HPvs19e The pic link does not work. Can you send the pic plus the specs for the caps? Many thanks.. Ken
  • 2 more comments
  • Anonymous Jan 06, 2009
    monitor wont turn on
  • Anonymous Jan 19, 2009
    Cap Xon, 1000 uf 10V, KF 105 deg C, P602 vent
    (3) capacitors identified on the board as: C822, C823, C824
    note, i had same problem, ordered these capacitors on the web, total cost including shipping was $3.20, i installed them and now my monitor works perfectly. only one looked buldged on the top, but replaced all three anyway.
    could only find 1000uf 16v 105C hi temp, but a little higher number is ok from what i was told.
  • Scouse_01 Jan 20, 2009
    Can anyone tell me how to get the back of a HP Pavilion f1930, as I'm having the same problem and it may be the capacitors as you mentioned.
    Michael.
  • baytownbert Apr 21, 2010
    I cannot heat the solder up enough from the backside to release the capacitors. Am I doing something wrong?
    Scholar:
  • 140 Answers
Ken:
Here is additional info requested, the hardest part is cracking open the monitor case. Prior to working on this you should check to be sure the capacitors are discharged. A good way to do this is to connect a 12V light bulb across the terminals and when it goes out the cap is dicharged. You can also have a look at this page ( http://ezinearticles.com/?The-Right-Way-To-Discharge-Capacitor-In-Switch-Mode-Power-Supplies&id=64778 )
Spec is:
They are the 3 right above where the multi color wiring harness plugs into pwr supply board shown in lower right of pic.
John :).
Posted on Nov 23, 2008
I confirm that replacing the 3 capacitors mentioned with Radio Shack (1000uf 35V) worked perfectly for me in my HP vs19e. Thanks everyone for the guidance!
For others information, my board looked completely different, and I had to actually remove the board entirely to replace the capacitors.
David
Posted on Mar 20, 2010
Hi that was great info,I replaced the same three 1000 uf 10V capacitors and the monitor works fine,all three imploded and bulged ant the top.
Posted on Dec 29, 2008
TO FIX LM727; JUST FOLLOW THIS GUIDE
http://zorg.tripod.com
BY KELVIN M; REF ZORG.TRIPOD.COM
Posted on Nov 15, 2010
2007 TVS Scooty PEP Plus oil meter always reads maximum
Hi, Parimi you may have a faulty oil sensor for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.datamanagement-le-blog.com/tvs_scooty_pep_plus_service_manual_download.pdf
Shop At TVS SCOOTY PEP Bike Parts And Accessories Online Store safexbikes...
TVS Scooty Pep Plus Owner Manual
TVS Scooty Pep Plus Price Specs Review Pics Mileage in India
TVS Scooty Wikipedia
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 28, 2017 | 2007 TVS Scooty PEP Plus
How can i send pics from my mytouch ph to messenger
Download text plus and that will help you send photos text and even make calls to other textPlus users you need to use a earphone with a mic to make calls
Aug 05, 2014 | Android Apps
I am looking 4 the torque pressures (ft.lbs) on the main crank bearings, and rod bearings on a 2007 Ford 5.4 3 valve engine??? Gerry..............thank-you
mains - vertical bolts first 30 ft.lb. PLUS 90 degrees
pattern frt
8 7
4 3
2 1
6 5
10 9
side bolts
22 ft. lb plus 90 degrees
pattern frt
7 8
3 4
1 2
5 6
9 10
connecting rod caps cracked type rod-rod and caps must be kept in matched sets, recommend new bolts/nuts, spec is 32 ft lb. plus 105 degrees - torque each item to the correct torque then go back and do the degrees. these are torque to yield bolts and the procedure is very important.
Oct 02, 2010 | Ford F-150 Cars & Trucks
I have a Kodak Easy Share CD82 camera and I need to send pictures that are no larger than 2MB. Can you help? Thanks, Ken
Just right-click on the picture file on your computer and choose e-mail. You will be given the choice to make smaller images. Choose one and your e-mail will open with the pic already loaded at the correct size without changing your original.
