Cannot Access database (error=49153)
I have a machine running on Accpac 5.2 and pervasive as the database and everytime I try to log in I get this error message.
Cannot Access database (error=49153)See help for more information.
  • master1297 Jan 11, 2009
    i have sgl server running i ahve successfull connection i tested by obdc but when i open the application i get the message a bove
    Champion:
  • 401 Answers
You may fix this error through how to fix access file error
This guide will aid you http://www.fixaccessfile.com
Posted on Jul 08, 2013
We are using Oracle, but you may want to try these:
  1. Go to ODBC in Control Panel, and test the Connections
  2. If it still doesn't work, Go to Services in Administrative Tools, and try to restart it (the seervices)...
It worked on us...
Posted on May 19, 2009
How to resolve error code f120 toshiba estudio 255
Database abnormality: Database is not operating
normally.
1. Check that no jobs remain and rebuild the databases. ([5]+ [C] + [POWER] -> 4. Initialize database -> 1. LDAP DB
and 2. Log DB (Job,Msg).
2. If the error is not recovered, reinstall the system software.
([4] + [9] + [POWER] -> 4. System Software(HD data))
Notes:
• If you rebuild the databases with a job remaining,
delete it after finishing.
• When "Rebuilding all databases" is performed, all
data including log/user/role/group/department
information and address book data are deleted. If
you back up the data in advance, they will be
recovered by restoring them after rebuilding the
database
Nov 15, 2017 | Toshiba Office Equipment & Supplies
Toshiba e-studio 356SE error code f 121 Database abnormality user information management database
user management database is corrupted.
Delete the log in the following procedure:[5] + [C] +
[POWER] ? 4. Initialize database ? 1. LDAP database
(to delete user database) (Note that all user, role, group
and accounting data will be deleted.)
Jul 14, 2016 | Toshiba E-Studio 356 Multifunction Copier
Could not connect to MySQL
Hi;
You can start/stop the mysql service on the server by logging into the server as root from the command line interface and run the following command/s.
service mysql stop
service mysql start
service mysql restart
You can also use the following if the above does not work fine.
Fix Toolbox for MySQL
https://www.fixtoolbox.com/repairtoolformysql.html
Jul 07, 2016 | Wolfgang Schmuck MySQL
Repair MS Access database without having program installed
Use Recovery Toolbox for Access developed for recovering data from corrupted Microsoft Access databases. The MS Access recovery tool is capable of repairing MDB and ACCDB database files.
For more: https://access.recoverytoolbox.com/
Oct 18, 2015 | Microsoft Office Computers & Internet
Cannot open Peachtree Complete Accounting 2007 as error message states cannot connect to pervasive 9
Apparently your Peachtree system is linked to Pervasive database stuff.
It is possible your system remotely connects to pervasive or you have pervasive software on your machine. It is possible that you subscription to their service ran out OR a change has been made to your Pervasive stuff or computers it operates on that has made it impossible for your Peachtree software to access the databases it is tied into.
If you connect to Pervasive remotely, then check your internet access and subscription status.
Nov 10, 2009 | Computers & Internet
Error 3343 when I start PC Charge, how can I fix this?
error 3343 is a database error. Unfortunately, PCCharge is still in the stone-ages of computer technology and they think VB6.0 and MS Access 2.0 are stable and secure ... At any rate. 3343 is simply an unrecognizable database, in this case due to corruption. There is a program in the PCCharge directory called VisData. This will allow you to run a repair and compact the database. To use:
First make a backup of your PCCW.MDB database in your PCCharge directory (C:\Program Files\Active-Charge (PaymentServer); C:\Program
Files\PCCW (PRO)).
Execute VISDATA.exe.
File -> Repair MDB.
Select the PCCW.MDB database from your PCCharge directory.
Select 'No" to open Repaired Database.
File -> Compact MDB ... 2.0 MDB
Again, Select the PCCW.MDB
It will then prompt for what you want the database to be named. Simply select PCCW.MDB again, select 'YES' to replace existing database.
Select 'NO' to encrypt database.
Select 'NO' to Open Compacted database
Exit Visdata and start PCCharge.
It would also be a good idea to go ahead and update to the latest available Scripting Runtime library. This can be found by going to microsoft.com and searching for the phrase 'windows script'. (To my knowledge, 5.7 is the latest version).
Jul 16, 2009 | Go Software Inc. PCCharge Pro...
Everytime i try installing sage peachtree on xp sp2 system keeps asking me to update pervasive
You probably have a earlier pervasive version installed or no version. You will get this error when either of those occur. Pervasive workstation is all you need. There should be an option to install it from the peachtree cd. If not open the cd and browse for a pervasive directory and run the setup.
If they didn't include it then you can download it from Pervasive. You should get V10 workgroups install and that error should go away.
Mar 12, 2009 | Sage Peachtree Premium Accounting 2009
COMPANY IS MISSING!!!
try checking to see if the company exists in the database setup.
you need to make sure the company database is linked to the system database before it becomes available to use. if it is there, delete the links and recreate them
Feb 22, 2008 | ACCPAC Simply Accounting 2004 PRO...
Computers & Internet Logo
3,334 people viewed this question
David Payne
David Payne
