Question about Boston Acoustics MicroMedia Computer Speakers
Headphone problem I have an LG TV which doesn't have a headphone socket. Is there a jack which will plug into the audio socket and have a female socket for a headphone to be plugged into? G Jarratt
    President:
  • 1,073 Answers
Yes there is
Posted on Dec 03, 2008
CAN I PLUG IN STANDARD HEADPHONE (MALE PLUG) INTO AUDIO OUT (FEMALE) JACK WITHOUT SEPERATE AMPLIFICATION
You can't. If your set have a socket marked Headphone / Earphone; you can plug it.
Dec 06, 2015 | Televison & Video
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
When I plug the headphone jack of my philips wireles headphone into the TV, it cuts out the main audio output. What should I do?
Thats how all headphone sockets work. When u plug in jack, feed to TV's speakers is disconnected.
Aug 02, 2011 | Televison & Video
I have a VI210 big tv and want to put wireless head phone on it. I need to know if there is a jack for head phone if not where do I plug it in
Most TV's will have some kind of stereo output - if not in the form of a 3.5mm headphone jack, then in the form of two RCA outputs (Left and Right).
If you can't physically see a headphone jack on the back, bottom, sides, or front of your TV, it probably doesn't have one. However, You can plug an RCA to 3.5mm female adapter cable into your TV and plug your headphone receiver into that!
May 19, 2011 | Televison & Video
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
May 19, 2011 | LG 42LH40 LCD TV
I have purchased a 50inch plasma tv which does not have a headphone socket. I wish to use headphones with this tv - can I use the composite audio red and white jacks on the back to plug into a headphone...
Hello smiths47 34:
What you will need is a Stereo RCA to stereo 1/8" cable that will connect you to your TV. You can get it at any radio shack or electronics parts store.
You might also like this which is a wireless headphone setup for your TV or phone system.
"CLICK HERE"
If the link doesn't work then copy and past this:
http://www.radioshack.com/product/index.jsp?productId=11300844#tabsetBasic
If this helps then click the thumbs up.
Sincerely, Peter N.
Mar 22, 2011 | LG 37LC2D Television
Does my sanyo tv model DC26640 have a place for headphones?
Looks like your Sanyo DP26640 does not have a headphone jack in the traditional sense however it does have two audio output jacks (left and right) for RCA audio cables which would typically go to an amplifier with speakers. If you want strictly a headphone, what you can do is go to Radio Shack and buy an adapter cable for less than $10. You can get adapter cables for 3.5mm plugs and others. Plug your headphones in and you can listen. 3.5mm female and RCA male at the TV side.
Mar 06, 2011 | Sanyo Televison & Video
I have a westinghouse 26 diagonal LD 2655VX--tying to connect to a logitech computers speaker system-can't find headphone jack to install it. Thanks
Hello Jennyjanuary, unfortunately the headphone jack that this TV has is for audio in and you need audio out. What you will need to do is buy a 3.5mm jack female to RCA male which will make your headphone jack connection in to left (white) and red (right) audio which you can connect to the audio out on the TV. For more information on this adapter please email me at westytech@westinghousedigital.com
Jan 22, 2011 | Westinghouse Televison & Video
I connect my Beyerdynamic DT131 wired headphone to my Sony Bravia TV through the cable box, audio volume is extremely low and the headphone's volume control had no effect on the volume. I tried connecting...
The audiolevel is much to low for a headphone.
You really need to use a headphoneoutput ( if its there) or a headphoneamplifier.
You tried to connect your headphone on line-level outputs.
Regards,
Gerard
Apr 23, 2010 | Beyerdynamic DT 100 Professional...
I have a samsung NC10. I have connected to my TV via the PC cable. I can see the screen but here no sounds. I have connected the red/yellow/white audio cable to the tv. It has a jack plug on the other end....
The cable you are using is a rca audio/video cable. The colors translate to:
  • red=audio,right
  • white=audio,left
  • yellow=composite video
Your laptop headphone input uses a ⅛′ (3.5 mm) mono and stereo (TRS).
You need a Stereo 3.5mm mini phone plug male to 2 RCA female connectors.
Nov 07, 2009 | Samsung NC10-11PBK Netbook
Boston Acoustics MicroMedia Computer Speakers Logo
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
