Question about Honeywell Programmable Thermostat Heater
Honeywell rth7400 keeps turning furnace on
I just installed a Honeywell RTH7400. I did go through and make sure the settings are for my furnace (2 stage heat 1 stage cool). I have the heat set at 62 and the temperature says its currently at 62 but it keeps kicking in anyway. It will stay off for about a minute or so and then kick right back in. I know this can't be saving me energy. Help!!
  • Anonymous Jan 04, 2009
    I have the t-stat set at 66 and 68 for different times of the day and for different days. However, the furnace runs for a few minutes, then shuts down and within 30 - 40 seconds it starts up again.
  • 27 Answers
Check your heat antisipator setting make sur eit matches your tpye of heat. also, do you have a 2 stage heating sys?
Posted on Nov 26, 2008
Honeywell thermostat blows cold air on heat
Thermostats don't actually blow anything, the heating system might though. Check the breakers for your heat system, then call a heating specialist. They're really not that expensive.
Oct 06, 2014 | Honeywell Heat/Cool Thermostat
I have just installed a RTH7400/RTH7500 thermostat. The wires are seem to be in the correct place, all functions are working, with the exception of no heat will come out, only cold air? I have set all...
Check function 0170 to make sure it is set on the proper type of heating system. Its a long list and specifics of system type make a difference. Also, Ive learned the hard way to always go by function, not color of wire. If you tossed the instructions they can be found on the Honeywell website https://customer.honeywell.com/resources/techlit/TechLitDocuments
Nov 16, 2017 | Honeywell Focus 6300B 5-2 Days...
My husband just installed the Honeywell RTH2310 thermostat. The fan turns on, but the furnace does not. What's our next step? (It's a natural gas furnace and he made sure that it is on correct h/e setting....
need to make sure there is a jumper between RC and RH if the red wire is connected to the RC terminal the heat wont work you will need a jumper wire to tie the RC and RC together with the red wire.
Oct 20, 2009 | Honeywell Focus 6300B 5-2 Days...
New thermostat honeywell RTH7400 cycles oil furnace every 10 min.
rth7400 maintains a 1 degree differential in temp so 10 minute cycles are not unusual.
Vinnie
Jan 02, 2009 | Honeywell Programmable Thermostat Heater
Where does the T Wire go on the RTH7400
the t wire is for an outdoor anticipator reset. If you dont have a terminal on your thermostat it does not have to be used. Just tape it off.
Nov 18, 2008 | Honeywell Programmable Thermostat Heater
RTH7400 thermostat installed-screen display unlit-used page 10 wire installation. Used heat pump wiring-which does not show W2 and Y2 on heat pump schematic, so used conventional displayed W2 and Y2...
w2 and y2 are used for 2stage applications
w2 = 2 stage heat
y2= 2 stage cool
If your system is a single stage system, look for the y1 and y2 terminals. If the thermostat does not have y1 and y2 then you may have the wrong thermostat. As always, please read the directions carefully. Thanks!
Jul 03, 2008 | Heating & Cooling
Changing Thermostats
This is one where you will need a good control man or woman. The American Standard ASYST system is not intended for the homeowner to change out. It has a room sensor wire that others do not account for.
Jan 15, 2008 | Honeywell Programmable Thermostat Heater
Honeywell 5+2 day programmable thermostat will keep heating to 29 degrees!
Is sounds like you wired it correctly, The black is a little unusual perhaps its blue, anyway, try disconnecting the wires from the thermostat and see if it shuts off. If so, then it may need to re calibrated. I will need some more info to help you anymore.
Dec 03, 2007 | Honeywell CT3200 5-2 Day Electronic...
Heating & Cooling Logo
354 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
