Question about Copystar CS-1620 Copier
Double sided copies.
I have begun a new job and cannot locate the instruction manual.
Can you direct me on how to make double sided copies?
Thank-you!
  • ellenlangril Nov 21, 2008
    CS 1620
    TY!
  • ellenlangril Nov 24, 2008
    Thanks for your help!
    Genius:
  • 1,847 Answers
May i have the model no# for your copier?
Posted on Nov 21, 2008
Double sided copies
Your printer has Duplex printing Capabilities. However when you are ready to send the print job, open the Printer Properties and select Double Sided.
To copy a Double sided document, insert it in the ADF (Automatic Document Feeder) and open the copy settings on the machine and select Double sided.
Jan 07, 2014 | Office Equipment & Supplies
E-Studio 281c is it possible to scan a double-sided document on this machine? thank you.
Welcome to FixYa!
It cannot do double sided scanning but can do double sided copying.
Thank you for using FixYa!
Jas247
Mar 24, 2011 | Toshiba Office Equipment & Supplies
I was wondering if there is anyway that you can make double sided copies and if so how??
Only copiers fitted with a duplexing unit will automatically make a double sided copy. I assume yours does not have this accessory.
You can always make two sided copies manually. You need to first work out the paper path, so mark one piece of paper with an arrow showing the top and the direction the sheet was placed on top of the paper feed tray. Make a copy and you will now know whether the top or bottom of the paper as loaded gets printed on. Now place that sheet back in the paper feed tray again with the arrow face down in the paper tray, but still pointing in the same direction as before. Print side two and you will now have a double sided copy. If the reverse of the copy is facing the wrong way then you know that the paper needs to go into teh paper tray with the arrow facing you. Hope this makes sense, but it just needs a couple of trial runs to get to understand which was round to put the paper back in for the revers side to be printed. Always keep the final successful double sided copy, marked up for future reference, as it is so easy to forget which way to put the paper back in several weeks later.
Oct 01, 2010 | Copystar CS-2030 Copier
Instructions for copying double sided
at the main menu of the panel, select "SIMPLEX DUPLEX" option,which is at the right side of the lcd screen, now in "SIMPLEX DUPLEX" option select "DOUBLE SIDED" original to "double sided" copy option and then press the start button...............
Mar 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Simple, step-by-step instructions on how to fix Error 1311 in Windows XP -- this error popped up when trying to repair/fix original installation of Microsoft Office 2003 -- not very computer savvy, but can...
Hello
Thank you for using
FixYa for your problem
To resolve this problem, copy the contents of the Office CD to a folder on your hard disk, and then run Office Setup from this folder. To do this, follow these steps:
  1. On your desktop, double-click My Computer.
  2. Double-click the local on which you want to create a new folder.
  3. On the File menu, point to New, and then click Folder.
  4. Type a name for the new folder, and then press ENTER. For example, type OfficeXPCD.
  5. Insert the Office CD into your CD-ROM or DVD-ROM drive. Hold down SHIFT as you insert the CD to prevent Setup from starting automatically.
  6. In My Computer, right-click the CD-ROM or DVD-ROM drive, and then click Explore.
  7. On the Edit menu, click Select All.
  8. On the Edit menu, click Copy.
  9. Right-click the folder that you created in step 3, and then click Paste.
  10. When all the files have been copied to the new folder, quit all other programs that are running, and then double-click Setup.exe in the folder that you created in step 3 to start Windows Installer and Office Setup.
  11. Follow the on-screen instructions to complete the Office installation.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 19, 2009 | Microsoft Windows XP Home Edition
I need an instruction manual for a stoves heritage 720EF oven
I have just uploaded a scanned copy of the stoves 720- EF manual to the link below.
Requires the free Adobe Acrobat Reader or similar software to view the manual which most computers already have. The stoves ef720 manual file below is full and free of charge
http://wl.filegenie.com/~simun/Stoves720EF.pdf
Jun 02, 2009 | Stoves 720EF Electric Double Oven
Printing double sided with MFC-6490CW printer
Hee is you support website See if they have directions(manual ) to download for instructions. I take it that this printer is designed to print double sided else I can tell you the method that works on all printers.
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us〈=en∏=mfc6490cw_all
Mar 13, 2009 | Brother MFC 6490CW InkJet Printer
How do i make double sided copies for my HP 2840
When the printer window pops up, click on preferences then features to enable manual two-sided printing.
Dec 21, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Setting the copier to Double Siding as Default
Select the Double-side function that you require as standard. Select COMMON SETTINGS, found in Additional Functions (X) button. Select the Store Common Functions setting and press OK. Think this is correct, let me know? In order to reverse setting, follow instructions to get to STORE selection but select INITIALIZE. Hope this helps.
Mar 13, 2008 | Canon imageRUNNER 5570 Copier
Copystar CS-1620 Copier Logo
23 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
