Question about Philips Magnavox 9P6034C 60" Rear Projection Television
NO HIGHT VOLTAGE
I HAVE PROBLEM WITH HIGHT VOLTAGE EVERTHING LUX IS WORKING EVEN ALL THE TRNSIST. AND IC CONSUM AND GETS HOT
BUT NO HIGHT VOLT.
TO THE PIC TUBE THIS USED 3 MODULE
  • Philips Master
  • 8,617 Answers
Sounds like the LSB is defective as that controls all the high voltage and deflection circuits. If you go to the following link and leave them a email with your model number they should have a LSB board for your model.
http://servicemanuals.vstore.ca/
Posted on Nov 23, 2008
Im trying to repair a Bx4500h. there is not output, the preamp sections works and the transformer works. I tested both. Im thinking its a problem with the 3080 IC underneath the amp board. Theres 2 cables...
Well, first off, if this is an IC output, depending on the rated watts per channel, you will certainly need a rail volt greater than + - 15V. That would be for a regulated voltage somewhere else in the amp.
Mar 07, 2015 | Audio Players & Recorders
I have a 1992 mercury capri and was wondering my battery is over charging my dash volt indicator needle is on hight and I have all my lights are working all fuses are good not blown except my low beams I...
Voltage regulator inside the alternator is probably stuck closed. It is unlikely that the low beams not working is connected to that problem. mostly the low beam bulds are burnt out or something is wrong with the wiring or the dimmer switch.
Dec 17, 2014 | Cars & Trucks
How can i Set Haier tv, my haier 14'' CRT change With 21'' CRT so vertical Hight is short, how can i adjust vertical hight.. IC "Trident TDA 11105 PS/V3/3/AP3
You can check it by reducing the value of the resistor, connected to ground at one end of the deflection yolks' vertical scan out windings. Usually, this resistor will vary a value of 1.2 Ohms to 2.2 Ohms. But, if you reduce this value too much, to say at about 0.15 Ohms or so, there is a possibility of damaging the vertical scan output IC.
So, do this very carefully. It is a trial and error process.
Check it with gradual reducing this value of this resistor; by 0.25 Ohms at a time. Wish you success. I hereby advice you, assuming that the horizontal width of the picture is OK.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
May 05, 2014 | Haier Televison & Video
I have a Maytag Centennial electric dryer I have just installed the electrical cord but it will not work I am getting sufficient voltage at both hot leads at the outlet with an even split in voltage when I...
-Here do some test as below:
-Turn your meter to 720 Volt AC.
-Hook up meter to both hot line at outlet. You should have 240 volts.
-If yes. Then Next red lead to 1 hot and black lead to neutral at outlet. Do you have any volts..? (You should have 120 V.)
If Not. the Neutral line has bad connection between outlet
and breaker panel.
-If Yes then check the wire that you just replace.
Good Luck
Mai Lor
Dec 20, 2013 | Dryers
Hi , i have a trinitron kv 21, and it has a problem , the problem is: when i start the tv , it has narrow picture and hight of picture is short , and after passing time picture is going to be better a...
Hello
You haven't mentioned anything about your Sony TVs model number. Yet I'm answering to you, considering it as a general problem for Sony.
Your set's vertical output section has the trouble. Normally Sony uses a 9 pin Ic for this section for their 20 tvs, starting with LA' Series. This is a small IC vertically mounted on the circuit board,and screwed on to a heatsink plate. Just replace the capacitors around it first. Most of the electrolytic capacitors will go reduce in its capacitance value with time. Check the input voltage to that IC also. This input voltage is usually derived from the Line Output Transforemer's [LOT], secondary winding, and come upto 28VDC or so. If this voltage is very low, the retifier diode connected to the respective winding of the LOT may faulty. Replace it with same type and number.
When replacing electrolytic capacitors, keep a keen look on its polarity,as tthey ahve both positve and negative terminals, and should be coincide with the printed circuti board. otherwis it will burst off when supply is charged.
Replace all of them including the majn smoothing capacitor to the IC voltage. If these does not help, replace the vertical output IC. It will not cost too much. OK.
Dec 16, 2010 | Sony Televison & Video
Mixer not working and board getting hot
There is likely a voltage regulator or a diode burned out in the vicinity of the power supply. If you have the schematic, start at the power supply and work through the circuit to the I.C. Also look up the pinout on the internet for that I.C. With the power on test the voltages at each pin on the I.C. You should not have supply voltage readings on any of the signal pins. This is an indication that the I.C. is also burned out. Use a volt ohm meter with a D.C. voltage setting. Also hopefully your meter should have a diode test function. If not you can still test them with the resistance test function.Here is a link to an explanation:http://www.elexp.com/t_test.htm I hope this helps.
Mar 03, 2010 | Vestax Pmc 280 DJ Mixer
I have a 50 inch lcd tv,the sound works but no picture. What could be the problem?
your problem is in the video section check your video ic 201 the number 1 pin should be getting 5 volts dc input if the voltage is absent then checkQ 210 it could be bad replace it.if the 5 volts is present check the ic output for 125 volts dc if absent replace ic.good luck.
Feb 27, 2010 | Televison & Video
Help
resolder the vertical IC that is whats making the CRTs go blank. Its a safety issue where the CRTs blank when there is no vertical deflection. Just resolder the output IC that should cure your problem
Mar 12, 2008 | Toshiba 43H70 43" Rear Projection...
Viewsonic VG919S 19" LCD
Hi
You must focus to mainboard of LCD monitor find the voltage regulator IC. Voltage test the regulator IC use digital or analog multimeter range 10v dc connect the negative to cold ground, these regulator providing a constant supply of 2.5 - 5v to all IC in the mainboard. check the scalar IC. Because scalar IC will convert analog input signal of Red, Green & Blue. Lastly check the controller board, check the ribbon cable connector from mainboard to
controller board for lose, check the fuse inside controller. I think the exact problem of your monitor could be either the (mainboard) or (LCD panel where the controller board is located).
Oct 06, 2007 | ViewSonic VG910S (Black, Silver) 19" LCD...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
