fix it. It will change it on the computer screen but doesn't on...
Do not switch on the machine with the small hoop attached. After changing the hoop reload (close and open again) the design or restart the software or select the small hoop manually from the menu.
Aug 26, 2008 | Singer CE-100 Futura Computerized Sewing...
180E Hoop problem
Joan, there are 3 micrositches on your embroidery unit arm. these switches are depressed when you attach the hoops, it appears from your comments that one switch is not functioning. This could be simple, it is out of alignment or more complex it is broken. Either way you need to take it to a professional for repair.
Dec 21, 2007 | Bernina Artista 180
Husqvarna Des 1.. won't recognize hoops
The embroidery unit needs to be calibrated. Can only been done by a trained dealer. you can relax, it is not a major issue and shuold not cost you a arm and a leg. Ask the dealer to also calibrate your touch screen and download the working hours on your machine.
Regards
dupina
Dec 11, 2007 | Husqvarna Designer I
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
77 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
