Question about Soundstream RUB500-1 Car Audio Amplifier
Soundstream rub 500-1 mono....
Hooked up a Soundstream RUB 500-1 Mono amp and after hooking it up the sound lasted about 10 minutes and now all i have is bass. its hooked up to 2 10" Kicker Comps. and 2 8" Bass Tubes. Why May i Not be Getting any Sound? Thank you for Your Help.
U need to make sure your subs are wired correctly. And u need to make sure all your speakers are at the same ohm load. If u hook up two subs on one channel and two more on the other one u need to make sure that your subs are all 2ohm or 4ohm subs cause if u got two 4ohm subs ran parrallel then u will have a 2ohm setting and if both of them are 2ohm subs them your load will be a 1ohm load witch could harm your amp unless its an 1ohm stable amplifier.
Posted on Nov 21, 2008
My amp won't play bass everything is hooked up
I have a similar problem with my 2012 civic, I hooked up my 1800w kenwood mp to my 2 12" w6s and 1 song plays and sounds great, the rest of my songs have no bass from the subs, just the car speakers sound normal so I dont know what the hell thats all about. I thought it was a wiring issue but I can play the one song all day and it sounds perfect so any suggestions? thanks in advance
Jan 29, 2012 | Sony Car Audio & Video
I have an old soundstream reference class a 5.0 and a set of mb quart pwe 254 10 duel voice coil subs. i would like to know how to wire this set up for the most power. parrallel the voice coils then run...
The Soundstream Class A 5.0 will deliver its full power at 1 ohms mono.
I think your subs are two dual 4 ohm voice coils.
If you wire the voice coils for each sub in PARALLEL, that's 2 ohm for each sub. To get 1 ohm mono, you need to hook up the subs in PARALLEL to the amplifier, in bridge mode. That's the way to get to 1 ohm mono. Please add a fan to your setup as the amplifier will get very hot. You will need to use a relay to hook up the amplifiers and fan(s) to or you will damage the remote ouput of your HU (if you hook up the fan straight to the remote of the HU) as the remote output of the HU is not designed for the amount of current a fan draws.
Good luck. If you need help with the relay issue, have a look here: http://www.caraudiohelp.com/newsletter/multiple_amplifiers.htm
Jun 27, 2011 | MB Quart PWE-254 Car Subwoofer
Wiring power house phd2 mono amp to the earthquake 4 ohm speakers.
When i hooked up my bass knob the amp made my subs hum i unhook the rca but still humming unhook bass knob still hummin
Jun 12, 2011 | Earthquake Sound PH-D2 Car Audio Amplifier
The amp worked fine for about a year then one day the bass would not play through my subs properly sounding like a cd skipping only with the bass i would turn volume down and it would work fine until a...
When you hooked up your amp, did you hook it directly to the head unit so that it didn't come on with the car? Did you find the inline fuse in the amp positive cable? Few things to check..
Jul 13, 2017 | Kenwood KAC-6104D D Class Mono Power...
Home theater hooked up volume sounds low
Check your different settings either in your t.v. or your amp. In your menu settings you can change your audio. Bass trebile etc. and even sometimes switching it from stereo,mono, dolby digital will increase your volume. Dolby digital is very quiet if your not running and exteranal amp system. so try changing it to stereo and your volume should increase.
Aug 31, 2009 | Panasonic Audio Players & Recorders
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
I bought a 500/1 jl audio amp and also a w7 10 sub
if its cutting off and right back on then check your ground and your power wire makes sure both are connected good and none of your fuse's are blown, either that or you got a wire hooked up backwards in the sub.. but my guess is that the sub is hooked up wrong... that sub should be hooked up in a series or in parallel,
ok if your running just one speaker, it should be hooked up like this and 2 speakers are a different way...
this is parallel :pos to pos , neg to neg, then one wire coming from pos on sub to pos on amp then neg on sub to neg on amp but bridge the amp on your amp should be 2 pos and 2 neg in two different channels take the pos off the sub into the pos on 1 channel and then the neg from sub to the neg on the other channel,
this is series : on the sub it will go pos to neg then the other neg and pos will go to the amp, but make sure the pos and neg r on different sides of the sub, dont hook them both to the same coil
if your need more help give me your email and ill send you a pic of how to do it...
Aug 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
My Kenwood KAC-X1R hooked up to (2) Kicker Solobaric L5's
first get a deck with 4 volt pre outputs or more that will help a lot then a battery in the back will help like a 1000cca or more
Dec 30, 2007 | Kenwood KAC-X1R Car Audio Amplifier
Soundstream RUB500-1 Car Audio Amplifier Logo
295 people viewed this question
Top Soundstream Car Audio & Video Experts
richie46
ray gallant
Are you a Soundstream Car Audio and Video Expert? Answer questions, earn points and help others
