Question about Zanussi FJS1225W Front Load Washer
Oil and noise coming from my washing machine
My front load washing machine makes an horrendous noise when it spins . It has also deposited a load of oil over my wash. There seem to be some very small particles of something, no idea what, over some of the clothes. Some of these particles seem quite hard. The machine is about 5 years old, maybe 6. It first left oil on clothes about a dozen washes ago and I thought perhaps I'd accidentally left something amongst the clothes (my husband does a lot of motorbike mechanics). The noise started just a few washes ago. Any idesa anyone?
  • Anonymous Mar 14, 2014
    i had accidentally fall a small cloth wlhilecleaning the opening of the washing machine. How can i remove it and is it harmful?
I have had the exact same problem, when i pulled the whole thing apart i found the spindle which holds the drum in place, 2 of the three spokes had broken.
Posted on Mar 22, 2007
I would think that the bearings have gone,spiin empty tub by hand and a rumbling noise will confirm also removing the rear cabinet will probably reveal a trail of rusty water down the outer tub.the answer is new shaft £40 and a bearing kit £22 your husband should be able to try it af as you say he is mechanically minded
Posted on Dec 19, 2006
Washer makes horrendous noise while spinning whats wrong ?
jill...THIS IS A TOTAL GUESS? If you overload a washer....it may do this. Also...sometimes you have to adjust your load in the spin cycle...as the high speed rotation to remove the water will cause a radial vibration because of the weight being out of balance. If it does it with any size load...then you probably need suggestions from someone else or a local repair person.
You may also want to go to the manufactures web site and see if they have any trouble shooting suggestions there. Would also help if you post the brand of machine/ upright or front loader....how old and of course the machine should be on a level surface or be leveled. Good Luck! Goodn
Feb 03, 2015 | Washing Machines
Machine making loud noises w6863 front loader
could be that the wights are coming loose on the drum turn the drum by hand and see if you can feel any movement in the drum if yes get them looked at also try some oil on parts
Oct 12, 2014 | Washing Machines
Indesit WIL143UK knocking noise
Most likely the suspension gone a bit loose. Try with lesser load
Nov 10, 2013 | Indesit W 123 Front Load Washer
Roper washing machine is not agitating. Makes a horrendous noise when supposed to be aggitating. No noise when filling with water.
In addation to the agitation does it make the same noise in spin??
If yes it makes that same noise in spin the problem is going to be a broken motor coupler. I have written this tip about a broken motor coupler it will show ya how to take apart the washer and replace the coupler. http://www1.fixya.com/support/r10293994-whirlpool_made_washer_not_agatating
GENE
Oct 10, 2011 | Roper RAS8445KQ Top Load Washer
Kenmore washer MOD 110.24422300 SER CP4427442 the washer wont spin, it makes a harsh and loud noise when it comes onto the spin cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 20, 2010 | Kenmore 12502 Top Load Washer
It will spin but the water does not come out, then it makes a funny sound-like a high rattle noise. We have never had any problems - we checked the hoses, they are clear. I has worked like a tip for years,...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Aug 29, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My piece of **** whirlpool duet washer is making a horrendous grinding sound and won't finish a wash cycle or drain! Help?
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
May 28, 2010 | Whirlpool WFW8300SW
When in the spin cycle it now makes a horrendous noise
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | GE WPXH214A Front Load Washer
Location of bearings on a zanussi fla100w
how do you change bearings on zanussi fla 1101W
Jan 11, 2010 | Zanussi FLA1101W Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
167 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
