Question about HP Office Equipment & Supplies
HP Photosmart 8450. Replaced black inkjet cadtridge with hp 94 (HP C9350N) Error Message:Print cartidge cradle is stuck. Clear jam then press OK. I do not know where cradle is and I see no obstruction. Cartridge removed and replaced several times. Same error message.
  • sutsu Nov 21, 2008
    Rechecked tightness of cartridge several times. Also checked tightness compared with other two cartridges which were not changed. OK. Each time printer turned on,press OK an active rubbing sound on a second or two then the stop and error signal appears.
  • 53 Answers
Hello ... click the link below n select troubleshooting option to get the solution....http://h10032.www1.hp.com/ctg/Manual/c00230503.pdf
thank you..........
Posted on Nov 21, 2008
    Guru:
  • 859 Answers
The Ink cartridges snap into a print head. The print head resides on the print carriage. The carriage moves on the carriage travel arm. With the pinter on, reach in a push the carriage against the right side and then pull the carriage towards the center of he travel arm. When the carriage is in the center, turn the printer off and then on again. See if the error resolves itself after this. There is a sensor at the far right side of the carriage travel arm on the inside wall of the printer. This can get gummed up. If the error repeats soon. Pull the carriage away again, turn the printer off and swab down the sensor on the far right. You should be able to pick it out visually. Swab it down with rubbing alchohol diluted with water to a 50/50 mixture.
  • 734 Answers
May be your new cartidge is not for your model. give me the number of your cartidge.
    Brigadier General:
  • 6,966 Answers
Offhand, either a mechanical problem with the linkage drive or the motor system or most likely a smudged encoder strip. This then would require cleaning. Clean the encoder strip on both sides with a paper towel and a mild cleaner. This would be the clear narrow belt from left to right inside the printer that the print head uses as a basis for its position. There should be evenly spaced black bars (almost like bar codes). If the print head could not sense the interval between and the black bars, it would stop and presume a jam.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • 749 Answers
Here is a complete guide to the solution-- (wont fit here with pictures or i would type it out. http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00255661&dlc=en&product=402150
    Sergeant:
    Champion:
  • 347 Answers
Hello sutsu,
Make sure you are fitting the cartidge in properly into its place, and it is not lose on the cartidge position.
Print Cartridge stuck
Look at the pad on the right side of the printer under where the ink cartridges are loaded. It may have ink deposits built up into lumps which interfere with the movement of the cartidges on the rod. Clean the deposits by scraping the lumps and removing all debris. This worked for me.
Jan 23, 2010 | HP PhotoSmart 7550 InkJet Printer
My printer keeps saying
There is probably a small piece(s) of debris floating around in there. Look very carefully for it with a flashlight. Try to remove it that way.
You can also buy "canned air" available at computer and office supply stores and use it to blow out the printer as thoroughly as you can.
Believe it or not, I have read where a small piece of skin has kept the carriage from moving properly.
Oct 25, 2009 | HP Photosmart 375 InkJet Printer
Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
Get error message on my HP Photosmart 7760 that "Print cartridge cradel stuck. Clear jam then press okay"...but there is no jam. :( Help...thanks.
jam not on the paper but, check the space where the printhead slides on, see if there is something blocking the path
Jun 26, 2009 | HP PhotoSmart 7760 InkJet Printer
Hp photosmart 7550 says carriage is stuck
print cartrigeis cradle is stuck clear jam then press ok in hp photosmart 7550.
Apr 04, 2009 | HP PhotoSmart 7550 InkJet Printer
Print cartridge cradle is stuck error message
The cartridges & container must be removed and reinstalled.
Apr 03, 2009 | HP PhotoSmart 7760 InkJet Printer
Error Message - "Print Cartridge Cradle is Stuck. Clear jam."
open the printer - take out the print cartridge and put it back in
Mar 20, 2009 | HP PhotoSmart 7960 InkJet Printer
HP Photosmart 335 Error Mesage
It is programmed to malfunction just like the dell computers, your best bet is to buy another competitors product and never buy the HP brands again!!!
Dec 26, 2007 | HP Photosmart 335 InkJet Printer
HP 7660 "Print Cartridge Cradle is Stuck" Message
I was having same problem but it was a paper jam all the time and then it started to state Cairrage Jam. And what was happening was the unit the cartridges sit in was not going all the way to the right. A little nudge and you could feel it move. Closed lid and sometimes it would print but eventually it would fail. Just replaced but I suspect if you can get to the cairrage you could clean/repair whatever was keeping it from going all the way to the right.
Hope that helps!
Dec 18, 2007 | HP Photosmart 7660v InkJet Printer
Cartridge cradle is stuck
I have had this problem with my 7550 for a while now and I finally found this on the HP website and it seems to have fixed my problem, I also replaced all of the cartridges:
Issue While printing from an HP Photosmart printer, the printer screen displays Print cartridge cradle is stuck / clear jam and then press OK . The printer may also make grinding sounds. This can occur after a paper jam when another printer part blocks the cradle. Solution Follow these instructions to adjust the clutch on the printer.
  1. Disconnect the USB cable.
  2. Press the printer power button to turn off the printer.
  3. Disconnect the power cord from the back of the printer.
  4. Open the top cover of the printer.
  5. Remove the print cartridges from the printer.
  6. Slide the cradle to the right side of the printer.
  7. Locate the clutch on the left side of the printer.
    NOTE: The clutch is a flat, white, plastic component that rests just above the white roller gear wheel. In the HP Photosmart P1000 and P1100 printers, the clutch is black metal. Figure 1: Printer clutch c00020494.jpg
  8. Remove the rear access door from the back of the printer.
  9. Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
  10. Release the clutch and roll the wheels up two more rotations.
  11. Reinstall the rear access door.
  12. Reinstall the print cartridges and secure the latches in place.
  13. Close the top cover and reconnect the power cord.
  14. Turn on the printer.
  15. Print a test page.
Nov 27, 2007 | HP PhotoSmart 7550 InkJet Printer
37 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