Jun 15, 2010 | Cameras
White lines across stiils
You can suspect that the ccd has a problem. Here is a link to Canon Repair .
Call the Canon Repair 800 number, they will pay to and from plus repair the camera to fact. specs.
Sep 21, 2009 | Canon PowerShot A95 Digital Camera
Need to find a photo capacitor for a sb-600 flash
http://www.jamicon.com/capacitor.html
you may use 680uF-1000 but 350-400Volt.
Check Voltage,be carefull!!!!!
in you system voltage exeed nominal level 330V! may be 350-360V-result die capacitor.
For normal use capacitor on 330v good maximum voltage wil be ~280V.
sorry for my english)
Best regards,AlexOn
Sep 03, 2009 | Nikon Speedlight SB-600 TTL Flash
Samsung z510
Feb 23, 2008 | Samsung SGH-Z510 Cellular Phone
Line in picture
Send me a Digi-pic of the screen please.. Good starting point..
ken@ikenfixit.com
Jan 09, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
VS19e problem
Most of the time the power capacitors on the power supply have gone bad. There are three of them in the power supply, 1000uf 12v on the left side of the dual transistor heat sink looking at it with the heat sink toward you. Go to Radio Sh and get three new ones(1000uf 12v min, as long as they fit 1500-2000uf 12-16v? does not matter) and solder them in. The hardest part is taking the front basil off the monitor. there are no screws, insert something strong and thin where the two half's come together and carefully start it apart. The LCD unit comes right out along with the power switch board. Remove the two screws at the bottom of the power board. The for back-light plug in's and the two screws from the main AC plug. The other plug in is a multi wire that unplugs from the other board. Replace the capacitors and reassemble. This goes wrong with this model all the time and is not as hard to do as you may think. What do you have to loose? Most likely save $150 bucks.
Jan 02, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Open Questions:
Steps To Fix Toshiba Laptop virus and Freezes Issue Call toll free Number :+1888784-9316 Are you facing sudden pop-ups on your computer or witnessing slow loading of files and programs? If you are getting issues like slow internet and processing, unexpected computer behavior then contact Toshiba support for making your computer free from all such dangerous online threats. Toshiba support provides safe and secure removal of all virus and other infections along with protecting the system from any such instances further. Toshiba support providing technicians make sure that your pc is secure and also that all your important files and documents are safe from any type of harm. If your system is infected with viruses, Trojans or malware then it might show signs like slow computer processing and internet speed, unexpected computer behavior, sudden freezing and crashing down of the system, frequent arrival of error messages, many advertisement pop-ups, non-intended outgoing emails and messages to contacts, files disappearing, problems in hardware and accessory devices, screen freezing and image blurring issue etc. Toshiba support helps in scanning all the variants of virus inhibiting the system by using proper scanning process and removal processes after that. Many a times, user while scanning viruses on his system might not be able to remove all even after many attempts. This happens because system gets infected to new variant of virus due to vulnerabilities of programs used in that system or because of inefficient scanning methods. The anti-virus program used for scanning the presence of that virus might not have got that virus's signature. So, for proper and efficient scanning of all viruses and removal afterwards, it is necessary to take help from experts like Toshiba support technicians. These technicians utilize the efficiency of advanced techniques and much better tools to clean the system and make it infection proof in order to yield greater productivity. Specialists of Toshiba support collect samples of all the variants of new and recent viruses and update the user's software database with their signatures. In case your system is also suffering from the infection of any such viruses which is new and is creating trouble getting detected, then contact Toshiba support us for help on their toll-free Toshiba customer helpline number +1888784-9316 anytime for expert supervision and advice.
Aug 14, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
1,720 people viewed this question
Alun Cox
David Payne
David Payne
