Question about Windchaser HUL60 1.8 Gallon Humidifier
No mist coming out
I have the Windchaser HUL60 1.8 Gallon Humidifier. This is the 3rd season I've used it. Just took it out for the winter season and the first couple of days it worked fine. Now now mist/steam, etc is coming out of the top like it's supposed to. It's set at 45%. The display is showing it's only at 35%. It's thoroughly cleaned every year before its stored away. I don't know what the problem is.
Tank is full, but after a few minutes why does it stop and the 'Tank Empty' light comes on?
Reset light comes on, unit stops operating when tank is full ...
www.fixya.com/support/t384577-reset_light_comes_unit_stops_operating
Feb 6, 2008 - Question about Vicks Warm Mist V745A 1 Gallon Humidifier ... Tank is full. ... for about another 5 minutes when the unit stops, reset light comes on etc. ...the humidifier since the reset light keeps going on immediately after I turn ... water in the tank because of course, the heater is on, but no water is getting ...
How to Fix a Humidifier ' HomeTips
www.hometips.com/repair-fix/humidifier-doesnt-work.html
Jan 17, 2016 | Humidifiers
Venta Sonic VS205 Humidifier turns and has the green light, makes a buzzing sound, but no mist is coming out.
If you see mist in unit and not coming out fan motor in base of unit bad. Four screws in base and fan unplugs
Aug 20, 2011 | Venta Airwasher VS 207 3.7 Gallon...
I added water and the vicks medicine and no steam
medication was never meant to go into a humidifier. it clogs the transducer. if you can clean the vicks off the transducer plate you might squeeze another season out of it, otherwise by adding medication to the machine you just gave it an early death.
Oct 23, 2009 | Vicks Warm Mist V745A 1 Gallon Humidifier
Produces a ton of white dust... Why???
Your V5100N ultrasonic humidifier generates a fine mist by vibrating the water at an exremely high speed. The water doesn't actually evaporate until after the water mist is in the air. As the tiny water droplets evaporate in the air, the calcium and other minerals settle on your floors and furniture.
Humidifiers that evaporate the water in a filter wick, or with heat, do not generate dust because the water evaporates inside the unit and the calcium is trapped inside.
You can avoid the dust problem with your humidifier by using distilled water. Distilled water is available in most stores that sell bottled water in gallons...but be sure to choose "distilled" water, not "purified" water. Try the distilled water in your steam iron also...if you have one. It will last longer.
Feb 29, 2008 | Vicks V5100N Humidifier
The humidifier doesn't make enough vapor
Soak it with vinegar for several hours then use a soft nylon bristled brush to scrape off the minerlized crust and rinse. You probably need to replace the silver stick & mineralization cartridge more often.
Jan 04, 2007 | Air-O-Swiss 7133 Humidifier
Windchaser HUL60 1.8 Gallon Humidifier Logo
23 people viewed this question
Top Windchaser Humidifiers Experts
Paul Carew
Dennis
Marvin
Marvin
Are you a Windchaser Humidifier Expert? Answer questions, earn points and help others
