Question about Tappan 18 in. MDR251RE Built-in Dishwasher
No place to install by sink
We have no place to install a dishwasher right by our sink. We really don't want to move a portable all the time. Is it possible to install one across the room if you have access to plumbing and drains in the basement. Thanks
    Sergeant:
    Champion:
  • 251 Answers
Yes it is possible Here to help Shaun
Posted on Nov 21, 2008
Hose/ Adapters for older Maytag Portable Dishwasher
The sink faucet may have to be modified by installing an adapter.
Jun 22, 2017 | Maytag Dishwashers
There is water leaking down the electric wire at the bottom of the unit. What could cause this? the unit works just fine.
Once disposal rusts out, it needs replacement.
Usually if sink basket seal is broken or if dishwasher attachment is leaking, you can feel water near top of disposal.
Use paper towel at top to see if that area is wet.
If top area is dry, then water is coming from inside disposal, and disposal is rusted out.
If sink seal is still good, we used to buy same brand disposal and re-attach to same sink basket. That's the quick fix.
If this is inside your home, you probably want to install new sink basket that comes with disposal.
To install new disposal, also buy container of plumber's putty to seal sink basket.
Remove disposal.
Clean off old putty on sink. It will chip off easily.
Apply finger-thick amount of plumbers putty to sink opening.
Set disposal sink basket into putty and push down.
Tighten screws on bottom of sink basket.
Wipe away excess plumber's putty from sink so it looks nice and smooth.
Before lifting disposal into place, attach electric wires and attach dishwasher hose to disposal.
Use hammer and screwdriver to remove steel blocker located inside dishwasher stem ... the blocker is left in place if no dishwasher hose is attached.
Disposals can be different: But here's the usual sequence:
Lift disposal with one hand and hold level. Push up strong while rotating attachment ring until ring grabs bottom of sink basket.
If you cannot lift disposal with one hand while rotating attachment ring with other hand, use small bottle jack from auto-parts store. And put piece of wood between bottle jack and aluminum disposal so disposal doesn't break.
Here's how to handle tubular pipes below sink:
Any tubular pipe joint that moved while removing or installing disposal, has to be taken apart, cleaned and re-attached.
If washers are plastic, then clean and re-use.
If washers are rubber, then replace each washer with new rubber washer.
When reattaching tubular pipes, apply generous amount of rectorseal over each plastic or rubber washer for first-time seal of tubular pipes.
Nov 19, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Dishwasher not draining properly. How much water
Its likely to be one of the following
a) a partially blocked drainhose
b/ the solenoid on the drain valve not opening closing probably
c) a blocked drain valve with a piece of bone or debris
This article should help you:
Dishwasher Basics The main parts of a dishwasher are: Control mechanism
The control mechanism is located inside the door behind the control panel. Many units use a simple electro-mechanical system: a timer determines how long each part of the cycle lasts and activates the proper function at the proper time (such as the detergent dispenser, wash spray and draining functions). Units that are more expensive might have a computerized control system. Modern units also have a door latch that must be closed for the unit to run. Some also have child safety locks. Intake valve
This is where water from the home's water supply enters the dishwasher. The unit's pump doesn't pump the water into the basin – when the intake valve opens, water pressure drives the water into the unit. Pump
An electric motor powers the pump. During the pump cycle, the pump forces water up into the spray arms. During the drain cycle, the pump directs the water into the drain hose. The motor-pump assembly is mounted beneath the basin, in the center of the dishwasher. There are two main types of pump:
  • Reversible
    These pumps switch between pumping water to the spray arms and pumping water to the drain by reversing the direction of the motor. Reversible pumps are usually vertically mounted. dishwasher-11.jpg
    -->Reversible pump
  • Direct-drive
    The motor runs in one direction, so the direction of flow is switched from spray arms to drain by a solenoid that opens and closes the appropriate valves or switches one hose connection to another. Non-reversible pumps are usually horizontally mounted. dishwasher-12.jpg
    -->Direct-drive pump
Dishwashers can be installed in either a portable or a permanent configuration. Portable units have finished sides and top that can be used as a countertop. When not in use, the machine sits in place next to the wall. When it's time to run a cycle, the unit can be rolled on casters over to the sink, where it connects to the faucet and plugs into a nearby outlet. In a permanent installation, the dishwasher goes underneath the existing countertop and bolts into place. Hoses underneath the kitchen sink connect directly to the hot water line and the drain line, and the unit usually plugs in under the sink as well. Both types of installation require a 120-volt grounded line.
Jun 07, 2009 | Kenmore Dishwashers
What is error 002 on Beaumark Dishwasher BM-DW 9702-SS
Error 2 = Longer Draining Time. The installation of the Drain Pipe is too high.
Apr 21, 2009 | Dishwashers
Can't find replacement rubber seal for sink attachment
if it is on the hose then it should be a check valve.
Nov 24, 2008 | Dishwashers
Portable Dishwasher
I sent you and email with some instructions, Look to hear from you soon!!
Mar 25, 2008 | Kenmore 17252 Free-standing Dishwasher
Kenmore 18inch Portable Dishwasher
how is the water flow at your sink this is a portable right un screw the connector at the sinkand check the screen 2 your fill hose could be kinking up when you pull it out take a light and look down into the washer see if you can see it kinked we will go from there
Dec 31, 2007 | Dishwashers
Dishwashers Logo
57 people viewed this question
Top Tappan Dishwashers Experts
Ronald Rissel
Melissa Martin
Melissa Martin
Trevor Turner
Are you a Tappan Dishwasher Expert? Answer questions, earn points and help others
